Page 3 of 5 1 2 3 4 5
Re: HEMI oil consumption? [Re: madscientist] #2583588
11/27/18 09:57 AM
11/27/18 09:57 AM
Tennessee
Hemi ragtop Offline OP
Tennessee
Thanks for the replies. It seems all agree that the oil ring in the pin hole is not an issue. To back it up, I talked to three “name” piston manufacturers that agree with you guys.
I have found cylinder walls that I don’t like, and oily valve head/guides on the intake.
I have finally got the crank out and am waiting to get some measurements.
So, you guys don’t have a problem running a 4.5” stroke on the street?
After reading posts on here about cranks, I am a little hesitant to let my Callies go!
Re: HEMI oil consumption? [Re: Hemi ragtop] #2583615
11/27/18 11:15 AM
11/27/18 11:15 AM
an8sec70cuda Offline
Like has been said many times already...the oil ring location isn't your problem, the 4.5" crank isn't a problem, and worn valve guides and/or valve seals won't cause as much oil consumption as you have.
If the above was an issue, then my 572" hemi would have guzzled oil (all 3 "problems"), but it never has.
I still believe your issue all along has been ring seal.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: HEMI oil consumption? [Re: Hemi ragtop] #2583616
11/27/18 11:20 AM
11/27/18 11:20 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If the bores aren't completely FUBAR, you might get away with honing with an appropriate finish for whatever ring material you choose.
A freshen up will be less painful than a full rebuild.
Kevin
Re: HEMI oil consumption? [Re: Hemi ragtop] #2583702
11/27/18 03:15 PM
11/27/18 03:15 PM
On your deal you need to measure all the bores with a torque plate mounted to see if the bores are round and straight before doing anything to fix the oil consumption problems twocents scope
Re: HEMI oil consumption? [Re: Hemi ragtop] #2584057
11/28/18 08:58 AM
11/28/18 08:58 AM
Tennessee
Tennessee
Just finished getting everything out of the block (working on it in evenings after work). Next step is getting it to a competent machine shop for measuring and evaluation.
Re: HEMI oil consumption? [Re: Hemi ragtop] #2584448
11/28/18 11:25 PM
11/28/18 11:25 PM
Tennessee
Tennessee
Well good or bad, I a taking everything to a shop that “checks out” next week. I want everything measured, and a written estimate of what it will take to make it right. We will see how it goes.
Re: HEMI oil consumption? [Re: Hemi ragtop] #2584657
11/29/18 01:23 PM
11/29/18 01:23 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I wouldn't be afraid to drive one day one way to take it to shop that is really high end. JMO.
Sheldon
Re: HEMI oil consumption? [Re: RUNCHARGER] #2593371
12/17/18 09:13 PM
12/17/18 09:13 PM
Tennessee
Tennessee
Update. For all of you that said bore seal, you were right. Valve guide issues as well.
I spent a day in Greenville TN With Bob at Performance Automotive.
He did a lot of work on Allan Johnson’s Pro Stock project. The first thing he did was run a bore gauge in the cylinders. The block was bored and finished honed when I delivered it to the first shop. I have the receipts from Diamond Racing. The pistons (Diamond) were 8032 alloy, fit at .003-.0035.
So why was there an obvious cross hatch and a measurement of .007-.0075? The first shop obviously didn’t think there was enough clearance?
The intake guides were round, no taper and measured .0015-.0017. But the exhaust were round and straight but .006-.0065?
So, DOUBLE the ideal clearance on the pistons, causing ring failure. The extra clearance in the guides didn’t help either.
Re: HEMI oil consumption? [Re: Hemi ragtop] #2593374
12/17/18 09:21 PM
12/17/18 09:21 PM
Tennessee
Tennessee
So on to the next question. I have a buyer for the original un ported aluminum MP heads. I think that I should go with the new Edelbrock head designed for larger stroked HEMI engines, (mine is 540cid and will be larger once the bores are round and true).
I hate to go to all this work and expense and not make an improvement!
Combo is 4.375? Bore with 4.5 stroke. 248/254 @ .050, .585” lift net on a solid roller.
