Page 2 of 10 1 2 3 4 9 10
Re: Tired of gratuitous mockup pics yet? [Re: SNK-EYZ] #2590468
12/11/18 05:41 PM
12/11/18 05:41 PM
S.E. Michigan
ZIPPY Online content OP
ZIPPY  Online Content OP
S.E. Michigan
Hey SNK, I was looking at the curved tray.
Which tray are you using in the reproduction hemi pan?
You have 4.500 stroke I presume?
What's your total fill and max rpm?
Pls feel free to PM if that is preferable.
The one I am doing has 2.200 journals.
Thx, Rich
Rich H.
Esse Quam Videri
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2590506
12/11/18 06:45 PM
12/11/18 06:45 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Have a great day
Iowan
"obsolete is neat"
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2590515
12/11/18 06:55 PM
12/11/18 06:55 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
The curved one from 440 source will not work with the hemi,440 six pack pan.
Re: Tired of gratuitous mockup pics yet? [Re: CSK] #2590547
12/11/18 08:08 PM
12/11/18 08:08 PM
S.E. Michigan
S.E. Michigan
Thanks, good info.
Of course part of me wants to see how far off it is/whether I could work with it.
Rich H.
Esse Quam Videri
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2590551
12/11/18 08:21 PM
12/11/18 08:21 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Hi Tony, taking baby steps towards a 572ci Street Hemi, eventual upgrade for the old Plymouth. More accurate to say street/strip but I will just stop there knowing you're very familiar with that whole deal (if you're not careful...next thing you know, it's a race car).
Nice! No adding 509 cam and 1.8 rockers for you. Going right for the jugular with the monster hemi, I like it! Looking forward to hearing how it turns out
2 kids and a dog
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2590572
12/11/18 09:18 PM
12/11/18 09:18 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I have a girdle and std stroke Milodon full length tray hanging on the wall if you want to mock stuff up.
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2590609
12/11/18 10:50 PM
12/11/18 10:50 PM
AndyF Offline
AndyF  Offline
Originally Posted By ZIPPY
Being cross bolted, I was thinking nobody made a girdle.
That World block doesn't need a girdle. Should be good for a couple thousand HP as is.
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2590626
12/11/18 11:25 PM
12/11/18 11:25 PM
S.E. Michigan
S.E. Michigan
Hey thanks. I put a production type MP tray in the mule 440 (I call it that because it's still kicking) and a milodon in the 451, but other than the deep milodon one....no extras. I might accept the tray loan even though the girdle won't be used. Will keep looking
at it and develop a plan. Of course, plans are always subject to change (This started as a low compression 528).
Rich H.
Esse Quam Videri
Re: Tired of gratuitous mockup pics yet? [Re: AndyF] #2590654
12/12/18 12:44 AM
12/12/18 12:44 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Originally Posted By AndyF
I don't know if such an animal exists or not but you can get sheet metal valve covers and then weld #12 AN bungs on them for screw in breathers or use AN lines over to the core support for a Moroso 3 qt remote breather tank.
AndyF,
Thank you for this info, I bought the 440source welded aluminum valve covers and was wondering how exactly to handle this problem. I appreciate your knowledge and willingness to help people, i wish everyone on this board would follow your example. Sorry to the OP for the hijack
eBay-cdwmotorsports
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2590752
12/12/18 10:14 AM
12/12/18 10:14 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Just let me know.
Of course you don't need a girdle, just a possible means to an end. It would simply be for mock up, clearance check and maybe some ideas. I think the thickness of the girdle will give you everything your trying to accomplish. Full length tray, up tight to the rotating assy, hemi oil pan, and a nice fit in the car.
Just an idea.
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2590875
12/12/18 03:33 PM
12/12/18 03:33 PM
S.E. Michigan
S.E. Michigan
collecting info.
Biggest detail is 1 and 3/16 stick out.
