Thanks!
The plastic was a little of a long term concern. I hadn't seen the 034 Motorsport option. I like that. I'd forgotten about the RobbMc's as well. I meant to check it out, but hadn't. At first I liked the idea of the Holley Hydramat, but not cheap and it is the filter that eventually needs replaced at the same, or eventually higher, cost.
I would prefer an off the shelf baffled tank, but my tank is fairly new, and I haven't seen any for 67 back.
64Sportfury, I'll PM you later. Not sure I want to go that direction, but would like to see how it fits. If I were replacing my tank, I would be more likely to consider it. Seems like a good option.
I'll also look into the Amazon link.
