Hi Guys _________ I have seen cars painted this way !
I even bought one painted this way , You would be suprised how it turns out !
( BUT ) Tremclad has little Hardner & NO silicone additive. So Paint reactions & fisheyes are a problem to be delt with. Also tremclad tends to fade & loose its shine due to sun-exposure.
If doing a Tremclad paint job ? Get enamel hardner & silicone additive. The hardener makes dry time quicker & keeps the shine , Even makes it shine more! Also the Tac Cloth is real good idea for removing dust.
Now You could get Spirts / Reducer to thin the paint . Gas will do the job too !
When done sanding , if painting inside? Wash the floor , walls & rafters down with a light mist of water from the garden hose. Let it drip...Go out & was the Car with warm water & dish soap... Even wash it twice. ( Warm day ) let it dry. As it dries You may see spots where the water is laying up. Ring out Your wash cloth & damp wipe it off. This will help with Drying time.
Then Put the Car inside & return the next day.
Pull the car out of the shop & Mask the car.
Wet only the Floor of the shop again. Pull the car back in . Shut the door....... Run over the surface with the Reducer / sprits . Use one cloth for wet & another Dry cloth for a dry wipe.( use lint free cloth ) Now car should be DRY.
Run a Tac cloth over the car. Your ready to paint.!!
NO sponge rollers> Only Fine rollers > Thin some paint , add some hardner & silicone additive & Test Your mix.. Pick a spot down low ( Like the Rocker area )Roll some paint on.
( STOP ) Let it dry for 30min & CHECK YOUR TEST AREA. IF ? all looks good ? Tac cloth the car again & mix the paint the same again & again as close as You can.
You can save the Roller You are using if You put it in a plastic bag & put it in the Freezer. This way the paint will not dry , unless left for days.
Good Luck with all.
An Automotive ( paint , hardener , reducer & silicone additive + tac cloth )can run as cheap as 200.00_get a spray gun for under 30.00 & find a air supply.
Do it yourself & for 300.00 You will be happy & learn a little. LOL
Bill >>>>>>> P.s. Grandmas_Grape cost about 300.00 to paint.
![](http://img.villagephotos.com/p/2004-6/760609/DSCF0298.JPG)