I'd like to create a little bit more space between the oil and the rods sticking out. With this pan and a 6qt fill, the oil seems a little too close to the rods for a windage tray/screen to even have much effect.
confirmed, the extra deep tray is no good with that pan.
I think what I'd like more is a 1"+ deeper repro pan, like 6".
I always believed that is what some of the f.a.s.t. cars appear to have...or used to...years ago I noticed some of them hang down below the K member but only slightly. Or alternately, I could shorten a 7" pan which would be easier because the sump is more squared off on most of them.
It has light interference at the pickup tube adapter, I think I can fix that. Although external is so easy with this block because of the hole in front, it's tempting to try that instead.
Will brainstorm awhile longer. I know I don't want a super stock pan with the center link poking through it.
Rich H.
Esse Quam Videri
Re: Tired of gratuitous mockup pics yet? [Re: cdwmotorsports] #2590882
12/12/18 03:46 PM
12/12/18 03:46 PM
S.E. Michigan
S.E. Michigan
AndyF,
Hey no need to apologize, pick up any ideas you possibly can from any source, it's all good.
I ran AN lines to a breather tank on my Wedge engine back in 2001
Over a period of time, though, I got tired of the clutter underhood and found it was not needed on that engine, tested up to 7000. Instead I went to OEM replacement 1970 era grommets and matching OE style breathers. Those paired up with baffles inside the valve covers is all it seems to need. But...that was a 3.75 stroke engine.....
Rich H.
Esse Quam Videri
Re: Tired of gratuitous mockup pics yet? [Re: BSB67] #2590884
12/12/18 03:47 PM
12/12/18 03:47 PM
S.E. Michigan
S.E. Michigan
Originally Posted By BSB67
Just let me know.
Thank you very much.
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2590923
12/12/18 04:49 PM
12/12/18 04:49 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Here's a link to a previous post about oil pickup clearance.
There are links in the posts and some pics.
https://board.moparts.org/ubbthreads/ubbt...tml#Post1266967
Re: Tired of gratuitous mockup pics yet? [Re: AndyF] #2590934
12/12/18 05:03 PM
12/12/18 05:03 PM
S.E. Michigan
S.E. Michigan
LOL, yes I know. And c'mon now...you know that I know laugh
Just being diplomatic for a second.
Rich H.
Esse Quam Videri
Re: Tired of gratuitous mockup pics yet? [Re: SNK-EYZ] #2590935
12/12/18 05:04 PM
12/12/18 05:04 PM
S.E. Michigan
S.E. Michigan
thanks
Rich H.
Esse Quam Videri
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2591019
12/12/18 08:31 PM
12/12/18 08:31 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
It looks like you want to go very fast Zippy !! Good luck with the build. Ron
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2591054
12/12/18 09:31 PM
12/12/18 09:31 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Nice info in your oil pan pic. Thanks.
For oil to rotating assy clearance, the 4.50 stroke is probably only 5/16" lower (closer) than a std stroke 440 if you're using the 2.20 rod journal.
Re: Tired of gratuitous mockup pics yet? [Re: ZIPPY] #2591137
12/13/18 12:36 AM
12/13/18 12:36 AM
NC, USA
davenc Offline
davenc  Offline
NC, USA
collecting info.
Zippy,
I had commented on someone else's build that from their pics the windage tray itself was going to be sitting at the oil level....then some other poster pointed out that the oil will not be at that level while the motor is running. I understand deep pans help, but it is worth considering that you may have more separation than you are thinking.
Re: Tired of gratuitous mockup pics yet? [Re: davenc] #2591150
12/13/18 01:12 AM
12/13/18 01:12 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
collecting info.
Zippy,
FWIW, I like to consider that too (i.e. the level will be lower when the motor is running), and that it is not sitting level either. I figure that if the oil is at the crank at the back of the motor when stationary and not running, and if the tray is up close to the crank, it'll all be good. No proof though.
I will say that with full time unrestricted oiling to the valve gear, loose bearing clearances and 0W-30W oil, I've never had a problem with oil pressure up to 6800 rpm.
