Page 2 of 4 1 2 3 4
Re: How many street legal 10 second B Bodies's [Re: GY3] #2583951
11/27/18 11:41 PM
11/27/18 11:41 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
10.90...Pump gas, iron heads,, all steel....Registered, plated, insured.
Re: How many street legal 10 second B Bodies's [Re: Dragula] #2583963
11/27/18 11:59 PM
11/27/18 11:59 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
66 Coronet Sedan 3750# all steel with fiberglass hemi scoop
steel wheels with dog dish hub caps 275 drag radials
full 3 inch exhaust to the bumper
4.10 gear
6.1 based 426 gen 3 Hemi modman intake with 2 4 barrels
has been 10.9s column shifted
Re: How many street legal 10 second B Bodies's [Re: Dragula] #2583965
11/28/18 12:03 AM
11/28/18 12:03 AM
Washington
madscientist Offline
Washington
I just LOVE that yellow! Very nice.
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2583975
11/28/18 12:22 AM
11/28/18 12:22 AM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Made it down to 10.70 at Milan (running a 11.0 index :() a while ago. I did have cutouts open. Was running a TKO at the time. The TKO was good for the street, but pretty iffy flat shifting
It was 3900 lbs, w/470
(also, anyone have a good 400 block they won't be using? sorry)
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2584008
11/28/18 01:23 AM
11/28/18 01:23 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
3700 lbs,Iron block hemi,1071 BDS with a pair of SV1s carbs.Will go mid to high 9's on pumpgas and 6 lbs of boost through the tailpipes.
Match Bash Racing with the Flashback AWB hemi.
https://www.youtube.com/watch?v=ij_d4RJ5kZc
35 mile drive to Coney Island in Brooklyn NY
https://www.youtube.com/watch?v=ALfJSBNBYz0
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2584465
11/29/18 12:46 AM
11/29/18 12:46 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Ran 10's on the old wedge. Hopefully quicker with the new setup.
https://www.youtube.com/watch?v=sIl-88xIsQw
https://youtu.be/IcNgpdQA4YI
Originally Posted By 68LAR
... By street legal,it must have insurance, registration, or anything else necessary to drive on the street legally. I'd also like to know the combo's.
Old set up: 446, 10.8:1, OOTB Performers (open chamber), Crane Gold rocker arms, .590 Purple Shaft, ~150hp NOS.
New set up: ???
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2584525
11/29/18 02:33 AM
11/29/18 02:33 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Mine has run 10.70's a few times and usually runs 10.80's on average days. In fact it ran 10.76 one of the first times out and I have made no changed to it since 2011 which is why it still runs the same. I just wanted to hit 10's in full street trim just as I drive it through the full exh on 92 pump usually but I have even had 87 pump in it when by mistake I put 87 in it. Still ran fine with no ping. Its a mild 440/493 that I can drive anywhere. I use Indy EZ heads and a Dwayne Porter solid flat tappet cam that's 264 & 270 @ .050 with .585 & .592 lift on a 110 LSA. Its 10.6 comp and I run the Indy dual plane intake with a Holley 850 DP. I have never uncapped the car and never had race gas in it. Its a 727 auto with a Dynamic 9.5 street/strip converter and I love driving it.The car body is all stock and all steel other then the glass hood. No tubs and no springs moved any. Ron
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2584554
11/29/18 04:14 AM
11/29/18 04:14 AM
New York, USA
Chargerfan68 Offline
New York, USA
Ive got a 505” pump gas motor with solid flat tappet cam at 10.4 comp. at 3900 lbs, it runs 10.75 @ 127mph. Edelbrock rpm just cleaned up a bit with a victor intake and 1050. 4speed stickshift with 4.30 rear. Alot of fun and i do drive it all the time. Driven 200+ miles each way to Carlisle for show.
Re: How many street legal 10 second B Bodies's [Re: Chargerfan68] #2584619
11/29/18 12:06 PM
11/29/18 12:06 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Interesting responses. From what I've read, just about everyone is running a stroker, except for, maybe three. Just about everyone is running an auto, except three. Most have some type of power adder. Seems like a pretty exclusive group, though. Good job everyone.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2584638
11/29/18 12:55 PM
11/29/18 12:55 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
https://www.youtube.com/watch?v=JUPjpF11MIc
My personal favorite. I was there that day and Jim drove it to the track and out to dinner afterwards... wink
5.53 @ 125 1/8th on the launch control..more left in her!
