Page 5 of 5 1 2 3 4 5
Re: Rocker ratio questions [Re: fourgearsavoy] #2597979
12/28/18 02:22 PM
12/28/18 02:22 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Originally Posted By fourgearsavoy
Well I'm looking at another Howards cam 260/268 duration and 555/574 lift with 108 separation.
The lift seems a little low but the duration is where I think would work with my car.
Gus beer
Close to the 259/266 that mine is, but with less lift and 1* less C/L.
open -------- close
int.24.5 BTDC 54.5 ABDC
ext.66 BTDC 20 ATDC These are the valve events of my cam.
With this, my power band is 3200-7200. Torq comes in around 4300.
My 2 step is usually set between 4600-5200.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Rocker ratio questions [Re: 68LAR] #2597994
12/28/18 02:52 PM
12/28/18 02:52 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Gus beer
open -------- close
Gus,
It seems you are liking Howards cams. See if this one fits? part number 721602-08. 260/260 .616/.616 lift on a 108 c/l. power 35-7200 rpm.
Re: Rocker ratio questions [Re: 68LAR] #2598163
12/28/18 10:07 PM
12/28/18 10:07 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
Well I pulled the trigger and ordered Howard's flat cam 260/264 616/620 108 LS and I think I will like it. Also ordered the Direct Lube lifters and some Max ZPM break in lube.
All in for $323.48
Still looking at springs,bee-hive maybe shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Rocker ratio questions [Re: fourgearsavoy] #2598167
12/28/18 10:18 PM
12/28/18 10:18 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
All in for $323.48
Gus beer
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Rocker ratio questions [Re: fourgearsavoy] #2598168
12/28/18 10:31 PM
12/28/18 10:31 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
All in for $323.48
Gus beer
Why so small? I run bigger in my 440.
Re: Rocker ratio questions [Re: fourgearsavoy] #2598231
12/29/18 02:11 AM
12/29/18 02:11 AM
All in for $323.48
Gus beer
I like your choice on that cam up Where will you install the intake lobes?
Re: Rocker ratio questions [Re: Cab_Burge] #2598355
12/29/18 01:38 PM
12/29/18 01:38 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
All in for $323.48
Gus beer
I like that choice also. I think it will work out real well for you.
