69 440 HP ID #2595875
12/23/18 06:06 PM
12/23/18 06:06 PM
fresno ca
mikeysmopars Offline OP
fresno ca
Just picked up a69 440 HP engine that's been sitting in a shed. Anyone tell what this engine came out of from the VIN on the block? Be nice to find the car it came from but it has a bad piston in #5 and burned through 3&5 cylinder deck. Still standard bore, I think it will clean up to 30 after the top gets fixed. Plan to use it in one of my projects unless I find the car it came from.
IMG_20181223_115352165-800x600.jpgIMG_20181223_115406678-800x600.jpgIMG_20181223_115358899-800x600.jpg
Founder and CEO of the Central Valley Mopar Drag Pack
Re: 69 440 HP ID [Re: mikeysmopars] #2595876
12/23/18 06:08 PM
12/23/18 06:08 PM
fresno ca
fresno ca
Couple more
Date code
Re: 69 440 HP ID [Re: mikeysmopars] #2595899
12/23/18 06:59 PM
12/23/18 06:59 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
from a Dodge or Plymouth c-body shruggy probably a former cop-car
Re: 69 440 HP ID [Re: 6bblgt] #2595910
12/23/18 07:23 PM
12/23/18 07:23 PM
fresno ca
fresno ca
Hmmm...thanks!
Re: 69 440 HP ID [Re: mikeysmopars] #2596148
12/24/18 03:35 AM
12/24/18 03:35 AM
AndyF Offline
AndyF  Offline
Looks like junk to me. Once the rust gets that bad in the bore you usually can't save them.
Re: 69 440 HP ID [Re: AndyF] #2596220
12/24/18 12:20 PM
12/24/18 12:20 PM
Sudbury, ontario canada
750-h2 Offline
750-h2  Offline
If there is too much rust to bore it out you can have a machine shop install a sleeve. A properly installed sleeve will make that cylinder as good as new.
Re: 69 440 HP ID [Re: mikeysmopars] #2596246
12/24/18 01:09 PM
12/24/18 01:09 PM
A727Tflite Online content
A727Tflite  Online Content
Buy a cheap dingle berry hone and have at it. If you can clean it up and it only has pits after, then .030” should make it right.
Use lots of mineral spirits while honing it to clean that rust out.
I have also used a large round wire brush on a drill motor to do the same thing.
Re: 69 440 HP ID [Re: mikeysmopars] #2596352
12/24/18 04:41 PM
12/24/18 04:41 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
You’ll spend more money on that block than it’s worth. STD bore 440 blocks are 250 or less and they don’t have rust for that price. The HP means nothing unless it’s the original motor to muscle car.
Re: 69 440 HP ID [Re: fastmark] #2596398
12/24/18 06:14 PM
12/24/18 06:14 PM
AndyF Offline
AndyF  Offline
I agree, blocks that have hard rust in them (not just surface rust) are almost always junk. I've been dragging rusty blocks into the machine shop for years and they almost always tell me to just toss the block onto the recycle pile. One problem with rusty blocks is that if the inside of the cylinder bore is rusty then the outside of the cylinder bore (inside the water jacket) is usually rusty too. If the cylinder walls get a lot of rust damage inside the water jacket then that will cause problems for the engine as well. You do not want to start off a $10,000 engine build with a rusty block. No good comes from that.
Re: 69 440 HP ID [Re: mikeysmopars] #2596584
12/25/18 12:36 AM
12/25/18 12:36 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Practice your honing skills on the block. Have a bore gauge handy and try to keep it to as little as possible. This will give you the answer if you want to use the block for a build and then get it hot tanked. Is the surface between the cylinders is that a groove. If it is a groove there are a few tricks to fix that or you will have the surface milled.
1971 HEMI E BODY REGISTRY
Re: 69 440 HP ID [Re: hemicar1971] #2597114
12/26/18 01:22 PM
12/26/18 01:22 PM
fresno ca
fresno ca
Thanks everyone, I'll get it apart & see if it's even worth messing with. It was given to me so not out anything. Was told it was out of a boat so I expected the worst anyway.
Re: 69 440 HP ID [Re: mikeysmopars] #2597157
12/26/18 02:48 PM
12/26/18 02:48 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Does engine rotation mean anything for just a boat engine BLOCK?
Re: 69 440 HP ID [Re: mikeysmopars] #2597291
12/26/18 08:19 PM
12/26/18 08:19 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I'm fortunate to have this very close to home,only way I would do " anything " anymore. If you have something comparable close,it would probably be worth the cost,and it is not hot tank.That block here would cost you about $75,well worth it just to know.
http://www.mecchemicals.com/services.php
Re: 69 440 HP ID [Re: 62maxwgn] #2597308
12/26/18 09:12 PM
12/26/18 09:12 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I think the closest one to us is in Oregon
Re: 69 440 HP ID [Re: mikeysmopars] #2598195
12/28/18 11:41 PM
12/28/18 11:41 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
looks like it's flame cut between the cylinders in the lower photo.
