A833 bearing retainer question
#2584979
11/30/18 12:38 AM
11/30/18 12:38 AM
Posts: 157 Winlock, Wa
fshd4it
Winlock, Wa
Hi all. I picked up a 4 speed today, stamping says it's from a '68 or '69 roadrunner(6th digit isn't legible). The front bearing is a 307, but it has the small O/D retainer. Didn't these come with the 3.70 bolt circle/4.805 retainers? I'm assuming someone changed the retainer to put it behind a small block, because the 383s didn't get a unique bellhousing, did they? It has a drop-in/bayonette style hurst shifter as well, what year(s) were those used? TIA, Karlin.
In order to know what you want, you'll probably have to find out what you don't want.
Re: A833 bearing retainer question
[Re: fshd4it]
#2584998
11/30/18 01:19 AM
11/30/18 01:19 AM
Posts: 43,308 Bend,OR USA
Cab_Burge
Never, ever assume anything when it comes to production cars and parts ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) I would bet money that all the pre 1970 23 spline trannys came with the small front bearing and retainers and only the hemi and 440 Hi Po tranny came with the larger 308 bearing and retainers ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Some of the early SB 4 speed tranny came with a different gear sets and a smaller output shaft but I'm going to say all of them used the same front bearings and retainers as all the other non hemi, 440 23 spline tranny did As far as the OEM Hurst factory built for Mopar shifters I'm going to say all of them had the slip in shifter handles instead of the bolt in handles like the over the counter Hurst Competition Plus shifters had ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Maybe not
[Re: fshd4it]
#2585107
11/30/18 12:06 PM
11/30/18 12:06 PM
Posts: 768 Ohio
Dan Brewer
Ohio
Hi all. I picked up a 4 speed today, stamping says it's from a '68 or '69 roadrunner(6th digit isn't legible). The front bearing is a 307, but it has the small O/D retainer. Didn't these come with the 3.70 bolt circle/4.805 retainers? I'm assuming someone changed the retainer to put it behind a small block, because the 383s didn't get a unique bellhousing, did they? It has a drop-in/bayonette style hurst shifter as well, what year(s) were those used? TIA, Karlin. Yes the retainer was likely changed to work with a small retainer hole bellhousing at some point in time. 68-9 383 RR would have used a trans with the 307 bearing and 4.805" retainer diameter. Retainers are readily available if you have the large hole bellhousing.
[Re: Dan Brewer]
#2585119
11/30/18 12:23 PM
11/30/18 12:23 PM
fshd4it
Winlock, Wa
Thanks Dan. I thought that's how it worked, but I wanted to make sure. There just aren't any marks, grease/dirt ring, etc on the front of the case to indicate it used to be a larger retainer, so it got me wondering.
[Re: fshd4it]
#2585283
11/30/18 06:28 PM
11/30/18 06:28 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
I have a supposed to be 69 RR trans in the garage.Was pulled over 40 years ago.It did have the small retainer.I have it on my 65 tranny now.Rocky
Chrysler Firepower
[Re: therocks]
#2585318
11/30/18 07:35 PM
11/30/18 07:35 PM
fshd4it
Winlock, Wa
I have a supposed to be 69 RR trans in the garage.Was pulled over 40 years ago.It did have the small retainer.I have it on my 65 tranny now.Rocky It had the small (4.350") outer diameter retainer? If I understand you correctly, that's interesting. This one's probably been sitting for that long as well.
[Re: Stanton]
#2585319
11/30/18 07:38 PM
11/30/18 07:38 PM
fshd4it
Winlock, Wa
If you have a large hole bell and a small retainer you can buy an adapter ring from Brewers. $20. I think I saw that on their site last night. IIRC I had one of those with a scattershield once. My stuff is all small block, so luckily it will work for me (if I keep it) as is.
