Roll Cage requirements #2590081
12/10/18 09:42 PM
12/10/18 09:42 PM
Carson City, Nevada
Biginchmopar Offline OP
Carson City, Nevada
Simple question, stock firewall, stock floor, what is the requirement to run 7.50's?
I know a simple roll cage is good to 8.50 and I'm all about being safe but what if the car runs low 8's?
I will be building my cage out of Chrome Moly.
Thanks!
Re: Roll Cage requirements [Re: Biginchmopar] #2590095
12/10/18 10:05 PM
12/10/18 10:05 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Contact SFI rule specs for 25.5 D cert. Your wallet will be $38 lighter.
Doug
Re: Roll Cage requirements [Re: Biginchmopar] #2590096
12/10/18 10:06 PM
12/10/18 10:06 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
It takes more than a simple cage including a funny car cage. Best get the SFI spec then there's no doubt you have correct info.
Re: Roll Cage requirements [Re: Biginchmopar] #2590182
12/11/18 01:16 AM
12/11/18 01:16 AM
Funny car type cage is required to go from the 8.50 certs to 7.50. My C.M. tube chassis Cuda needs that done to go faster next year, hopefully luck It was built a lot of years ago and the funny car cage wasn't required back then, it is now whiney
Re: Roll Cage requirements [Re: Biginchmopar] #2590417
12/11/18 03:34 PM
12/11/18 03:34 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
8.50 to 7.50 unibody with stock floor/firewall goes from a simple sportsman cert to the SFI 25.5D for 3600# max. Funny car cage, additional tubing in the floor and some things installed differently. Depending on how they were built, I've seen 8.50 cars that needed to be torn apart and redone to get them right for the 25.5. Wasn't as simple as adding bars. On a car going into the 8s, I would go on and make it legal for 25.5.
Re: Roll Cage requirements [Re: Biginchmopar] #2590984
12/12/18 07:01 PM
12/12/18 07:01 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
We went with a C.M. 25.5 cage in my Challenger the first time we did the cage in it. Better safe than sorry. Easier to do all at once then go back over & over & keep adding to it.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Roll Cage requirements [Re: Biginchmopar] #2591066
12/12/18 10:05 PM
12/12/18 10:05 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Hey, Big Inch. Just put as much crome moly tubing in there as you can. Then get a gallon of Goriila glue to hold it together. Then you're good to go! Some more sound advice from your uncle.
Re: Roll Cage requirements [Re: merpar] #2591299
12/13/18 01:51 PM
12/13/18 01:51 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Not to go against the grain of what you're saying but professionals like Bill Lutz are using RTV now-a-days.
Re: Roll Cage requirements [Re: HardcoreB] #2591303
12/13/18 02:01 PM
12/13/18 02:01 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I see what you did there. LOL
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Roll Cage requirements [Re: pittsburghracer] #2591305
12/13/18 02:05 PM
12/13/18 02:05 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
obviously none of you guys have a clue to what you were talking about all the high in chassis shops now are gluing the cage together with Flex Seal. I guess the benefit is you do not need a grinder to touch up the glue
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Roll Cage requirements [Re: Cab_Burge] #2591307
12/13/18 02:07 PM
12/13/18 02:07 PM
PA.
"Little"John
"Little"John
PA.
I'm betting that your car will need more updating than you think IF and I said IF the inspector checks under your car. A lot of inspectors don't but my car was on a rack at the time and it needed 6 bars added because of rule changes over the years when I updated my mild steel Daytona from 8.50 to 7.50.
And my Daytona already had a funny car type of cage.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Roll Cage requirements [Re: pittsburghracer] #2591321
12/13/18 02:43 PM
12/13/18 02:43 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Actually I have been watching this post closely I have been avoiding the chassis update on my car for multiple reasons.. I have been lucky most of the racing that we do is 1/8th mile racing on quarter mile tracks.. usually we don't draw too much attention that way
Re: Roll Cage requirements [Re: WHITEDART] #2591326
12/13/18 02:54 PM
12/13/18 02:54 PM
PA.
"Little"John
"Little"John
PA.
I write my racing off as a business so licencing, physicals, spot rentals, chassis tech, etc, etc, just kinda plays into it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Roll Cage requirements [Re: pittsburghracer] #2591365
12/13/18 04:22 PM
12/13/18 04:22 PM
According to the first NHRA inspector that looked at my car when I had it certified the first time for me here in division 6 said it all it needed was the funny car cage to be certed to 7.50 due to the amount of bars in the chassis under the floorboards, 6 from the rear suspension to the foot bar shruggy
This car has gone 6.80s at around 184 MPH before I bought it less engine, it had a blown B1 KB motor on Methanol back then. It sat for 6 yrs. before I got it 5 yrs ago shruggy
Hopefully the new, better bigger C.I., better headed motor will run 8.80 or quicker at 150+ MPH luck
Re: Roll Cage requirements [Re: Cab_Burge] #2591375
12/13/18 04:29 PM
12/13/18 04:29 PM
PA.
"Little"John
"Little"John
PA.
My blue Duster was built for 6.50 cert but being they are only good for two years instead of three I will have it stickered for 7.50 cert. that will easily cover my ET.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Roll Cage requirements [Re: pittsburghracer] #2591378
12/13/18 04:33 PM
12/13/18 04:33 PM
I have looked at all the SFI chassis specs. years ago, the weight and body type,open or door car, made a lot of differences on the wall thickness on every bar work
My Cuda weighs right at 2800 Lbs. with me in it ready to race boogie shruggy
Re: Roll Cage requirements [Re: Biginchmopar] #2591409
12/13/18 05:31 PM
12/13/18 05:31 PM
Carson City, Nevada
Carson City, Nevada
I have a Duster with a 6.0 cert and I don't want that many bars in a car that is uncut. I understand if that's what it takes, that's what it takes. The cage would add enough weight that I wouldn't have to worry about low 8's unless I spray some juice to it.
I was told just add a funny car cage and if that was all that was needed I could do that without adding a lot of weight.
Anyways thanks for the input!
I'm off to buy Gorilla Glue, RTV and Flex Seal. whistling
beer
Re: Roll Cage requirements [Re: Biginchmopar] #2591410
12/13/18 05:33 PM
12/13/18 05:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FC cage and a few bars on/under/above floor will cover it generally.
Re: Roll Cage requirements [Re: Al_Alguire] #2591809
12/14/18 01:47 PM
12/14/18 01:47 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I was surprised each time i have re-certed my car how the NHRA inspector go/no go gages each bar, sonic checks each bar even the under car bars. I was a little nervous when he stood up aftwer inspecting underneath & asked what chassis shop built this car? I said "my buddies & I did, it's home built" & he said "it is one bad ass m.f'er & I am a Chevy guy". Made me feel pretty good for a guy that inspects thousands of cars a year to compliment mine.
Re: Roll Cage requirements [Re: pittsburghracer] #2591819
12/14/18 01:54 PM
12/14/18 01:54 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
You guys joke but I know of one of our local No E.T./Grudge cars that the track officials finally told our buddy with a sleeper 10.5" tire Mustang with no cage & factory lap bet, we know how fast you are going & we would appreciate it if you put a cage in the car. He did, it is all glued together plastic PVC with some roll bar padding on the door bar & head bars to look the part. The officials never said anything again. It is funny watching him climb over the door bar & it flexes as he gets in & out.
Not for me though. I would rather be safe.
