Re: Carbon fiber dash . Pics and weight added
[Re: humpty]
#2590463
12/11/18 05:35 PM
12/11/18 05:35 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Looking good Shiloh! Did you happen to weigh the old dash? .. yes mine weighed 23.8oz lb. With upper and lower dash pads.. the new setup in the car will probably be 6 lb that includes the new racepak Dash
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: humpty]
#2590517
12/11/18 06:57 PM
12/11/18 06:57 PM
WHITEDART
bean town ....Ca
As of right now I'm going to run the tack... I'm not 100% sure on the other gauges yet
[Re: WHITEDART]
#2590700
12/12/18 02:35 AM
12/12/18 02:35 AM
Posts: 89 Cedar Rapids, IA
69Mcode440
Cedar Rapids, IA
Tell us about your steering column.
Mike
Mike 69 440 Cuda 71 Dart drag car 70 Duster drag car Best et 9.32, 145.9 mph 2019 Ram 2500 4x4
[Re: 69Mcode440]
#2590761
12/12/18 10:58 AM
12/12/18 10:58 AM
WHITEDART
bean town ....Ca
It's a Chassis Works steering column kit.. basically cut to length and weld together.. it saves a bunch of weight and cost around two hundred bucks..
[Re: WHITEDART]
#2590843
12/12/18 02:39 PM
12/12/18 02:39 PM
69Mcode440
Cedar Rapids, IA
It's a Chassis Works steering column kit.. basically cut to length and weld together.. it saves a bunch of weight and cost around two hundred bucks.. Thanks! Mike
[Re: fullmetaljacket]
#2592071
12/14/18 09:28 PM
12/14/18 09:28 PM
WHITEDART
bean town ....Ca
WD 40 That dash looks dashing. That's a good amount of weight loss that got my radar going.
Good luck moving forward which should be fairly easier now that you've got 16 lbs less to haul. Go get 'em. let's just say you have inspired me.. in all reality a stock Dash is closer to 30 lb... but my current Dash had already been on a pretty decent diet. I think this is going to be just shy of 20 lb gross after I got rid of some more weight that was hanging around in that area
[Re: bigblockrik]
#2592072
12/14/18 09:29 PM
12/14/18 09:29 PM
WHITEDART
bean town ....Ca
Looks killer is the flat area for the gauges vertical or angled cant tell from the pics and could you measure it wording how large of a gauge it will hold. I haven't forgot about you I just haven't had the opportunity to get out there and take those measurements for you hopefully over the weekend I can get back at it
[Re: Biginchmopar]
#2592093
12/14/18 10:36 PM
12/14/18 10:36 PM
WHITEDART
bean town ....Ca
. Yeah good point I bet you that's what it was
#2592160
12/15/18 01:29 AM
12/15/18 01:29 AM
WHITEDART
bean town ....Ca
We have talked extensively regarding glare.. unfortunately. Kevin at unlimited worked us a special deal I kind of need to run it the way it is kind of as a show and tell. I hope you know what I mean.. at some point it may get painted..