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2584639
11/29/18 12:56 PM
11/29/18 12:56 PM
an8sec70cuda Offline
Larry...Not a B body obviously, but my 'cuda went 10.40s at 129 mph (all motor) w/ a stock crank 440, unported Indy SR heads, .660"/266° at .050 solid roller, Weiand Team G and a 1050 dominator at 3700 lbs. 727 w/ 4.10 gears, 28x10.5 tire.
Drove it on the street a lot. It was probably the most fun street combo I've had in it. The current combo in the car is like driving on wet pavement almost all the time when you try to play w/ it on the street.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2584659
11/29/18 01:25 PM
11/29/18 01:25 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Not tagged or insured...... but.......
68 Satellite, 3670lbs, flat hood, heater, wipers, full interior, mech fuel pump, 5/16” fuel line, crank driven w/p, 9.7:1 448, ly rods, 260cfm 906’s, UD roller cam, torker 2, 850dp, 2” hookers, 5300 stall, 4.56’s, ss springs, 29.5 x 10.5 slicks.
Best ET 10.61, best speed 126+, best 60’ 1.46.
When I put the 448 back in the car after reworking the heads again and adding the roller cam, it went 10.91 right off the trailer with very used up 9 x 30 slicks on it.
Ended up mid-10.80’s that day.
Re: How many street legal 10 second B Bodies's [Re: fast68plymouth] #2584709
11/29/18 03:16 PM
11/29/18 03:16 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
10.90's @ 127
469CID
B1-BS heads
Richmond 5-Speed
Dana 60 3.54
28 x 10.5
I drive this around town quit often. beer
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2584713
11/29/18 03:20 PM
11/29/18 03:20 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
I'm working on it ... lol
72 Plymouth Roadrunner 11.08@123.25
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2584752
11/29/18 04:22 PM
11/29/18 04:22 PM
IL
Dart451 Offline
Dart451  Offline
IL
9.9's twice 10.0 enough to drive me crazy it wasn't in the 9"s lol
3300 race weight
498 Trickflow 240, Dwayne specs cam, thumper carb, Andyf "Wilson ported intake m1 intake" and 1.7 harland sharp rockers.
8" converter 4:10 gears
Dragweek 2017
Pic stolen from MoparBilly
Re: How many street legal 10 second B Bodies's [Re: Roughbird72] #2584754
11/29/18 04:27 PM
11/29/18 04:27 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
My 69 roadrunners has been 10.92 so far through the exhaust at 4000# ( with me).
10.5:1 511
Indy SR
Six pack or TM6 1050/4150 ( both ran the same)
SFT
4.10 gear
DOT’s
Heater is even hooked up and working. No roll bar because it’s a street car.
Tried to add picture but this site isn’t iPhone friendly..
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2584789
11/29/18 05:45 PM
11/29/18 05:45 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
interesting stuff. looks like a lot of different ways to get down in the 10s. all cool
Re: How many street legal 10 second B Bodies's [Re: 68LAR] #2584879
11/29/18 09:51 PM
11/29/18 09:51 PM
K
KOS Offline
KOS  Offline
K
68 charger 3840lbs
451 Low deck, eddy performers, comp (middle) street roller cam, eddy perf rpm intake
850DP Holley, 1 7/8 hookers.
727 9"4800 stall and 4.10 Dana 60rear
10.9s 122-123mph and I drove the car everywhere.........
Re: How many street legal 10 second B Bodies's [Re: KOS] #2584982
11/30/18 12:45 AM
11/30/18 12:45 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Mine is a 493 EZ std.port heads,Comp XTQ series flat cam,10.9 compression,Performer RPM with Quick fuel 1050 4150 series carb,Richmond 5-speed, 3.54 Dana,lights,wipers,horn,tags,insurance, 93 octane pump gas.
It has run 10.91 and a tic over 125 MPH on a 9" slick.
Putting a rollbar in it this winter so I can be legal and make the wife happy that I'm safe shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: How many street legal 10 second B Bodies's [Re: fourgearsavoy] #2585211
11/30/18 03:21 PM
11/30/18 03:21 PM
moparx Online content
moparx  Online Content
i'm going out on a [LONG] limb here [with saw in hand of course], and say i'm GUESSING my bunch of 10 second 1/8 mile cars growing up don't count ? biggrin laugh2 just KIDDING of course ! stirthepot
beer
Page 2 of 4 1 2 3 4
