Dana 60 Ford disc brake swap questions #2589294
12/09/18 12:14 PM
12/09/18 12:14 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
Sorry if this is rehashing old information. I poked around with the search function and found some stuff, but not everything I need.
I have a D60 at the axle shop now getting prepped and it's going to get disc brakes. The shop quoted a price of $475 for a kit; which doesn't seem bad at all, but I think I could get by significantly cheaper if I source the parts myself going with the Ford Explorer rear disc swap. There is a large self service junk yard near by, so getting the brackets should not be an issue. Rotors and calipers would be purchased brand new from a parts store.
Would there be much savings doing this myself, or should I just get the kit? If I do decide to source the parts myself, what year Explorers should I be looking at for caliper brackets?
I found this photo linked in another thread here:
These the brackets I should be looking for?
Thanks again.
Re: Dana 60 Ford disc brake swap questions [Re: MarkZ] #2589320
12/09/18 01:30 PM
12/09/18 01:30 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
Call your parts store and price it out... then call the salvage yard and price it out... then figure what your time is worth and ...you guessed it price it out. Let us know what you came up with.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Dana 60 Ford disc brake swap questions [Re: MarkZ] #2589339
12/09/18 02:02 PM
12/09/18 02:02 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Around here the backing plates are always damaged and usually rust out, from sitting with no wheels. I put an 8.8 in 2 of my vehicles, the one I had to replace everything on the brakes except backing plates, i want to say it cost like 300$ to replace everything.
I did see people selling complete used setups on eBay the other day.
Re: Dana 60 Ford disc brake swap questions [Re: MarkZ] #2589350
12/09/18 02:18 PM
12/09/18 02:18 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Used to be a time FMS sold the Explorer rear disc kit all new for less than that quote. Doesn't seem to be so anymore, but that $475 quote is cheaper than any Explorer kit I can find these days.
Don't be the exception.
Re: Dana 60 Ford disc brake swap questions [Re: MarkZ] #2589379
12/09/18 02:58 PM
12/09/18 02:58 PM
AndyF Offline
AndyF  Offline
Currie has new backing plates at a reasonable cost (Summit carries them) or you can buy the whole kit from Currie.
https://www.currieenterprises.com/CE-6012E1
Re: Dana 60 Ford disc brake swap questions [Re: MarkZ] #2589400
12/09/18 03:32 PM
12/09/18 03:32 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I sell NEW Explorer rear disc brake kits for $395.
Re: Dana 60 Ford disc brake swap questions [Re: DoctorDiff] #2589429
12/09/18 04:21 PM
12/09/18 04:21 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
there you go, I knew I saw that kit somewhere
Re: Dana 60 Ford disc brake swap questions [Re: DoctorDiff] #2589462
12/09/18 05:06 PM
12/09/18 05:06 PM
AndyF Offline
AndyF  Offline
I thought you did but I couldn't find them on your website so figured they had gone away.
Re: Dana 60 Ford disc brake swap questions [Re: MarkZ] #2589467
12/09/18 05:30 PM
12/09/18 05:30 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Not sure if this helps at all, but E350 vans came with Dana 60s and disc brakes from the factory.
Re: Dana 60 Ford disc brake swap questions [Re: MarkZ] #2589473
12/09/18 05:36 PM
12/09/18 05:36 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
I looked at your store before and didn't see the kit either. You also sell the Ford housing ends? Probably just make things a whole lot easier going through you and that is a good price. I'll call you Monday.
Re: Dana 60 Ford disc brake swap questions [Re: MarkZ] #2589704
12/10/18 01:50 AM
12/10/18 01:50 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I don't stock the Explorer rear disc brake kit, but I can drop-ship it.
Billet steel "new style/Torino" housing ends run $80 pair.
Re: Dana 60 Ford disc brake swap questions [Re: MarkZ] #2589718
12/10/18 03:02 AM
12/10/18 03:02 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I did the kit from Teraflex, uses explored rotors, calipers, etc.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Dana 60 Ford disc brake swap questions [Re: MarkZ] #2590195
12/11/18 01:44 AM
12/11/18 01:44 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
i am assuming you are prepping this dana 60 for a car---using ford passenger axle ends----there is a disc brake set up on a lincoln mark 7 or a versaille that fits right on there...the caliper on it was re-used on the explorers---neat set up......
