Re: more Duster bracket car questions
[Re: RustyM]
#2601792
01/05/19 01:55 AM
01/05/19 01:55 AM
Posts: 20,990 A collage of whims
topside
A collage of whims
Rusty, as the saying goes, "your mileage may vary"; not sure what nose weight you have so I can't compare, but I have a SB, mostly stock K with 6-cyl bars, its original setup from its SS/IA days. 2 batteries in trunk + the ballast.
I can't recall what wheelie bars we used, maybe Morrison's kit; we narrowed them and they mount to the rear axle. They're spring-loaded so they don't unload the rear axle/tires. Had to narrow the stock fuel tank on the right side for the right wheelie bar because my Dana's fairly narrow (3" spring relocation, 13x31s). One thing leads to another, you know.
Easy enough to fab a block-off from light/thin sheet aluminum, or leave the area as-is without the controls.
[Re: @#$%&*!]
#2602579
01/06/19 08:29 PM
01/06/19 08:29 PM
Posts: 43,367 Bend,OR USA
Cab_Burge
A Duster has curved widow glass, how's that work with Lexan? I think there are several different companies that make them in in either 3/16 or 1/4 inch thick as direct replacement windshields ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) My airplane(1960 Piper Comanche) had all Lexan windows and one piece windshield made for a 180 MPH airplane, I used special expensive cleaners a for them until a old timer at the airport told me about using Lemon Pledge furniture polish, liquid or spray cans, on Lexan ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) That is the hot ticket as the polish removes scratches and protect the windshield from bugs guts sticking also ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: RustyM]
#2603579
01/08/19 08:36 PM
01/08/19 08:36 PM
Posts: 9,897 MI, usa
dvw
MI, usa
DVW: how long does the lexan last? real world? I understand it scratches up really easily? Secondly : I haven't gutted the doors as yet, i'm guessing most of the weight is the glass and regulator? Dang doors are heavy. Same Lexan, year 7. Few scuffs but looks pretty good. Doug
