Custom push rods
#2595690
12/23/18 02:51 AM
12/23/18 02:51 AM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I remember reading here that there was a company that would send you a checking push rod to measure then order from them. I might need to get some new push rods and still haven't made up my mind yet. I made my last set from a kit and they turned out pretty good but some store bought ones would save me a bunch of work. Thanks Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Custom push rods
[Re: max_maniac]
#2595694
12/23/18 03:16 AM
12/23/18 03:16 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Jegs sells some nice size checking pushrods. I stocked up earlier in the year
[Re: fourgearsavoy]
#2595705
12/23/18 05:07 AM
12/23/18 05:07 AM
Posts: 43,259 Bend,OR USA
Cab_Burge
Do you need one for a B or RB motor with solid lifter or hydraulics and do you need ball and cup or ball and ball? Last thing w=hat size are the ends you need on each end, 1/4, 5/16 or 3/8?
[Re: dthemi]
#2595765
12/23/18 01:26 PM
12/23/18 01:26 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
You can cut an old one in two and thread the cut ends, put a short piece of threaded rod between and a couple jam nuts. Thats what I did, and sent both of them to Smith Brothers. They returned them with the new pushrods. I didnt want to take a chance on my measurements. Nice guys to work with.
[Re: fourgearsavoy]
#2596017
12/23/18 11:06 PM
12/23/18 11:06 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Smith Brothers Pushrods is the only place I will get mine. I just ordered a very custom set for a 428 Cobra Jet. Talk to Eric, good guy.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#2596129
12/24/18 02:38 AM
12/24/18 02:38 AM
Cab_Burge
Smith Brothers Pushrods is the only place I will get mine. I just ordered a very custom set for a 428 Cobra Jet. Talk to Eric, good guy. Smith Bros. screwed me once around 8 years ago when they where here in Bend, I have not used them since then and won't again I use Mantons now and will for a long time to come, way better quality and prices also
[Re: Cab_Burge]
#2596845
12/25/18 06:03 PM
12/25/18 06:03 PM
Posts: 610 long time lurker, short time p...
PorkyPig
Smith Brothers Pushrods is the only place I will get mine. I just ordered a very custom set for a 428 Cobra Jet. Talk to Eric, good guy. Smith Bros. screwed me once around 8 years ago when they where here in Bend, I have not used them since then and won't again I use Mantons now and will for a long time to come, way better quality and prices also Can you please explain "screwed me"? They always got my orders right so this sounds really odd.
[Re: PorkyPig]
#2596861
12/25/18 06:34 PM
12/25/18 06:34 PM
Cab_Burge
I paid for 3/8x.120 wall ball and cup and when one of them broke in half on the dyno testing, it broke due to a defect in the material I was told by Piere that they where .083 wall, not the .120 wall I ordered and paid him for When the bad one broke at around 5200 RPM on the engine dyno it took out the one beside it and the upper half ended up gouging the cam lobe and lifter bushing after the Crower solid roller lifter was spit out, which cause the link bar to break the top of that set of lifters off They replace the two bad pushrods but did not offer to help fix the cam and replace the pair of broken lifters I ordered a set of Manton .120 wall and put the motor back on the dyno with the Smith Bros. and made three pulls and then switch the pushrods to the Manton set with no other changes, those pushrods made 8 HP more and raised the peak HP RPM by 300 RPM This forum is for all of us to try and help each other, I hope this does that
[Re: Cab_Burge]
#2598196
12/28/18 11:45 PM
12/28/18 11:45 PM
RapidRobert
the hardware store has these thin (5/16?) shafts that are threaded on each end (LH on one end), not sure what they are for, didn't pay attention & from a bent junk pushrod, I cut & JB welded a ball on one end & a threaded shaft with 2 nuts to lock it solid at a particular height into the other. had more range than the tailor made ones (& cheaper) plus the satisfaction of doing it your self.
