Re: 1970 Road Runner
[Re: StangGangRepair]
#2361032
08/28/17 10:24 AM
08/28/17 10:24 AM
Posts: 305 Wisconsin
Big D A12
Wisconsin
ECS Automotive for OEM. Several suppliers on Ebay.
DD
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!! 2018 Demon Challenger PY4 A8 Black Hood 2017 Jeep Trail Hawk 2016 Hellcat Challenger PCP A8 1969.5 A12 Super Bee WM21 V1H F6 D21 1969 Coronet RT B5 D32 M46 N96
#2552847
09/21/18 01:51 PM
09/21/18 01:51 PM
Posts: 4,590 Motor City
6PKRTSE
Motor City
Better double check to make sure that you buddies Road Runner may not be an old Superbird with the different rear window design. I have a 70' Road Runner also. I can measure the window where ever needed for you if you need any dimensions to compare to your new rear window?
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
#2553915
09/24/18 12:17 AM
09/24/18 12:17 AM
Posts: 4 USA
StangGangRepair
USA
Thank you for the recent reply and pictures of the window. I believe that looks like the one we tried but it didn't fit with the bottom curves. This post was over a year ago and the owner of this car has since moved on to a 67 Stang Fastback, something we are more familiar with and it will be more nasty with the 428!
#2553933
09/24/18 01:32 AM
09/24/18 01:32 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Probably had the corners replaced with crappy repops... I know this is an old post, but the corner repair pieces they used to sell were flat and worthless.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: 70runner]
#2577690
11/12/18 11:19 PM
11/12/18 11:19 PM
Posts: 4 USA
StangGangRepair
USA
70Runner and cbusters, I think you were right about the dutchman panel being replaced wrong. As I was loading it up to be shipped out, I removed the old carpet from the package tray and i can see somebody's crappy work. Looks like they just welded a new dutchman panel over top of the old dutchman panel as i can see the bottom of the old window rail once the carpet was removed. At least it is now somebody elses headache. Ill attach a pic for you to see this crap. Thanks for all your help though and next time I get a dodge in here, I will reach out to this forum again before i buy 3 windows that wont fit! Thanks Again!
#2577754
11/13/18 12:56 AM
11/13/18 12:56 AM
Posts: 18,160 Mass
DAYCLONA
Mass
70Runner and cbusters, I think you were right about the dutchman panel being replaced wrong. As I was loading it up to be shipped out, I removed the old carpet from the package tray and i can see somebody's crappy work. Looks like they just welded a new dutchman panel over top of the old dutchman panel as i can see the bottom of the old window rail once the carpet was removed. At least it is now somebody elses headache. Ill attach a pic for you to see this crap. Thanks for all your help though and next time I get a dodge in here, I will reach out to this forum again before i buy 3 windows that wont fit! Thanks Again! That's a Superbird rear window plug installed over the stock dutchman panel, that's the way they were done, now you've opened Pandora's box for the popcorn crowd... AMD has repro rear windows for 70 SUPERBIRDs.... retail is approx $950 IIRC...better hurry if you truly need it as it's a limited run, the rear window trim is available as well...$850, IIRC they have a package deal, window and trim for approx $1500
[Re: DAYCLONA]
#2577760
11/13/18 01:17 AM
11/13/18 01:17 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
70Runner and cbusters, I think you were right about the dutchman panel being replaced wrong. As I was loading it up to be shipped out, I removed the old carpet from the package tray and i can see somebody's crappy work. Looks like they just welded a new dutchman panel over top of the old dutchman panel as i can see the bottom of the old window rail once the carpet was removed. At least it is now somebody elses headache. Ill attach a pic for you to see this crap. Thanks for all your help though and next time I get a dodge in here, I will reach out to this forum again before i buy 3 windows that wont fit! Thanks Again! That's a Superbird rear window plug installed over the stock dutchman panel, that's the way they were done, now you've opened Pandora's box for the popcorn crowd... AMD has repro rear windows for 70 SUPERBIRDs.... retail is approx $950 IIRC...better hurry if you truly need it as it's a limited run, the rear window trim is available as well...$850, IIRC they have a package deal, window and trim for approx $1500 Yep that's Pandora's box right there. LOL
#2577809
11/13/18 03:40 AM
11/13/18 03:40 AM
Silver70
Rust Belt, SW PA
I never knew they installed them over top like that... never worked on one. I've seen clones where people don't even install the plugs ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: Silver70]
#2577865
11/13/18 12:16 PM
11/13/18 12:16 PM
Posts: 18,160 Mass
DAYCLONA
Mass
I never knew they installed them over top like that... never worked on one. I've seen clones where people don't even install the plugs The 69 Charger Daytona and 69 Charger 500 models are done the same way also, the stock dutchman stayed in place and was covered over by the Aero plug install Mike
#2578286
11/14/18 10:55 AM
11/14/18 10:55 AM
Posts: 6,444 Abilene, Texas
fastmark
Abilene, Texas
Dayclona,
Thanks for the info on the rear window but we got rid of that car a few weeks ago after all the troubles with the rear window and other other parts. Thats a pricey window but I wish I would have talked to over a year ago when we first started having issues with the window. Im glad to see that one go. Yep, seriously! Lol. This would be the equivalent of going on to a Mustang board and complaining about not being able to find a hood that looks just like the one on my Mustang so I kicked on down the road. Oh, and it had someone name on the car too, like Shelley or something like that. He might have had a Superbird with a RR front end. Who knows now.
[Re: fastmark]
#2578313
11/14/18 12:20 PM
11/14/18 12:20 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Dayclona,
Thanks for the info on the rear window but we got rid of that car a few weeks ago after all the troubles with the rear window and other other parts. Thats a pricey window but I wish I would have talked to over a year ago when we first started having issues with the window. Im glad to see that one go. Yep, seriously! Lol. This would be the equivalent of going on to a Mustang board and complaining about not being able to find a hood that looks just like the one on my Mustang so I kicked on down the road. Oh, and it had someone name on the car too, like Shelley or something like that. He might have had a Superbird with a RR front end. Who knows now. Never know?... This could be the beginning of one of those stories you hear about some Chevy/Ford guy(s) who unknowingly had a potential 6 figure car in their hands and let it go for reasons like above...probably had some engine mods that looked like someone drilled holes in the valve covers to fit the ignition wires through too?...lol!
[Re: DAYCLONA]
#2578950
11/15/18 10:14 PM
11/15/18 10:14 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
70Runner and cbusters, I think you were right about the dutchman panel being replaced wrong. As I was loading it up to be shipped out, I removed the old carpet from the package tray and i can see somebody's crappy work. Looks like they just welded a new dutchman panel over top of the old dutchman panel as i can see the bottom of the old window rail once the carpet was removed. At least it is now somebody elses headache. Ill attach a pic for you to see this crap. Thanks for all your help though and next time I get a dodge in here, I will reach out to this forum again before i buy 3 windows that wont fit! Thanks Again! That's a Superbird rear window plug installed over the stock dutchman panel, that's the way they were done, now you've opened Pandora's box for the popcorn crowd... AMD has repro rear windows for 70 SUPERBIRDs.... retail is approx $950 IIRC...better hurry if you truly need it as it's a limited run, the rear window trim is available as well...$850, IIRC they have a package deal, window and trim for approx $1500 Holy Super Bird Batman! So.....is it possible this Roadrunner was one of those 70 Superbirds that didn't sell & had the nose removed???
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
