No Facebook part two #2589491
12/09/18 06:25 PM
12/09/18 06:25 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
First time in a few years now that I ended the season on a positive result.
2019 ultra rules are almost finalized, preliminary has 50lbs added on my combination. That's ok since I have been testing 35lbs heavy. If the rules stay as is, then I need to add 15lbs.
I've got some great people helping me and the racepak info looks like the goals can be achieved. Tighter converter and slight nitrous system mods may be all that's needed. That and test test test....
How's your heads up racing look for 2019?
....BAD A$$ STREET CAR.....
Re: No Facebook part two [Re: n20mstr] #2589502
12/09/18 06:40 PM
12/09/18 06:40 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Well after Church today I finished up my Powerglide for my heads up car. I went with a 1.69 straight-cut low gear-set, 8 blue clutches in a 10 clutch drum, pro trans-brake, 1500 plus horsepower input shaft, and a TCI high pressure pump. Now I can finish up the oiling system on my 572 and test prime the oiling system and finish up the engine. Finally this car may hit the track in 2019. I gotta get my butt to the gym to get myself ready for race season as I let myself go terribly. Good-luck in 2019.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: No Facebook part two [Re: n20mstr] #2589507
12/09/18 06:51 PM
12/09/18 06:51 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
I haven't even pulled my car out of the trailer .
Every time I want to move cars around it's raining or snowing .
Wanted to go with a bigger bore and more comp. 11.2 ish now wanted to go 13.5 but can't bore it anymore then it is .
Might just put rings and bearings and bigger push rods .
Think we can go 5.0hs next year.
Re: No Facebook part two [Re: n20mstr] #2589518
12/09/18 07:24 PM
12/09/18 07:24 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Not near in the same league with my mild street build but got solidly into the 10's last year in the brutal heat and humidity. First (realistic and achievable) goal is 10.40's this Spring. Pipe dream goal? 9.99. runaway
'63 Dodge 330
11.19 @ 121 mph
Re: No Facebook part two [Re: GY3] #2589529
12/09/18 07:46 PM
12/09/18 07:46 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
We all started there...it's addicting for sure. Only a matter of time, keep at it !
Re: No Facebook part two [Re: a493demon] #2589531
12/09/18 07:47 PM
12/09/18 07:47 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
-8 line , and some bottle valves
Re: No Facebook part two [Re: pittsburghracer] #2589532
12/09/18 07:48 PM
12/09/18 07:48 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
We can always use more cars at monster mopar ! Get ER done !
Re: No Facebook part two [Re: n20mstr] #2589622
12/09/18 10:53 PM
12/09/18 10:53 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I miss the column shifter!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: No Facebook part two [Re: hemi-itis] #2589917
12/10/18 05:13 PM
12/10/18 05:13 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
oh yea, me too....at least it was one of a kind back then ! fastest it went was 8.38 @ 160 column shifted
Re: No Facebook part two [Re: n20mstr] #2589922
12/10/18 05:23 PM
12/10/18 05:23 PM
PA.
"Little"John
"Little"John
PA.
every time I post in this post I get hell over on Facebook. I swear he’s over here on Moparts more than I am. Lol πŸ˜‚
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: No Facebook part two [Re: pittsburghracer] #2589942
12/10/18 06:00 PM
12/10/18 06:00 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
?? I cant understand why....this has nothing to do with XXXX
best thing you can do is ignore it....
Re: No Facebook part two [Re: n20mstr] #2589968
12/10/18 06:44 PM
12/10/18 06:44 PM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
We're in good shape also...Move the bars up a notch (LOL) and replace all the heim ends along with new rear tires and we're on go...Been stuck in the low 80's but should get better with the rule tweaking and better rear chassis understanding for our Tex275/Limited275 class we race in !!
Re: No Facebook part two [Re: n20mstr] #2589986
12/10/18 07:30 PM
12/10/18 07:30 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
This topic seems to require a reasonable attention span, and might be too complex and deep for Fakebook. I'm lucky if I get the car out at all anymore and am doing what I can to make little steps forward....that's about it...I've never tried to be a heavy hitter anyway and am just trying to make progress wherever I can, and whatever I do...do it better than last time.
Rich H.
Esse Quam Videri
Re: No Facebook part two [Re: ZIPPY] #2590005
12/10/18 07:53 PM
12/10/18 07:53 PM
Idabel,Oklahoma
Idabel,Oklahoma
[quote=ZIPPY]This topic seems to require a reasonable attention span, and might be too complex and deep for Fakebook.
Sadly but there's way more that goes on on FB than any board anymore as it's hurt most...All the hitters are there with all brands in the mix...You have your normal TROLLS but they get weeded out pretty quick...
Re: No Facebook part two [Re: Gary Robbins] #2590018
12/10/18 08:11 PM
12/10/18 08:11 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Understood and yes that is true, especially behind the scenes.
Even I personally spend more time on Fakebook than here but when something complex is brought up there, not many seem to wanna deal with it. It's no fun, don't be a downer by telling the truth, lets see more pictures of food, dogs, or whatever etc.
Guess it is because I'm old...I still like the old bulletin board format although it's kind of clunky.
Rich H.
Esse Quam Videri
Re: No Facebook part two [Re: n20mstr] #2590072
12/10/18 09:34 PM
12/10/18 09:34 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Gary, looks great. Talk about a prepped track !
Re: No Facebook part two [Re: n20mstr] #2590176
12/11/18 01:06 AM
12/11/18 01:06 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
[/quote] -8 line , and some bottle valves [/quote]
That'll be the day! πŸ™„
Re: No Facebook part two [Re: SILVER67] #2590192
12/11/18 01:31 AM
12/11/18 01:31 AM
a493demon Offline
a493demon  Offline
That'll be the day! πŸ™„ [/quote]
All ready have one bottle valve
Re: No Facebook part two [Re: a493demon] #2590458
12/11/18 05:27 PM
12/11/18 05:27 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
No fan of Facebook myself.. hopefully 2019 will be a good race year for us . Hopefully we can keep it together.. we plan on running limited 235.. which for us requires no rule change from the old west coast Ultra Street rules.
Also anticipate running MRM N/A 10.5 stuff as well.. not looking for any huge ET improvements this year just hoping to improve on some of the changes that we made.. hoping to run in the 5.30s this year
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: No Facebook part two [Re: WHITEDART] #2590951
12/12/18 05:31 PM
12/12/18 05:31 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
bad A$$ car, got to love a smallblock A body they are so easy to work on !
