Brass Gear ? Oil pump drive #2597637
12/27/18 03:54 PM
12/27/18 03:54 PM
Midwest
fuseable Offline OP
fuseable  Offline OP
Midwest
How (if there is a way) is the best way to check gear for wear? Can you check tooth thickness, or can it be checked like a ring gear, like you check backlash (might have worked if I had checked it when new, like a benchmark)?
Re: Brass Gear ? Oil pump drive [Re: fuseable] #2597642
12/27/18 04:02 PM
12/27/18 04:02 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Just look to see how deep the wear is on the gear. A collar the dist shaft spaced a few grand up from the gear will help slow the wear down.
Re: Brass Gear ? Oil pump drive [Re: fuseable] #2597648
12/27/18 04:17 PM
12/27/18 04:17 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Pop the cap and move the rotor,that is a strong indication how much wear there is.Also with the timing light if the timing is jumping around that points to a worn gear.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Brass Gear ? Oil pump drive [Re: fuseable] #2597659
12/27/18 05:05 PM
12/27/18 05:05 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Just for clarity...its Bronze, there's a difference
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Brass Gear ? Oil pump drive [Re: fuseable] #2597669
12/27/18 05:18 PM
12/27/18 05:18 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
On mine the teeth just get thinner over time. Takes quite awhile.
Rich H.
Esse Quam Videri
Re: Brass Gear ? Oil pump drive [Re: ZIPPY] #2597676
12/27/18 05:51 PM
12/27/18 05:51 PM
Midwest
fuseable Offline OP
fuseable  Offline OP
Midwest
Bronze, point taken.
Re: Brass Gear ? Oil pump drive [Re: fuseable] #2597682
12/27/18 06:09 PM
12/27/18 06:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just pull the gear.. its easy.. mark your timing
and see where the gear is pointing.. pull the
gear and see if you would replace it.. put it
back together and check your timing
wave
Re: Brass Gear ? Oil pump drive [Re: fuseable] #2597719
12/27/18 08:01 PM
12/27/18 08:01 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Wear pattern marching up or down the tooth surface = bad.
Boffin Emeritus
Re: Brass Gear ? Oil pump drive [Re: fuseable] #2597723
12/27/18 08:06 PM
12/27/18 08:06 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
They get sharp on the ends. When they get sharp and obviously worn just replace it. You will always have a little bronze in the filter running these.
Re: Brass Gear ? Oil pump drive [Re: Dave Hall] #2597782
12/27/18 10:44 PM
12/27/18 10:44 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Typically the outer edge of the gear thins out. I have seen some you could shave with. Good filtration will help keep the nasties out of the oil.I had an interesting deal happen one time when a customer neglected to replace the block bushing while using one and his motor burned one up in record time. The teeth on the timing chain were showing bronze being transferred to the teeth to the point it "looked" like the billet steel gear was wearing out according to him....
Re: Brass Gear ? Oil pump drive [Re: ZIPPY] #2597788
12/27/18 10:48 PM
12/27/18 10:48 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I only got a year out on mine? And Not many miles on it frown
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Brass Gear ? Oil pump drive [Re: Kam*Kuda] #2597834
12/28/18 12:51 AM
12/28/18 12:51 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
How bad is it?
Re: Brass Gear ? Oil pump drive [Re: ZIPPY] #2597987
12/28/18 02:44 PM
12/28/18 02:44 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
X2. Same here, the teeth get thinner over time.
I usually use the Mopar Performance drive, and they seem to last pretty good. Have one around here with 10,000 miles on it. I'll take a photo if I find it.
Put a 440 Source one in the 505, but don't have many miles on it to see how durable it is?
Re: Brass Gear ? Oil pump drive [Re: fuseable] #2598189
12/28/18 11:28 PM
12/28/18 11:28 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I was talking to a Crower Tech the other day and he said oil pressure affects gear wear a lot. He recommends 20 psi at idle and 60 on the high side.
Re: Brass Gear ? Oil pump drive [Re: fuseable] #2598202
12/29/18 12:00 AM
12/29/18 12:00 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Too much end play kills the gear
Re: Brass Gear ? Oil pump drive [Re: fuseable] #2598802
12/30/18 02:31 PM
12/30/18 02:31 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Found the MP drive with around 10,000 miles on it, turning HV pump.