I am running a Mopar “Marine” intake with two 750 Hollys.
This is a 4,175lb STREET car with 3.54 gear and Gear Vendor overdrive.
It made peak power (635) at 5,900 rpm with the MP heads.
What do you all think about going to the Edelbrock heads?
Re: HEMI oil consumption? [Re: Hemi ragtop] #2593415
12/17/18 10:42 PM
12/17/18 10:42 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Which would net the best bang for the buck; a quality port job on the heads you have or buying new heads?
Master, again and still
Re: HEMI oil consumption? [Re: Hemi ragtop] #2593420
12/17/18 10:47 PM
12/17/18 10:47 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
And how does that intake and carb combo compare to an Indy DP and Dominator? I'll bet that the DP and a big Thumper Dominator would find some missing ponies. And maybe some better street manners to boot.
Re: HEMI oil consumption? [Re: Hemi ragtop] #2593479
12/17/18 11:53 PM
12/17/18 11:53 PM
Washington
madscientist Offline
Washington
I don't know of ANY ring that will seal with 100% or more clearance. Why guys don't believe what the piston manufacturer says for clearance isn't enough. I mean...if an extra .0005 (half a thou) doesn't keep the piston from sticking in the bore, nothing will.
That excess clearance is a ring seal killer. I still believe that a coating from Line 2 line would have fixed that issue.
And guides with a clearance like socks on a rooster won't help either.
Re: HEMI oil consumption? [Re: Hemi ragtop] #2593489
12/18/18 12:02 AM
12/18/18 12:02 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Most of the time, the recommended clearance from the piston manufacturer is the minimum recommended clearance.
If that amount of oil was coming by the rings, the car should have been followed around by a continual cloud of blue smoke.
Re: HEMI oil consumption? [Re: fast68plymouth] #2593496
12/18/18 12:10 AM
12/18/18 12:10 AM
Washington
Washington
True, but he also said the exhaust guides were loose too. The piston may not have been loose enough to road fog everything, but ring seal was certainly compromised.
Re: HEMI oil consumption? [Re: Hemi ragtop] #2593663
12/18/18 11:14 AM
12/18/18 11:14 AM
Porting the current MP heads is a better choice performance per dollar. Send them to MCH and have them CNC'd.
That much guide clearance definitely isn't a good thing, but it wasn't causing much, if any, of your oil consumption. Especially considering it was the exhausts and not the intakes that were worn.
CHIP
Re: HEMI oil consumption? [Re: an8sec70cuda] #2593847
12/18/18 04:30 PM
12/18/18 04:30 PM
I had a set of BB iron heads that had less than .0030 guide to valve clearances that had oil running down them onto the top of valves that I saw when removing the headers puke
That was back in the days when some racers didn't run valves seals on the exhausts, me included realcrazy work I started running them after that up
Re: HEMI oil consumption? [Re: Cab_Burge] #2593967
12/18/18 09:26 PM
12/18/18 09:26 PM
Tennessee
Tennessee
Yes I saw oil on the valve stems. How tight can I set them? Considering everything, do you guys not think I would be better off with the Edelbrock head? After all, it flows way more at .600 lift than my MP heads. They were “designed for 500+ ci engines?
Re: HEMI oil consumption? [Re: Hemi ragtop] #2593971
12/18/18 09:39 PM
12/18/18 09:39 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
My understanding is the stock heads were to big for 426 inches and they work much better w/ another 100 inches. What would the flow be of ported stockers @ .600 vs. the flow of stock Edelbrocks?
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: HEMI oil consumption? [Re: Hemi ragtop] #2594068
12/19/18 01:23 AM
12/19/18 01:23 AM
I was told by a very competent Hemi engine builder, racer and machinest to run no more than .0010 on the intakes and no more than .002125 on the exhaust on a new pump gas street motor build up
Re: HEMI oil consumption? [Re: HemiRick] #2594143
12/19/18 08:53 AM
12/19/18 08:53 AM
Tennessee
Tennessee
My understanding is stock ported flow about 330 vs the Edelbrock 400
