Innovate #3844 A/F ratio gauge set. Info needed
#2599347
12/31/18 06:12 PM
12/31/18 06:12 PM
RapidRobert
I was considering one & thought I had red some reviews here that were good (but it was quite awhile back) then I saw some reviews elsewhere that were pretty bad. Any thoughts/suggestions. thank you for your time
Re: Innovate #3844 A/F ratio gauge set. Info needed
[Re: RapidRobert]
#2599351
12/31/18 06:24 PM
12/31/18 06:24 PM
Posts: 7,491 Minnesota
Hemi_Joel
Minnesota
I have a pair of them in my hot rod. since the intake is divided into two plenums, I got one gauge for each side. No problems, other than they don't show up in video.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: RapidRobert]
#2599750
01/01/19 12:29 PM
01/01/19 12:29 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Also not the same but I have two of their LC-2 units feeding my EFI and they have been flawless.
68 Barracuda Formula S 340
[Re: RapidRobert]
#2599934
01/01/19 03:39 PM
01/01/19 03:39 PM
Posts: 1,708 central il.
second 70
central il.
Mine has been trouble free for years. Easy install
[Re: second 70]
#2600237
01/01/19 11:41 PM
01/01/19 11:41 PM
RapidRobert
I'm still on the fence but thanks guys for the input. Appreciated!
