I have a Saginaw power steering pump that has big block brackets on it and a solid pully. The pulley has what I believe is a vendor number of 99705 stamped into it. It also has 3808 stamped into it which may be a partial part number? The pulley is the type that has a nut to secure it in place and is not pressed on. I would like to know the application of this pulley?
Thanks!