Re: Dana 60 Ford disc brake swap questions [Re: MarkZ] #2596214
12/24/18 12:04 PM
12/24/18 12:04 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
Got everything from Dr Diff to rebuild my 60 and also got the Explorer disc brake kit. The brake kit was only $390 and sure beats going junkyard shopping in the dead of winter. Honestly, even if this were summer I'd still go this route. The shop has everything now and I should pick the completed axle up a couple weeks after the new year. Thanks again Cass...
Re: Dana 60 Ford disc brake swap questions [Re: MarkZ] #2596301
12/24/18 02:44 PM
12/24/18 02:44 PM
AndyF Offline
AndyF  Offline
You need a big piston up front to work with the Explorer caliper out back. Are you using the factory calipers up front? If you have room for a 11.75 rotor (15 inch wheel) you might want to upgrade the front rotors. All you should need would be the bigger rotors and the taller caliper brackets. You shouldn't even need to bleed the brakes, just lift the calipers off and change the rotors and brackets and drop them back on.
Re: Dana 60 Ford disc brake swap questions [Re: AndyF] #2596399
12/24/18 06:14 PM
12/24/18 06:14 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
I figured I would need to change the master and distribution block. The car has 18" wheels that I bought in that size specifically for upgrading the factory front disc to a 13" rotor. I do have the 11.75" brackets though. I may just do that and see how it works for now since the budget is shot already. Trouble is I don't want to change the master twice if I decide to go 13" brakes up front later. Eh, I'll figure it out in the Spring. grin
Re: Dana 60 Ford disc brake swap questions [Re: MarkZ] #2596504
12/24/18 09:19 PM
12/24/18 09:19 PM
AndyF Offline
AndyF  Offline
You wouldn't need to change the master twice. If you're going with 13 inch rotors up front then you can ditch the power booster and just run manual. You should be able to use a 15/16 inch master from Doctor Diff for 4 wheel disc brakes. You shouldn't need a prop valve with that setup so just a simple distribution block will work. If you want to keep the factory brake light then you'll need a distribution block with the switch in it. Which 13 inch setup are you going to use up front? I just got the 13 inch Viper setup installed on my Duster. That same kit should bolt on your car. I also have the Explorer setup in the rear.
Re: Dana 60 Ford disc brake swap questions [Re: MarkZ] #2596686
12/25/18 12:01 PM
12/25/18 12:01 PM
P
Porter67 Offline
Porter67  Offline
P
Do you have a link to that rear brake kit, I couldnt find it.
Grr I read it through and found the answer.
Ive one S60 already with the explorer kit and its been flawless for almost 10 years now.
Like Andy wrote if you get the right master its very easy to run a manual system that works great, my fronts are a wilewood kit and ive also got the bigger master that came from Dr Diff and I might have a lil mos match as it takes more pedal effort then I thought it would but at the same time my front rotors are blue and my backs are a bit so maybe im working them hard.
Re: Dana 60 Ford disc brake swap questions [Re: MarkZ] #2596893
12/25/18 07:41 PM
12/25/18 07:41 PM
MarkZ Offline OP
Worthy
MarkZ  Offline OP
Worthy
I didn't realize going manual was an option. Would be nice being able to toss the booster. I was planning on Cass's 13" Cobra kit, but the Viper kit the two of you are putting together looks real nice too.
Do you think I would be able to run with the factory calipers up front for the season with a master cylinder that would be compatible with one of those two options?
Thanks again.
Re: Dana 60 Ford disc brake swap questions [Re: MarkZ] #2596934
12/25/18 10:14 PM
12/25/18 10:14 PM
AndyF Offline
AndyF  Offline
You could run a manual setup with the factory calipers and 11.75 rotors up front. It would stop but you might need to put more effort into it than you're used to. Once you changeover to the 13 inch rotors the effort would drop a bit.
I run manual brakes on my Coronet with 13 inch rotors up front. It stops really well and that car is 4000 lbs. So if you car is less than 4000 lbs you should be fine with manual brakes.
Re: Dana 60 Ford disc brake swap questions [Re: MarkZ] #2596942
12/25/18 10:26 PM
12/25/18 10:26 PM
P
Porter67 Offline
Porter67  Offline
P
It would be simple for you to run manual, Im pretty sure youd need the fmj plate that lets you use the 2 stud master and its for manual because its arm is leveraged a bit different.
I run my master (and im pretty sure its the 15/16? Cass sold at the time) I can dig out my paperwork and it runs through the oem per-portioning valve.
I still have the WW adjusteable valve in its box I thought id need.
Ive never had one instance where I said to myself "I wish they were power" and ive been on them hard at 140.
