Rocker ratio questions
#2592761
12/16/18 02:07 PM
12/16/18 02:07 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
What are the benefits of going to a 1.6 or 1.7 rocker ratio versus just getting the correct cam to start with. Is there some sort of mechanical advantage with a higher ratio rocker? It seems that hardly anyone runs a 1.5 rocker anymore judging from some of the builds I've seen here. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Rocker ratio questions
[Re: fourgearsavoy]
#2592829
12/16/18 04:19 PM
12/16/18 04:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The only way to know for sure if you could use a bigger ratio is to test it by tightening the intake lash some.. I run a tighter lash on my engines.. thats cheaper than buying new intake rockers.. I have never seen the engine make more power changing the exhaust ratio unless its WAY off
[Re: MR_P_BODY]
#2592843
12/16/18 04:39 PM
12/16/18 04:39 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I have never seen the engine make more power changing the exhaust ratio unless its WAY off I see this consistently from guys that have a lot of experience, so I trust it to be true. But it begs the question: why does every split pattern cam I’ve ever looked at feature more lift and duration on the exhaust side of the equation? I’m planning on going from my current 1.5 to 1.6 rockers this winter for the following reason: last year I had my heads ported and prepped, and the flow sheet says they continue offering more flow well past .650 lift while my current cam offers net .555 lift. My theory is that in my case more lift and effective ramp speed should benefit me (??). The rest of the combo (carb/intake/exhaust) should also adequately support more flow. Hopefully we’ll see if I’m correct.
[Re: StealthWedge67]
#2592850
12/16/18 04:50 PM
12/16/18 04:50 PM
MR_P_BODY
I have never seen the engine make more power changing the exhaust ratio unless its WAY off I see this consistently from guys that have a lot of experience, so I trust it to be true. But it begs the question: why does every split pattern cam I’ve ever looked at feature more lift and duration on the exhaust side of the equation? I’m planning on going from my current 1.5 to 1.6 rockers this winter for the following reason: last year I had my heads ported and prepped, and the flow sheet says they continue offering more flow well past .650 lift while my current cam offers net .555 lift. My theory is that in my case more lift and effective ramp speed should benefit me (??). The rest of the combo (carb/intake/exhaust) should also adequately support more flow. Hopefully we’ll see if I’m correct. My W-9 heads were known for having good exhaust flow and I had the rockers to change over so I did.. the car didnt show any change with just the exhaust.. all I can say is test it and see
[Re: fourgearsavoy]
#2592853
12/16/18 04:56 PM
12/16/18 04:56 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
First, most split pattern cams I have used may have more exhaust duration than intake, but always have less lift. Second, if your heads can handle more flow than what you are creating now, than a 1.6 rocker will help. Higher ratio rockers not only give you more lift, they also give you more duration at valve, without creating more motion from lifter or pushrod. Most "Other" brand engines, and even later Magnum engines all use ratios higher than 1.5 these days on production engines. So there is something to be said for higher ratios. My last 500 cid build had Indy -1's with Jesel 1.7 rockers. The cam I chose was based on a BBC grind, that also used factory 1.7 rocker ratio.
