BB HP manifold flow
#2595041
12/21/18 01:22 PM
12/21/18 01:22 PM
Posts: 1,386 Houston,Tx.
Lee446
Houston,Tx.
In all the years that I have been messing with Mopars, I always wondered something and I have never seen a post on it. If you look at the HP 383/440 exhaust manifolds, there is really a huge difference between the drivers side and the passenger side. No kidding? right! The drivers side looks like it ought to be a great flowing manifold, while the passenger side looks to be much more restrictive. I have no idea how to do a flow test, nor do I have the equipment, but I have to wonder, with all the technology that is available, and with so much research done by the F.A.S.T racers, if anyone ever tested and got numbers that show whether they flowed close or if they had a large disparity. Anybody know?
Re: BB HP manifold flow
[Re: ZIPPY]
#2595087
12/21/18 02:59 PM
12/21/18 02:59 PM
Lee446
Houston,Tx.
Yeah Zippy, I read that the other day and it got me to thinking about it. I am not disputing their findings, but it seems hard to believe that Ma Mopar would have spent all that money on developing HP manifolds for a lousy 6-8 horsepower, but stranger things have happened! I was finishing up a 440 build and getting it ready to break in on a friends engine stand, and was having trouble with the drivers side manifold hitting the fabricated valve covers high up, not so on the passenger side which does not swoop up high. Anyway, that reminded me that I always wondered how much difference in flow their might be between sides and how that would affect performance. If I had a dyno, I'd be dangerous, as I would see if I could reverse mount a drivers side manifold on the pass side and see if it made a difference. Kind of on the subject of manifolds, I remember reading an article in the 70's about how when testing a new LS 6 454, they picked up almost 100 hp using headers vs the restrictive factory manifolds. I always thought that that Chrysler was way ahead of the others in both exhaust and intake manifold design. I wonder if any of the engineers that did that development are still around to ask, I bet that would be interesting!
[Re: Lee446]
#2595624
12/22/18 09:12 PM
12/22/18 09:12 PM
Posts: 14,531 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
IMO, this falls right into the “it depends” category.
The test in the link has the hp manifolds making 4hp over the logs(272 vs 276), and 3 step headers making 15hp(272 vs 287)over the logs.
A member posted some numbers from his TF/6bbl topped stroker a couple months ago where the manifolds cost the motor 90hp.
My suspicion is that on something a like a 600+hp 500”+ FAST type build(as opposed to a 275hp <8:1 440) there would be more than a 4hp difference between the HP pieces and the logs....... but having not done that test myself, I can’t say for sure.
[Re: topside]
#2595636
12/22/18 09:56 PM
12/22/18 09:56 PM
Posts: 4,333 Prospect, PA
BSB67
Prospect, PA
I'd have thought by now that someone would've tested a pair on a flowbench to at least get a number. Maybe even a comparison between stock and extrude-honed. I guess you could put it on a flow bench and get some comparative numbers. But what the exhaust does is so much different than an intake, and what is important is different. How and what makes the exhaust help the intake (I.e. the only part that makes power) is different. The exhaust is under hundreds psi positive pressure pushing the exhaust out, verses 13 psi of vacuum. I wouldnt be surprised if a manifold port flows about as good as a 1 3/4" header tube, but clearly the long tube header helps the intake a lot more and will make a bunch more power.
[Re: BSB67]
#2595683
12/23/18 02:22 AM
12/23/18 02:22 AM
Lee446
Houston,Tx.
Andy makes the point that they did not have sophisticated computer modeling then, but they did have dyno's and I am sure that they must have used them to confirm the improvements as they developed the HP manifolds. Like I said, no way Ma spent big bucks and got a couple of hp. If that were the case, they would have canceled the project and stuck with the old log style manifolds. I sure would like to see the results of their testing and would like to know the flow difference between the sides. You have to wonder, say the pass side flows 10-15% less than the drivers side, what would the effect on performance be besides the obvious restriction, would'nt it also cause reversion and mixture contamination?
