Re: alcohol vs race gas
[Re: ek3]
#2602246
01/05/19 11:42 PM
01/05/19 11:42 PM
Posts: 76 georgia
intenseneon
georgia
On my 12:1, solid cam 408 I made 50hp and about the same more in tourque with Alky over 110 fuel.
69 Dart
[Re: ek3]
#2602757
01/07/19 02:33 AM
01/07/19 02:33 AM
Posts: 304 Florida
Mark Whitener
Gains depends on the Induction and combustion efficiency of the engine, and how well the converter and gear are matched to go with it. I just had a customer switch from a 650 on gas to a 650 on methanol and pick up 1/2 a second in the 1/8 mile. My SB2 head engine in my dragster would slow down with anything other than gas (no nitro in this conversation...;-) ) So it's really subjective to the combination.
Mark Whitener [url=www.racingfuelsystems.com[/url]
[Re: ek3]
#2603486
01/08/19 04:46 PM
01/08/19 04:46 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
I help a friend w/ his Camaro. 436" sbc, 14.5:1 compression, AFR heads, glide, 9", ladder bars, etc. Makes somewhere around 700 hp. Ran on alcohol (4150 Demon 825 cfm carb) and ran a best of 5.78 in the 1/8 mile w/ a 1.24 sixty foot at 2900 lbs. Ran this configuration for years.
Switched it to race gas a few years ago (112) and went to a 1050 Dominator...same manifold (Edelbrock Victor 4150) w/ the tall 4500 adapter. Now it's 100 lbs heavier at 3000 lbs and it went a best of 5.93 w/ a 1.27 sixty foot. It lost a noticeable amount of lowend torque and obviously some HP, but never dyno'd either setup. Knew it would slow down some, but was hoping the Dominator would help not to slow down too much. It has more in it (still needs more tuning), been a long time since the car was run, but it won't run what it did on the alcohol.
[Re: an8sec70cuda]
#2603494
01/08/19 05:08 PM
01/08/19 05:08 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
My personnel opinion on straight methanol, not race methanol like M1 or M5, is it will as fast or faster by a tiny bit on straight methanol compare to non oxygeneated race gas I switch to pump E 85 several years back and love it, deadly consistent and half as much cost per gallon as the local race gas and the motor runs cooler No issues with oil dilution either
[Re: ek3]
#2604121
01/09/19 09:59 PM
01/09/19 09:59 PM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
There are some inaccuracies posted so far. Methanol burns slightly faster than gas. I run 34 degrees timing on alky, a lot of 440-1 motors on gas run more. Methanol has more energy than gas based on a stoiciometric mixture, because it runs at least 2.2 times the volume of fuel per cfm of air than gas. The fact that some claim gas makes more power may well be that only very high rpms allow this? The statement flys in the face of thousands of racers seeing reduced ETs going to methanol. Methanol lowers charge temp considerably, increasing the amount of air (measured as mass) inhaled
[Re: ek3]
#2604384
01/10/19 12:55 PM
01/10/19 12:55 PM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
The reasons some motors make more power on alky are mostly based in the inefficiencies inherent in the type of motor. No one is arguing that almost all bracket type engines will behave better on alky for bracket racing.
The decrease in timing requirement in a few motors isn't related to the fuel being better, but the increase in chamber efficiency brought about by twice the volume of liquid in the chamber, and how that effects compression. Also the reduction in temperature.
The effort required to deliver twice the volume of fuel, and the space that it consumes in doing so will always handicap the process in high efficiency engines. A normal 1.8hp per inch bracket motor would almost always be helped by alcohol. A 3hp per inch gas motor would be crippled by alky.
It really just comes down to the energy density of fuel.
Fuel Density kg/m3kg/m^{3}kg/m3 Specific Energy MJ/kgMJ/kgMJ/kg Energy Density MJ/m3MJ/m^{3}MJ/m3 Gasoline 716 -47.3 -33,867 Kerosene 830 -46.2 -38,346 Diesel Fuel 830 -44.8 -37,184 Ethanol 784 -29.7 -23,278 Coal (Anthracite) 1350 -27 -36,450 Methanol 787 -22.7 -17,855 Wood 600 -15 -9,000 Coal (Lignite) 801 -15 -12,015
[Re: WHITEDART]
#2604521
01/10/19 05:33 PM
01/10/19 05:33 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
We made 18 hp more with q16 over pump e85..back to back .the e85 carb was a little bigger How much was the Q16 a gallon?
[Re: pittsburghracer]
#2604527
01/10/19 05:44 PM
01/10/19 05:44 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
We made 18 hp more with q16 over pump e85..back to back .the e85 carb was a little bigger How much was the Q16 a gallon? . $20 a gallon.. vs E85 at $3.. personally I loved E85 just couldn't make it happy where we were at even experimented with race blend E85 at $20 a gallon . I will tell you my valve spring bill offset the cost in the fuel for sure.. we like to leave the starting line absolutely as cold as possible on cue and used to like to leave the starting line at 180 degrees on the E . Which was definitely hard on the valve springs and valve job
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: racerx]
#2605128
01/11/19 09:27 PM
01/11/19 09:27 PM
WHITEDART
bean town ....Ca
were there a HP difference with the race blend e-85? [/quote] . Unfortunately only tested in the car never on the dyno and personally didn't see much to gain with our application
[Re: WHITEDART]
#2605133
01/11/19 09:44 PM
01/11/19 09:44 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
. Unfortunately only tested in the car never on the dyno and personally didn't see much to gain with our application [/quote] That "goofy" e-85 you had made Q16 smell good. It should have come with a Hazmat suit
"Just a Bracket car dressed up like a streetcar"
[Re: WHITEDART]
#2605291
01/12/19 04:39 AM
01/12/19 04:39 AM
Posts: 4,070 Mo.
racerx
Mo.
. Unfortunately only tested in the car never on the dyno and personally didn't see much to gain with our application [/quote] Thaxs……. I kind of wonder if there were an real world advantage of using the race blend verse mixing your own.
