Re: WET FLOW CYLINDER HEAD
[Re: A/MP]
#2595934
12/23/18 08:34 PM
12/23/18 08:34 PM
Posts: 4,457 Washington
madscientist
Washington
Darin Morgan used to have some posted, but it want small block stuff.
[Re: PorkyPig]
#2596917
12/25/18 09:03 PM
12/25/18 09:03 PM
madscientist
Washington
Google cylinder head wet flow test and check the videos tab. There are a few but most are pretty short.
I don't think Ryan had a wet flow bench. As I recall he was spraying Dykem or something like that straight into the intake port while running his regular flow bench. Seen others do it too, but it's got to make a huge mess inside the flow bench. Not really...it dries before it gets very far past the valve, if that. The farthest it gets that I've seen in the adapter.
