Re: Brass Gear ? Oil pump drive
[Re: fuseable]
#2597648
12/27/18 04:17 PM
12/27/18 04:17 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Pop the cap and move the rotor,that is a strong indication how much wear there is.Also with the timing light if the timing is jumping around that points to a worn gear.
[Re: fuseable]
#2597659
12/27/18 05:05 PM
12/27/18 05:05 PM
Posts: 2,122 Byron, NY
W.I.N. Racing
Byron, NY
Just for clarity...its Bronze, there's a difference
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: fuseable]
#2597669
12/27/18 05:18 PM
12/27/18 05:18 PM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
On mine the teeth just get thinner over time. Takes quite awhile.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2597676
12/27/18 05:51 PM
12/27/18 05:51 PM
Posts: 774 Midwest
fuseable
Midwest
[Re: fuseable]
#2597682
12/27/18 06:09 PM
12/27/18 06:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Just pull the gear.. its easy.. mark your timing and see where the gear is pointing.. pull the gear and see if you would replace it.. put it back together and check your timing
[Re: fuseable]
#2597719
12/27/18 08:01 PM
12/27/18 08:01 PM
Posts: 4,213 New York
polyspheric
New York
Wear pattern marching up or down the tooth surface = bad.
Boffin Emeritus
[Re: ZIPPY]
#2597788
12/27/18 10:48 PM
12/27/18 10:48 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
On mine the teeth just get thinner over time. Takes quite awhile. I only got a year out on mine? And Not many miles on it
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: Kam*Kuda]
#2597834
12/28/18 12:51 AM
12/28/18 12:51 AM
ZIPPY
S.E. Michigan
On mine the teeth just get thinner over time. Takes quite awhile. I only got a year out on mine? And Not many miles on it How bad is it?
[Re: ZIPPY]
#2597987
12/28/18 02:44 PM
12/28/18 02:44 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
On mine the teeth just get thinner over time. Takes quite awhile. X2. Same here, the teeth get thinner over time. I usually use the Mopar Performance drive, and they seem to last pretty good. Have one around here with 10,000 miles on it. I'll take a photo if I find it. Put a 440 Source one in the 505, but don't have many miles on it to see how durable it is?