[Re: fourgearsavoy]
#2592870
12/16/18 05:55 PM
12/16/18 05:55 PM
Posts: 31,038 Oregon
AndyF
I spent a bunch of time and money last year testing rocker arm ratios. The answer is that your engine only needs what it needs. Adding more rocker arm ratio or more duration to the cam doesn't add any power if the engine doesn't need it. Based on my testing I'm pretty confident that a person can build a 700 or 800 hp BB Mopar with 1.50 shaft mount rocker arms and cam lobes right out of the catalog. https://www.hotrod.com/articles/trying-find-extra-power-rocker-arm-testing/
[Re: fast68plymouth]
#2592910
12/16/18 07:54 PM
12/16/18 07:54 PM
fourgearsavoy
Rittman Ohio
This is definitely one of those “ it depends” items. My flat tappet cam lobes are worn and I'm replacing the cam with a hydraulic roller. There aren't many off the shelf grinds available and before I either get one custom ground or buy off the shelf I wan't to know if I should add new rockers to the build. My current rockers are some good old 1.5 Isky's with the premium service from RAS. They are working perfect on my old cam but will they be good with my new cam? My combo 493 10.9 compression Wiseco Pro-Tru flattops Indy EZ heads std. port with some clean-up and valve job by Nick Wilson. They flow 319 at 600. My car is a street/strip deal that runs 10.91 124.6 at 3640# I wouldn't mind a 10.50 time slip in my glovebox. I think I can get more out of my combo with just a valvetrain change. My old cam was a Comp XTQ series 292-312 grind. Thanks Gus
[Re: fourgearsavoy]
#2592996
12/16/18 11:39 PM
12/16/18 11:39 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
IMO, your rockers are fine for what you’re looking to do.
Hyd roller vs solid flat tappet for an ET improvement? I guess we’ll see how that works out for you.
[Re: fourgearsavoy]
#2592999
12/16/18 11:52 PM
12/16/18 11:52 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
I am not saying to run a hydro roller, BUT, I went from a solid FT to one in my 512, used one from Hughes, 9.7to one, 4050lb street car, solid cam was 248@.050 116 mph 12.03 2200 DA Hyd roller 255,258 @ .050 121 11.33 mph 1750 DA Short shifting 5500, easy pass but I used the expensive High RPM Morel. Still need to do some track tuning. also had better rear tires for the faster pass
[Re: fourgearsavoy]
#2593006
12/17/18 12:14 AM
12/17/18 12:14 AM
CSK
Pattison Texas
Your Rockers are great, BUT I also went from 1.5, to 1.6, not saying it had anything to do with more power
[Re: CSK]
#2593009
12/17/18 12:26 AM
12/17/18 12:26 AM
fourgearsavoy
Rittman Ohio
Well I wish I didn't have to do this deal at all but my old cam gave up after about 5 years and I don't want to go flat again. I checked on Morel rollers and they were over a grand and that's just a little much for my build budget. I'm probably going with a Howards cam and lifters they have better reviews than Comp Cams do. Gus
[Re: fourgearsavoy]
#2593012
12/17/18 12:29 AM
12/17/18 12:29 AM
CSK
Pattison Texas
Morel has 2 versions, I think the Howards are the less cost Morel from what I have been told
[Re: fourgearsavoy]
#2593096
12/17/18 12:01 PM
12/17/18 12:01 PM
Posts: 4,206 New York
polyspheric
New York
Considering the RT weight, it would be nice to fit a 3/4" pushrod in there for the extra spring load...
Boffin Emeritus
[Re: fourgearsavoy]
#2593143
12/17/18 02:16 PM
12/17/18 02:16 PM
Posts: 10,005 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Maybe I am just too old school, but I don't see the advantage of going HR versus FT solid cam. A solid cam may be a tic noiser, but a few thou tighter on lash helps. plus they are cheaper by a bunch, and allow you to see any problem early on in the valvetrain. Valve lash changed a bit? OK, what caused that? Something is wearing. Easy to find. HR adds two areas for failure; the roller wheels, and the hydraulics.
[Re: gregsdart]
#2593153
12/17/18 02:39 PM
12/17/18 02:39 PM
CSK
Pattison Texas
Maybe I am just too old school, but I don't see the advantage of going HR versus FT solid cam. A solid cam may be a tic noiser, but a few thou tighter on lash helps. plus they are cheaper by a bunch, and allow you to see any problem early on in the valvetrain. Valve lash changed a bit? OK, what caused that? Something is wearing. Easy to find. HR adds two areas for failure; the roller wheels, and the hydraulics. I agreed with everything you just said, until the tool steel solid FT lifters started eating up my camshaft lobes & I had to go back through the engine, I just hope the hydro roller holds up, so far over 2k miles & all is good.
