torque convertor slippage percent #2598028
12/28/18 04:07 PM
12/28/18 04:07 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
360 / 727 in a 1/2-ton pickup, 3.23 gears, 275-60-15 tires.
Using the old formula:
MPH = RPM x tire diameter / 336.13 x total gear ratio
I calculate about 16% convertor slippage at 50 MPH, level driving no load. At 50 MPH I'm at 2250 RPM.
Does this seem high for a stock convertor ?
Re: torque convertor slippage percent [Re: hemienvy] #2598030
12/28/18 04:12 PM
12/28/18 04:12 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Sounds high. I would expect to see more like 5-7%. Try this speed/rpm calc to double check your math:
https://www.e-bodies.org/resources/rpm-speed-gear-tire-size-calculator/
Re: torque convertor slippage percent [Re: hemienvy] #2598045
12/28/18 04:37 PM
12/28/18 04:37 PM
BDW Offline
BDW  Offline
I agree, 7% is about right
Re: torque convertor slippage percent [Re: hemienvy] #2598052
12/28/18 04:55 PM
12/28/18 04:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Be sure your speedo is accurate (check with GPS or roadside markers) and the tire diameter you used in your calculations is correct (check the rollout).
Re: torque convertor slippage percent [Re: hemienvy] #2598128
12/28/18 08:34 PM
12/28/18 08:34 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
IMO the slipage gets relatively more at slower rpms as the convertor become less efficient/capable of transferring the torque.
Switching the convertor Lockup ON from OFF on a A518 transmission resulted in some 200-300rpm drop usually while cruising at around 1500-2000rpm on my setup.
That's more than 10%.
