Compression VS H.P. #2596824
12/25/18 05:31 PM
12/25/18 05:31 PM
new jersey usa
11secdart Offline OP
new jersey usa
I am considering lowering the compression in my 363 ( 30over 360 magnum block, W2 heads, 590 lift M/P mech. cam) from 11.5 to 1 to 9.5 to 1 so i can use pump gas. It made 549 hp and 450 tq on the dyno and went 10.60s at 125 in my Dart. 3150 lbs, 4.30 gear, 4800 stall Converter, 904. How much power will i loose? I stopped it down to run 11.50s. will it run high 10s-low 11s? Don't mind losing a little but still want to be able to run 11.40s in bad air.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Compression VS H.P. [Re: 11secdart] #2596830
12/25/18 05:39 PM
12/25/18 05:39 PM
AndyF Online content
AndyF  Online Content
Hard to say since it will depend on the combustion chamber design. I've seen dyno tests where reducing the piston dome actually increased power even though the compression went down. That can happen on a BB Chevy where they use a big dome. So if you are switching from a dome to a flat top piston you might not see a large difference in power.
Re: Compression VS H.P. [Re: 11secdart] #2596837
12/25/18 05:52 PM
12/25/18 05:52 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Are you planning to change the cam to go with the lower compression ratio?
Re: Compression VS H.P. [Re: PorkyPig] #2596842
12/25/18 05:58 PM
12/25/18 05:58 PM
new jersey usa
new jersey usa
i wasn't planning on it.
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: Compression VS H.P. [Re: 11secdart] #2596849
12/25/18 06:09 PM
12/25/18 06:09 PM
P
PorkyPig Offline
PorkyPig  Offline
P
I believe dropping 2 points on compression without a cam change to account for this could hurt your torque everywhere. I don't think you have enough cubic inches to just lower the cr without giving up 20 or 30 HP. But it wouldn't be the first time I was wrong about something.
Re: Compression VS H.P. [Re: 11secdart] #2596853
12/25/18 06:25 PM
12/25/18 06:25 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Would you need to drop it down to 9.5:1 to run pump gas?
72 Plymouth Roadrunner 11.08@123.25
Re: Compression VS H.P. [Re: 11secdart] #2596867
12/25/18 06:43 PM
12/25/18 06:43 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
You can turn down the timing to get you to pump gas levels. Running the N.E. Index? This can get you there. Will take several passes to get the new feel of the car. Might need to cut a tighter light to make up for a sluggish launch( might not even show). But if you back the timing a little, you can try premium,93 octane, and Klotz octane booster. Works well w/o the plug issues of others and makes the pump gas last longer w/o carb/pump issues.
Re: Compression VS H.P. [Re: 11secdart] #2596872
12/25/18 06:57 PM
12/25/18 06:57 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Have you considered water/meth on pump gas?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Compression VS H.P. [Re: 11secdart] #2596907
12/25/18 08:20 PM
12/25/18 08:20 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
E-85
Re: Compression VS H.P. [Re: 11secdart] #2596918
12/25/18 09:13 PM
12/25/18 09:13 PM
Washington
madscientist Offline
Washington
I'd spend my money on a cam from a custom grinder long before I dumped the compression and no way in hell would I ever drop it that far.
It's 2019 and you can easily run that compression ratio on pump gas. The issue isn't your compression ratio. It's the cam. I like the MP cams but I'd say look at a different cam, preferably one that isn't in a catalog or on someone's shelf.
Me? I'd call Jim at Racer Brown and tell him what you are doing and see what he says. I run the same CR as you on pump gas. I don't have detonation issues. I also have a dome. It's not an issue.
I've also used Cam Motion for relatively high CR pump gas stuff and never had an issue.
I'm not a fan of giving up CR when you don't need to.
Re: Compression VS H.P. [Re: 11secdart] #2596963
12/25/18 11:27 PM
12/25/18 11:27 PM
K
KOS Offline
KOS  Offline
K
that 590 wants compression...you will have to change it or it will be a dog.the MP 557 would work perfectly.
Re: Compression VS H.P. [Re: KOS] #2597069
12/26/18 09:42 AM
12/26/18 09:42 AM
new jersey usa
new jersey usa
Thanks for great advice guys, Happy Holidays ! Yes I run some N.E. index races.
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: Compression VS H.P. [Re: 11secdart] #2597077
12/26/18 10:57 AM
12/26/18 10:57 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I'd shoot for the 10-10.5:1 compression range and others have stated a cam change would also prob be needed to help optimize it.
Re: Compression VS H.P. [Re: 11secdart] #2597164
12/26/18 03:04 PM
12/26/18 03:04 PM
Renton Washington
Triple Threat Offline
Renton Washington
I ran my old Aluminum headed SB @ 11.3:1 on 92 octane pump gas.
If you could get to 10:1 i think you'd be pretty safe as long as you dont get greedy with timing.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Compression VS H.P. [Re: 11secdart] #2597206
12/26/18 04:27 PM
12/26/18 04:27 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I run 11 to 1 with iron magnum heads, some thought into keeping the air cool and some other tricks should be able to make it live just fine on pump premium as is. 9.5 is very low these days.
Re: Compression VS H.P. [Re: 11secdart] #2597241
12/26/18 05:55 PM
12/26/18 05:55 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Sorry if some of this is obvious?
Tighten your quench to .035".
Reduce your initial spark lead.
Slow up and lengthen your spark advance curve.
Consider a high gear only 2-4° spark retard (45 years old, H/T Bill Jenkins)
Higher number PV.
Step up the mains 1 number.
Bigger ATF cooler.
Retard the cam 4° (watch your exhaust P-V!).
Boffin Emeritus
Re: Compression VS H.P. [Re: 11secdart] #2597248
12/26/18 06:11 PM
12/26/18 06:11 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I think POLY wants to build you a moder !! smoke
Re: Compression VS H.P. [Re: polyspheric] #2597276
12/26/18 07:28 PM
12/26/18 07:28 PM
Washington
Washington
Higher number PV.
Bigger ATF cooler.
All these are much better options for the OP than his original idea.
Re: Compression VS H.P. [Re: 11secdart] #2597681
12/27/18 06:05 PM
12/27/18 06:05 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
WHy not consider a head swap? get some magnum type heads to replace the W2 . Also you have a magnum block, get an up to date roller hydraulic cam and you probably be fast enough for 10.00 index....
just a thought, im like that...I rather speed up than slow down lol
....BAD A$$ STREET CAR.....
Re: Compression VS H.P. [Re: 11secdart] #2597702
12/27/18 07:25 PM
12/27/18 07:25 PM
You may loose 30 HP but gain more torque with lower compression on pump gas work
All the iron headed pump gas motors I've dyno that had less than 10.5 to 1 compression, aluminum head motors also, made more torque than HP by 30+ Ft Lbs. work
I wouldn't hesitate to run the pump gas with 9.5 to 1 compression ratio as long as you retune the motor for it up
Torque moves the mass, not HP shruggy HP make it MPH up
