Re: Eagle Head [Re: ric3xrt] #2600375
01/02/19 11:23 AM
01/02/19 11:23 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
Ray if you get the chance this year try a 2.125 X 7MM intake valve....I think you'll like the results...I'm going to try a putting a vein in the next set of Eagles I do.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Eagle Head [Re: ric3xrt] #2600794
01/03/19 02:17 AM
01/03/19 02:17 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
If I was going to go thru that trouble I would just buy Thitek heads. The equality of the head is just so good
Re: Eagle Head [Re: ric3xrt] #2600934
01/03/19 01:12 PM
01/03/19 01:12 PM
raleigh, NC
mcmopar1 Offline
mcmopar1  Offline
raleigh, NC
How pricey are those heads, look very impressive!
Re: Eagle Head [Re: mcmopar1] #2600992
01/03/19 02:57 PM
01/03/19 02:57 PM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
ThiTex ? base price is about $2500
Re: Eagle Head [Re: sixpackgut] #2600994
01/03/19 03:04 PM
01/03/19 03:04 PM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
No doubt Thitex's are cream of the crop, but most entry level G3 hemi people aren't going to spend that kind of coin, I started this thread to get some Information out there.
Re: Eagle Head [Re: ric3xrt] #2601098
01/03/19 06:51 PM
01/03/19 06:51 PM
Kalispell Mt.
HotRodDave Online content
HotRodDave  Online Content
Kalispell Mt.
I like to polish the entire valve head on the exhaust, it reduces the surface area and increases reflectivity and so keeps the heat retained in the valve down, at least thats my theory.
To do it I just chuck the valve in the drill press and run it on a slower speed, careful not to marr it up and dont grab it where the guide slides at all, then depending on surface texture of valve, start around 220 grit and work my way finer till around 2000 grit and I can see my face reflecting in it.
Re: Eagle Head [Re: ric3xrt] #2601322
01/04/19 01:42 AM
01/04/19 01:42 AM
raleigh, NC
mcmopar1 Offline
mcmopar1  Offline
raleigh, NC
2500, not as bad as I thought!
Re: Eagle Head [Re: ric3xrt] #2601328
01/04/19 02:04 AM
01/04/19 02:04 AM
Australia
aus370 Offline
aus370  Offline
Australia
I love all the in depth information on this forum . I'm gonna have a go at porting my Apache heads ... i'll probably loose 30 hp ! .
Re: Eagle Head [Re: aus370] #2602982
01/07/19 02:55 PM
01/07/19 02:55 PM
dogdays Offline
dogdays  Offline
It's a V*A*N*E
Blood doesn't flow through it. It does, through a vein.
R.
Re: Eagle Head [Re: ric3xrt] #2603043
01/07/19 05:28 PM
01/07/19 05:28 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
So, rolling the short side radius angle towards the intake side of the head has proved to be one of the most effective strategies? Allows the air to start turning around the short side radius earlier correct?
Anybody try welding some taller spring seats in to raise the port roof?
Adriel Paradise
Substation Design Engineer III
Re: Eagle Head [Re: ric3xrt] #2603326
01/08/19 09:23 AM
01/08/19 09:23 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
Originally Posted By dogdays
It's a V*A*N*E
R.
LL"1 teka ttha up with car tcerrect time next mez nead to speel eht word vien
Re: Eagle Head [Re: Adrielp] #2603328
01/08/19 09:26 AM
01/08/19 09:26 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
not sure that putting in that type of work is worth it with the eagle head.
Re: Eagle Head [Re: ric3xrt] #2603537
01/08/19 05:37 PM
01/08/19 05:37 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
Anybody have any cutaways of the BGE cylinder heads? I'm curious of the thin areas that this cylinder may have compared to the eagle cylinder head.
Adriel Paradise
Re: Eagle Head [Re: sixpackgut] #2617572
02/05/19 11:00 PM
02/05/19 11:00 PM
Australia
L4staero Offline
L4staero  Offline
Australia
I have not spent time comparing a sharp vein to one that is wider like in the photo but it seems to get the same results.
There is another thing on the eagles that helps. Machine cut on chamber on intake valve side. None of the Apache heads Ive seen has it
Ray can you elaborate on this cut a little?
Re: Eagle Head [Re: L4staero] #2620167
02/12/19 07:07 AM
02/12/19 07:07 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
He's referring to the factory relief cut in the chamber
Re: Eagle Head [Re: Adrielp] #2620170
02/12/19 07:15 AM
02/12/19 07:15 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
I haven't forgot to get to this, just haven't had the time to cut up a head, the last one I did cut open was Hellcat head(same ports as the BGE)I sent off to a friend.
