72 A Body Vacuum Canister Bracket Picture ? #2597316
12/26/18 10:04 PM
12/26/18 10:04 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
Can anyone post a picture of a correct 1972 (only ?) A Body vacuum canister bracket? It is located in the right front corner of the engine compartment? I need to locate one and have seen a couple of different versions and trying to determine which one is correct.Thanks for any help.
Re: 72 A Body Vacuum Canister Bracket Picture ? [Re: 44D6PAKCUDA] #2597580
12/27/18 02:06 PM
12/27/18 02:06 PM
Shoreline, Washington
72roadrunnergtx Offline
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: 72 A Body Vacuum Canister Bracket Picture ? [Re: 72roadrunnergtx] #2597586
12/27/18 02:13 PM
12/27/18 02:13 PM
I ended up buying that bracket.Now I am confused as to what was originally used on my 1972 GSS Demon.Did they use/bend/adapt the original A body bracket or did they use the E body bracket that has the step brecket that appears to fit against the firewall better? Does anyone have the contact info for the board member from FL that has a 72 GSS Demon? I PM'd him a while back but never heard from him
Re: 72 A Body Vacuum Canister Bracket Picture ? [Re: 44D6PAKCUDA] #2597770
12/27/18 10:09 PM
12/27/18 10:09 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Did you mean to say "where it fits against the inner fender"...and not.."to fit against the firewall".
Here's a picture I took today of an original one, original passenger inner fender mount location.
From a 73 Duster if it makes a difference...looks exact as yours
