pink primer under plum crazy paint? #2596510
12/24/18 09:24 PM
12/24/18 09:24 PM
Massachusetts
N
NortheastMopar Offline OP
N
Massachusetts
Looking at the floor of our 70 challenger. appears to have a pink paint under the plum crazy. Was that the color of the primer they used or was it a rustproofing. I only see it inside under the paint on the floor. I also notice it on the side of the spare tire hold down in the trunk?
Re: pink primer under plum crazy paint? [Re: NortheastMopar] #2596523
12/24/18 09:40 PM
12/24/18 09:40 PM
Kirkland, Washington
Pacnorthcuda Offline
I'd sure like to see a pic of this!
Re: pink primer under plum crazy paint? [Re: NortheastMopar] #2596533
12/24/18 09:58 PM
12/24/18 09:58 PM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
that's yellow primer that's fading out
Re: pink primer under plum crazy paint? [Re: NortheastMopar] #2596562
12/24/18 11:13 PM
12/24/18 11:13 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I seem to recall some pinkish primer under the flaking FC7 70 cuda paint way back in 1977.
Re: pink primer under plum crazy paint? [Re: NortheastMopar] #2596566
12/24/18 11:35 PM
12/24/18 11:35 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IIRC a Plum Crazy factory paint job is applied over a gray primer base, and I believe the gray primer was shot over a red oxide finish, but that would be on the main outer body, the interior/floor areas would be in the dip finish primer (gray) prior to the vehicle in final paint...
so it's possible you might be seeing pink/FM3, assembly line workers would sometimes clean out their guns of the previous paint run by blowing out the color in what would become hidden areas later when the vehicle was in final assembly
Re: pink primer under plum crazy paint? [Re: DAYCLONA] #2597334
12/26/18 11:01 PM
12/26/18 11:01 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It depends on if it assembled / painted in LA or Hamtramck. LA used a darker gray dip primer and no red oxide.
Re: pink primer under plum crazy paint? [Re: Morty426] #2597494
12/27/18 11:24 AM
12/27/18 11:24 AM
Massachusetts
N
N
Massachusetts
My car was built in LA. Shipped to Texas. Found no build sheets. I understand LA cars did not get the build sheets left in them? I will try to get a clear picture of the paint today.
