Page 4 of 5 1 2 3 4 5
Re: HEMI oil consumption? [Re: Cab_Burge] #2594144
12/19/18 08:55 AM
12/19/18 08:55 AM
Tennessee
Hemi ragtop Offline OP
Tennessee
Originally Posted By Cab_Burge
I was told by a very competent Hemi engine builder, racer and machinest to run no more than .0010 on the intakes and no more than .002125 on the exhaust on a new pump gas street motor build up
Thanks Cab, that goes along with what I’ve been reading.
Re: HEMI oil consumption? [Re: Hemi ragtop] #2594187
12/19/18 12:26 PM
12/19/18 12:26 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Go with the Edelbrocks
2011 Drag Pak Challenger
Re: HEMI oil consumption? [Re: Hemi ragtop] #2594232
12/19/18 02:05 PM
12/19/18 02:05 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I ran across this in my travels/research. Maybe it will help you...hopefully it doesn't add to the confusion.
Re: HEMI oil consumption? [Re: Hemi ragtop] #2594235
12/19/18 02:08 PM
12/19/18 02:08 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I know if I were deciding on what heads to use on my hemi, to put in my 4175lb strictly street car with 3.54’s and OD unit......... really big flow numbers would be right at the top of my list of “must haves”.
You neeeeeeeeeeed 400+cfm of flow available when you’re racing along at 2100rpm.
Re: HEMI oil consumption? [Re: rickseeman] #2594238
12/19/18 02:09 PM
12/19/18 02:09 PM
So. Burlington, Vt.
So. Burlington, Vt.
That’s the answer he’s looking for.
Re: HEMI oil consumption? [Re: Hemi ragtop] #2594255
12/19/18 02:48 PM
12/19/18 02:48 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
Ask and ye shall receive
Re: HEMI oil consumption? [Re: fast68plymouth] #2594272
12/19/18 03:14 PM
12/19/18 03:14 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
haha
Re: HEMI oil consumption? [Re: blowndart] #2594388
12/19/18 07:37 PM
12/19/18 07:37 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Dang Dwayne, is that a bit of Yankee Christmas sarcasm!??!
My Mopar aluminum Hemi heads were CNC ported by Modern and by the sheet flowed 446 cfm on the intake, 261 on exhaust. Theoretically, they could support 1000 hp. Looking back, I could have met my goals with less flow and made the same hp at a lower rpm. I quit racing several years ago, so it's about a 99% street car now. Like most of us, sometimes you get carried away looking for max hp. If I were in your shoes, knowing what I know now, I would send them to Dwayne and have him port them to a level that is commensurate with your goals and use. Nothing wrong with the Mopar head, if your guides are good, porting and a good valve job and you are in business. If you just want the edelbrocks, by all means, get them. I sure never discourage anyone from spending money! I know I am good at it! Let us know what you do, this has been an interesting post!
Re: HEMI oil consumption? [Re: Hemi ragtop] #2594422
12/19/18 08:36 PM
12/19/18 08:36 PM
So. Burlington, Vt.
So. Burlington, Vt.
Huh?whaaa??
Noooooo........ he wants to buy some new Edelbrock Victor heads(the series of heads they offer for race engines) for his strictly street car......... and I’m just being agreeable.
It’s his car, his build, his money...... his decision.
If those are what he wants....... he should just buy ‘em.
It’s certainly easier than boxing up your old stuff, shipping it out...... waiting for it to come back, etc.
One call to Summit and a couple days later...... boom..... new heads are at your door.
Re: HEMI oil consumption? [Re: Hemi ragtop] #2594450
12/19/18 09:51 PM
12/19/18 09:51 PM
New York
64 Sportfury Offline
New York
"If I were in your shoes, knowing what I know now, I would send them to Dwayne and have him port them to a level that is commensurate with your goals and use. Nothing wrong with the Mopar head, if your guides are good, porting and a good valve job and you are in business."
This is exactly what I did a few years ago when it was time to re do my 472 crate Hemi. Dwayne did his magic based on my needs for a strong street only cruiser (64 Sport Fury Conv, 4250 lbs. 5 spd). He easily squeezed 363 cfm @ .550 lift out of my iron heads and spec'ed a very satisfying solid lifter cam and EDM lifters for a very nice price. There is something special about having heads and cam customized to your purpose build. Good luck.
