A look at Classic Industries 71-74 B-body A-pillar molding #2591591
12/14/18 12:37 AM
12/14/18 12:37 AM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Hi all,
I drove up to Classics Industries warehouse in Huntington Beach, CA yesterday to look at their A-pillar moldings for my '71 Satellite. Just thought I'd let everyone know my impressions. The blurb on CI's website says they are made from injection molded ABS, and are intended to fit 1971-1974. I also found out they are made by Southwest Reproductions. Actually, I was pretty disappointed in them, overall:
- The finish is very glossy black - yes, I know it can be painted.
- The detail is not very sharp. Look at the surface "grain" close up.
- My originals have a very defined (sharp-ish) edge where the bends are (running up and down each piece). You can't see it very well in the pics, but their edges are rounded, not sharp at all.
- Probably the worst part is where they meet the dash. It appears that there would have to be some significant trimming involved, at least for the '71 dash, and even then I'm not sure they would work. Perhaps they were made this way so they can be used on other years?
In any case, submitted for your approval:
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: Fab64] #2591617
12/14/18 01:46 AM
12/14/18 01:46 AM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
well.... they are not completely useless , can always serve as a bad example
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: Fab64] #2591659
12/14/18 04:15 AM
12/14/18 04:15 AM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
I think you are being over critical. Your moldings are worn and 48 years old. If you need to do a little trimming at the dash pad you can make them fit perfectly. The edges look like what I remember in my parents 72 Sebring Plus. Before you pass judgement maybe someone else has pics of originals that are not as bad as yours.
Real Men shift for themselves
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: Fab64] #2591665
12/14/18 04:31 AM
12/14/18 04:31 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
That doesn't look that good to me. I wouldn't want to run them in a car I owned.
Sheldon
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: Fab64] #2591697
12/14/18 10:36 AM
12/14/18 10:36 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I can only see one of your pictures, but it looks more like vacuum formed than molded. Looks like crap. I'd take them back.
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: Fab64] #2591762
12/14/18 12:41 PM
12/14/18 12:41 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
they are pretty much similars than the ACCUFORM ones I got... but slightly diff grain pattern and STILL a POS. Shamely my pillar panels are 1000 miles away from home at this moment so I can't compare them or post them to show
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: Fab64] #2591776
12/14/18 12:56 PM
12/14/18 12:56 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would probably never notice any difference once they were installed.
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: Fab64] #2591795
12/14/18 01:33 PM
12/14/18 01:33 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
I ordered some years ago and sent them back from numerous vendors - Fit was horrible
My factory 71 Bee , a lot of the original white interior plastic had severe chalking and discoloration
Rear sail panels are almost impossible to find in decent shape
Anyways I found some really nice factory tan pillar moldings at Mopars in the Park for $60 last year - The grain was perfect and zero chalking
SEM Super White , a few light coats after using there cleaning product , man they look brand new , and of course nothing beats factory for fit
Now those Non SE 1971 Rear Sail Panels , still looking for something I can SEM
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: Fab64] #2591875
12/14/18 03:11 PM
12/14/18 03:11 PM
New Jersey
Dante Offline
Dante  Offline
New Jersey
Hate to be the bearer of bad news...but those the NOT injection molded.
Those are the Accuform pillar posts.
Nobody if making injection molded pillars.
Dante's Mopar Parts
One of the countries largest Interior Dealer, e-mail for a discounted price quote.
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: Fab64] #2592065
12/14/18 09:14 PM
12/14/18 09:14 PM
Maryland
MoparMike1974 Offline
Maryland
First glance and I thought they are vacuum formed parts as well. If thats the case they are cheap flimsy parts.
Im finding that many parts from Classic dont fit well at all. Im assembling my car and having issues with just about every part I try to put on.
Door handles -One side was great. Other side the stud is not centered correctly so the gasket doesnt fit. Also the pushbutton rattles like crazy.
Dash pad -Studs do not line up. 3 were only slightly off but one was about an 1/8" off. Had to use the die grinder and make it fit.
Defrost vent -Did not fit at all. Had to die grind the large hole and the holes for the studs. Thought the problem was my powdercoated dash but stock vents fit fine.
Door locks -crimp on stainless bezels were crap. Had to tap the down with a screwdriver so it would sit in far enough to get the clip on.
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: Fab64] #2592197
12/15/18 04:46 AM
12/15/18 04:46 AM
None
71rm23 Offline
71rm23  Offline
None
Take your originals clean and repaint them.....Done
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: 71rm23] #2592204
12/15/18 05:35 AM
12/15/18 05:35 AM
RUNCHARGER Offline
RUNCHARGER  Offline
Trouble is, it can be hard to find usable originals.
Sheldon
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: Fab64] #2592245
12/15/18 11:09 AM
12/15/18 11:09 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
decent ebay green pillars
search on for sale section here and other boards
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: Fab64] #2592287
12/15/18 01:09 PM
12/15/18 01:09 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
1971-1974 B
What year did they change from double screw , like the ones in nacho eBay listing
My 71 Bee had double screw
To the single screw a pillar moldings ?
Siberian Huskies
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: DaytonaTurbo] #2592296
12/15/18 01:20 PM
12/15/18 01:20 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
For a 100 point show car they wont work.
However they look better than those originals posted. shruggy
Not to mention they might be the only option, once the originals go south, if a person even has any that are usable.
I have mechanical Aptitude.
I can screw up anything.
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: NachoRT74] #2592303
12/15/18 01:38 PM
12/15/18 01:38 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
And the CI ones look like crap compared to the green Ebay ones as well. It's not a case of the OP's covers being old or worn. It's a case of CI's stuff being crap. Which is sad because it takes no more effort to do it right as it did to do it wrong.
Don't be the exception.
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: Fab64] #2592351
12/15/18 02:51 PM
12/15/18 02:51 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Very similar to the late B mouldings, same things happen to them, get chalky and brittle AND harder to find, along with the large rear panels.
B's younger siblings have the same issues, and nobody's willing to repop ANYTHING for the 75-79
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: bee1971] #2592386
12/15/18 03:25 PM
12/15/18 03:25 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Originally Posted By bee1971
1971-1974 B
Looking at my 71 Charger SE SPD 901 has the two screw ones, and my 71 RR SPD 605 had one. Mid year??
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: T2R9] #2592396
12/15/18 03:49 PM
12/15/18 03:49 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
1971-1974 B
My Satellite build date is 6-8-1971, and it has one screw.
Re: A look at Classic Industries 71-74 B-body A-pillar molding [Re: Fab64] #2592409
12/15/18 04:16 PM
12/15/18 04:16 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I just doubled checked and mine was 608 too not 605.
