Re: Rocker ratio questions
[Re: fourgearsavoy]
#2597979
12/28/18 02:22 PM
12/28/18 02:22 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Well I'm looking at another Howards cam 260/268 duration and 555/574 lift with 108 separation. The lift seems a little low but the duration is where I think would work with my car. Gus Close to the 259/266 that mine is, but with less lift and 1* less C/L. open -------- close int.24.5 BTDC 54.5 ABDC ext.66 BTDC 20 ATDC These are the valve events of my cam. With this, my power band is 3200-7200. Torq comes in around 4300. My 2 step is usually set between 4600-5200.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: 68LAR]
#2597994
12/28/18 02:52 PM
12/28/18 02:52 PM
68LAR
South Park, Pa.
Well I'm looking at another Howards cam 260/268 duration and 555/574 lift with 108 separation. The lift seems a little low but the duration is where I think would work with my car. Gus Close to the 259/266 that mine is, but with less lift and 1* less C/L. open -------- close int.24.5 BTDC 54.5 ABDC ext.66 BTDC 20 ATDC These are the valve events of my cam. With this, my power band is 3200-7200. Torq comes in around 4300. My 2 step is usually set between 4600-5200. Gus, It seems you are liking Howards cams. See if this one fits? part number 721602-08. 260/260 .616/.616 lift on a 108 c/l. power 35-7200 rpm.
[Re: 68LAR]
#2598163
12/28/18 10:07 PM
12/28/18 10:07 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
Well I pulled the trigger and ordered Howard's flat cam 260/264 616/620 108 LS and I think I will like it. Also ordered the Direct Lube lifters and some Max ZPM break in lube. All in for $323.48 Still looking at springs,bee-hive maybe Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2598167
12/28/18 10:18 PM
12/28/18 10:18 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
Well I pulled the trigger and ordered Howard's flat cam 260/264 616/620 108 LS and I think I will like it. Also ordered the Direct Lube lifters and some Max ZPM break in lube. All in for $323.48 Still looking at springs,bee-hive maybe Gus Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: fourgearsavoy]
#2598168
12/28/18 10:31 PM
12/28/18 10:31 PM
BradH
Well I pulled the trigger and ordered Howard's flat cam 260/264 616/620 108 LS and I think I will like it. Also ordered the Direct Lube lifters and some Max ZPM break in lube. All in for $323.48 Still looking at springs,bee-hive maybe Gus Why so small? I run bigger in my 440.
[Re: fourgearsavoy]
#2598231
12/29/18 02:11 AM
12/29/18 02:11 AM
Posts: 43,202 Bend,OR USA
Cab_Burge
Well I pulled the trigger and ordered Howard's flat cam 260/264 616/620 108 LS and I think I will like it. Also ordered the Direct Lube lifters and some Max ZPM break in lube. All in for $323.48 Gus I like your choice on that cam Where will you install the intake lobes?
[Re: Cab_Burge]
#2598355
12/29/18 01:38 PM
12/29/18 01:38 PM
68LAR
South Park, Pa.
Well I pulled the trigger and ordered Howard's flat cam 260/264 616/620 108 LS and I think I will like it. Also ordered the Direct Lube lifters and some Max ZPM break in lube. All in for $323.48 Gus I like your choice on that cam Where will you install the intake lobes? I like that choice also. I think it will work out real well for you.