Ernesto
Re: HEMI oil consumption? [Re: fast68plymouth] #2594506
12/20/18 12:08 AM
12/20/18 12:08 AM
Tennessee
Tennessee
Really? Are you being serious? I value your opinion very much. I know that at cruising speed the air flow does’nt matter. But last year at our “Moparts” Mike Bucle asked me to race his HEMI Coronet just for fun. I would like to take him up on it next year!
Re: HEMI oil consumption? [Re: 64 Sportfury] #2594510
12/20/18 12:15 AM
12/20/18 12:15 AM
Tennessee
Tennessee
Dewain, I have plenty of time. I am not opposed to sending you my heads, or having you do both the heads and new cam if you think I need it.’
I am posting to get advice, and I value yours.
After all the work, expense and time spent, I would like to improve what I have. At 63 years of age, I would like to put this engine together and enjoy it from now on.
I have waited nearly all my life to have a HEMI convertible that I could drive anywhere. So, what do you suggest?
Re: HEMI oil consumption? [Re: Hemi ragtop] #2594611
12/20/18 10:08 AM
12/20/18 10:08 AM
A727Tflite Online content
A727Tflite  Online Content
Who is Dewain?
Re: HEMI oil consumption? [Re: ZIPPY] #2594629
12/20/18 12:05 PM
12/20/18 12:05 PM
an8sec70cuda Offline
Pretty sure this may be the flow sheet from my heads I've posted here a few times. They are the normal MP aluminum street hemi heads CNC ported by MCH.
Make well over 800 hp on pump gas on my 572" hemi.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: HEMI oil consumption? [Re: Hemi ragtop] #2594633
12/20/18 12:19 PM
12/20/18 12:19 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The OP's original question seems like a simple one to answer. He wants the best performing head. And although he didn't mention it, he probably wouldn't be opposed to the least cash outlay to get there.
I got the same flow chart that Zippy posted with my heads that MCH did a few years ago. It would be easy to price that port job today from them or from Dwayne.
Then somebody surely has a flow chart for the new Eddies. And pricing them is no problem.
Comparing flow to dollars should make the right choice clear.
And if it matters, the ported MPs on my 540 have great street manners. 250* cam, Indy dual plane intake and a Thumper Dominator top it off. It starts right up, has a steady idle, and drives with no bad habits. My point is that the 400ish flow is not a problem on the street.
I personally think that it is important to have a Hemi (even a Hemi that doesn't see much racing) to run like a Hemi is expected to run. Nothing is worse that to pull up beside a brand Xer and not be able leave him in the dust. The few times that I have had a race, my Hemi had upheld the Hemi tradition. That is worth the price of admission.
So, I say 'go for it', OP. Help that Hemi run like a Hemi! And when you can do it for a bit less money one way rather than another, and have good street manners, too....what's not to love?
Master, again and still
Re: HEMI oil consumption? [Re: Hemi ragtop] #2594656
12/20/18 01:09 PM
12/20/18 01:09 PM
So. Burlington, Vt.
So. Burlington, Vt.
I’m not really lobbying for the job......... and if I ported them they wouldn’t flow anywhere near as much as the flow sheet posted.
Since Dave has had such good results with his CNC ported heads from Modern on his mild combo, that’s probably the best bang for the buck for reusing the current heads.
Or sell em and buy the Victors.
The Victors flow right at about 400ootb.
Re: HEMI oil consumption? [Re: DaveRS23] #2594775
12/20/18 07:13 PM
12/20/18 07:13 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
iagree
Once a guy has that beast, I feel it had better be capable of running respectably hard, staying in context with the rest of the vehicle.
Rich H.
Esse Quam Videri
Re: HEMI oil consumption? [Re: an8sec70cuda] #2594818
12/20/18 09:47 PM
12/20/18 09:47 PM
Tennessee
Tennessee
Yes that helps, thanks! So did it effect drivability?
Re: HEMI oil consumption? [Re: DaveRS23] #2594819
12/20/18 09:49 PM
12/20/18 09:49 PM
Tennessee
Tennessee
That’s the kink of info that I was looking for, thanks!
Re: HEMI oil consumption? [Re: fast68plymouth] #2594820
12/20/18 09:51 PM
12/20/18 09:51 PM
Tennessee
Tennessee
Thanks Dewayne!
