Square back alternator details - Housing #2595810
12/23/18 03:49 PM
12/23/18 03:49 PM
Phila. Pa.
Mattax Offline OP
Mattax  Offline OP
Phila. Pa.
'74 Parts books shows a different rectifier end housing (ie case) for the 65 amp squarebacks, vs all the others.
Does anyone have pictures of an original '72-75? or can describe the differences?
Thanks.
Re: Square back alternator details - Housing [Re: Mattax] #2596732
12/25/18 02:14 PM
12/25/18 02:14 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have a '72 here, front case is dated 5th month & the rear case 2nd month.
Not sure of the application, so I'll include the numbers for you.
Front first;
Re: Square back alternator details - Housing [Re: Mattax] #2596733
12/25/18 02:15 PM
12/25/18 02:15 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Rear;
Re: Square back alternator details - Housing [Re: Mattax] #2597138
12/26/18 02:15 PM
12/26/18 02:15 PM
Phila. Pa.
Mattax Offline OP
Mattax  Offline OP
Phila. Pa.
Barry, Thanks!!
From the '74 parts book, it looked like the65 Amp alternators may have had functional difference.
Now looking at the '73 parts book, I'm only more puzzled as to whether the part number changes reflect a functional or appearence change.
3438 804 is a single pulley 41 amp alternator assembly.
Parts books shows that housing as p/n 3438 711
The alternator on my bench, although unfortunately blasted by a rebuilder has the same casting number on the housing. Date is obliterated.
But I found some photos on-line of another 41 amp alternator that shows in both the '73 and '74 parts book. Red tagged 3755404 eBay item number: 142665980358
Parts book shows different p/n for both front and rear housings.
Casting numbers are the same!
Here's what I see different externally.
Front (Drive end) housing
Recess for hex head of assembly screw in the mounting ear.
Unfortunately not enough of a view of the back to see what might be different.
