Re: How many street legal 10 second B Bodies's
[Re: GY3]
#2583951
11/27/18 11:41 PM
11/27/18 11:41 PM
Posts: 12,476 Taxes & Virus's R-US, NY
Dragula
10.90...Pump gas, iron heads,, all steel....Registered, plated, insured.
[Re: Dragula]
#2583965
11/28/18 12:03 AM
11/28/18 12:03 AM
Posts: 4,457 Washington
madscientist
Washington
10.90...Pump gas, iron heads,, all steel....Registered, plated, insured. I just LOVE that yellow! Very nice.
[Re: 68LAR]
#2583975
11/28/18 12:22 AM
11/28/18 12:22 AM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
Made it down to 10.70 at Milan (running a 11.0 index :() a while ago. I did have cutouts open. Was running a TKO at the time. The TKO was good for the street, but pretty iffy flat shifting It was 3900 lbs, w/470 (also, anyone have a good 400 block they won't be using? sorry)
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: 68LAR]
#2584465
11/29/18 12:46 AM
11/29/18 12:46 AM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
Ran 10's on the old wedge. Hopefully quicker with the new setup. https://www.youtube.com/watch?v=sIl-88xIsQwhttps://youtu.be/IcNgpdQA4YI... By street legal,it must have insurance, registration, or anything else necessary to drive on the street legally. I'd also like to know the combo's. Old set up: 446, 10.8:1, OOTB Performers (open chamber), Crane Gold rocker arms, .590 Purple Shaft, ~150hp NOS. New set up: ???
[Re: 68LAR]
#2584525
11/29/18 02:33 AM
11/29/18 02:33 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Mine has run 10.70's a few times and usually runs 10.80's on average days. In fact it ran 10.76 one of the first times out and I have made no changed to it since 2011 which is why it still runs the same. I just wanted to hit 10's in full street trim just as I drive it through the full exh on 92 pump usually but I have even had 87 pump in it when by mistake I put 87 in it. Still ran fine with no ping. Its a mild 440/493 that I can drive anywhere. I use Indy EZ heads and a Dwayne Porter solid flat tappet cam that's 264 & 270 @ .050 with .585 & .592 lift on a 110 LSA. Its 10.6 comp and I run the Indy dual plane intake with a Holley 850 DP. I have never uncapped the car and never had race gas in it. Its a 727 auto with a Dynamic 9.5 street/strip converter and I love driving it.The car body is all stock and all steel other then the glass hood. No tubs and no springs moved any. Ron
[Re: 68LAR]
#2584554
11/29/18 04:14 AM
11/29/18 04:14 AM
Posts: 1,266 New York, USA
Chargerfan68
New York, USA
Ive got a 505” pump gas motor with solid flat tappet cam at 10.4 comp. at 3900 lbs, it runs 10.75 @ 127mph. Edelbrock rpm just cleaned up a bit with a victor intake and 1050. 4speed stickshift with 4.30 rear. Alot of fun and i do drive it all the time. Driven 200+ miles each way to Carlisle for show.
[Re: Chargerfan68]
#2584619
11/29/18 12:06 PM
11/29/18 12:06 PM
Posts: 4,016 South Park, Pa.
68LAR
South Park, Pa.
Interesting responses. From what I've read, just about everyone is running a stroker, except for, maybe three. Just about everyone is running an auto, except three. Most have some type of power adder. Seems like a pretty exclusive group, though. Good job everyone.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: 68LAR]
#2584639
11/29/18 12:56 PM
11/29/18 12:56 PM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
Larry...Not a B body obviously, but my 'cuda went 10.40s at 129 mph (all motor) w/ a stock crank 440, unported Indy SR heads, .660"/266° at .050 solid roller, Weiand Team G and a 1050 dominator at 3700 lbs. 727 w/ 4.10 gears, 28x10.5 tire.
Drove it on the street a lot. It was probably the most fun street combo I've had in it. The current combo in the car is like driving on wet pavement almost all the time when you try to play w/ it on the street.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: 68LAR]
#2584659
11/29/18 01:25 PM
11/29/18 01:25 PM
Posts: 14,531 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Not tagged or insured...... but.......
68 Satellite, 3670lbs, flat hood, heater, wipers, full interior, mech fuel pump, 5/16” fuel line, crank driven w/p, 9.7:1 448, ly rods, 260cfm 906’s, UD roller cam, torker 2, 850dp, 2” hookers, 5300 stall, 4.56’s, ss springs, 29.5 x 10.5 slicks.
Best ET 10.61, best speed 126+, best 60’ 1.46.
When I put the 448 back in the car after reworking the heads again and adding the roller cam, it went 10.91 right off the trailer with very used up 9 x 30 slicks on it. Ended up mid-10.80’s that day.
[Re: 68LAR]
#2584752
11/29/18 04:22 PM
11/29/18 04:22 PM
Posts: 668 IL
Dart451
IL
9.9's twice 10.0 enough to drive me crazy it wasn't in the 9"s lol 3300 race weight 498 Trickflow 240, Dwayne specs cam, thumper carb, Andyf "Wilson ported intake m1 intake" and 1.7 harland sharp rockers. 8" converter 4:10 gears Dragweek 2017
Pic stolen from MoparBilly
[Re: Roughbird72]
#2584754
11/29/18 04:27 PM
11/29/18 04:27 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
My 69 roadrunners has been 10.92 so far through the exhaust at 4000# ( with me).
10.5:1 511 Indy SR Six pack or TM6 1050/4150 ( both ran the same) SFT 4.10 gear DOT’s
Heater is even hooked up and working. No roll bar because it’s a street car.
Tried to add picture but this site isn’t iPhone friendly..
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: 68LAR]
#2584789
11/29/18 05:45 PM
11/29/18 05:45 PM
oldiron
New Hampshire, USA
interesting stuff. looks like a lot of different ways to get down in the 10s. all cool
[Re: KOS]
#2584982
11/30/18 12:45 AM
11/30/18 12:45 AM
Posts: 10,607 Rittman Ohio
fourgearsavoy
Rittman Ohio
Mine is a 493 EZ std.port heads,Comp XTQ series flat cam,10.9 compression,Performer RPM with Quick fuel 1050 4150 series carb,Richmond 5-speed, 3.54 Dana,lights,wipers,horn,tags,insurance, 93 octane pump gas. It has run 10.91 and a tic over 125 MPH on a 9" slick. Putting a rollbar in it this winter so I can be legal and make the wife happy that I'm safe Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
