how deep a hole should 4 speed crank be #2592769
12/16/18 02:33 PM
12/16/18 02:33 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
b body 383 eng.thanks
Re: how deep a hole should 4 speed crank be [Re: moparpro] #2592778
12/16/18 02:48 PM
12/16/18 02:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
body and engine irrelevant
From Brewer's
Don't be the exception.
Re: how deep a hole should 4 speed crank be [Re: moparpro] #2592962
12/16/18 10:11 PM
12/16/18 10:11 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Appears to be missing the dimension for the depth of the .938-sized hole...the way I'm reading it is there's a step between .938 and .875, right?
I guess one could just measure the width of the pilot bearing for that dimension.
Re: how deep a hole should 4 speed crank be [Re: moparpro] #2592967
12/16/18 10:24 PM
12/16/18 10:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Being honest, I'd just drill the 0.875" hole and use the later Dakota roller bearing and not the older bushing. Assuming you have the later larger crank register.
Re: how deep a hole should 4 speed crank be [Re: topside] #2593090
12/17/18 11:47 AM
12/17/18 11:47 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
The depth of the step is 8.125" from the face of the bell, .875 bushing length.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: how deep a hole should 4 speed crank be [Re: moparpro] #2595162
12/21/18 06:48 PM
12/21/18 06:48 PM
Chicago
PurpleBeeper Offline
Chicago
Here's what I'm seeing from the blueprint:
a. Hole depth = minimum 2.225" from outer ring on crank flange (go slightly deeper)
b. Hole diameter is 0.938"
c. Trans input shaft diameter (& crank bushing I.D.) = 0.875"
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: how deep a hole should 4 speed crank be [Re: moparpro] #2595304
12/22/18 12:09 AM
12/22/18 12:09 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I measure from the face where the bushing is pressed in and I get 1.750 depth
