Converting fuel types. E85, E98, Methanol. Pros and Cons. #2582872
11/25/18 04:58 PM
11/25/18 04:58 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
Due to my solid block, I want to change over from gasoline to keep the temps down. I'm going to convert my carbs, and run through a belt drive pump. I'm looking for advantages and disadvantages of using any of the ethanol or methanol fuels available. Any fuel I use will be more than likely purchased from VP, so yes, sealed containers to eliminate fuel quality deteriorations.
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: sgcuda] #2582907
11/25/18 06:35 PM
11/25/18 06:35 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Methanol can run really rich without penalty (about 250% of gas volume, jetting accuracy need not be spot on, will run well near 5:1), most corrosive (can't leave fuel in the car), most power, tolerates high static and dynamic CR. Doesn't like to start cold, needs big pump, lines, regulator, filter etc. Very hygroscopic - every time the container is opened, air containing water vapor enters. Always use the smallest container you have. I've heard of using an inflatable bladder to fill the air space, but material?
It eats aluminum, brass, Buna-n, calcium, copper, galvanized steel, lead, magnesium, neoprene, Nitrile, plastics, Plexiglas, potassium, rubber, shellac, varnish, zinc, and many paints.
How about using CO2 or Argon (I think Nitrogen still has some water vapor?) to expel meth from the container?
You may get away with a smaller (lighter, weight off the nose) radiator.
Alcohol flames are nearly invisible, be sure your car has warnings for the safety crew.
Boffin Emeritus
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: sgcuda] #2582917
11/25/18 06:53 PM
11/25/18 06:53 PM
sgcuda Offline OP
sgcuda  Offline OP
Poly, all of the fuels will require some kind of flushing sequence figured into the maintenance program. Some of the new methanol fuels have anticorrosive lubricants added already to help slow down corrosion. (ie: VP's M3 fuel). A 5 gallon pail will probably be the right amount for 1 day of thrashing at the track, so no old fuel lying around. I did forget about the flame visibility problem. Good point. Warning stickers on the car look to be in order.
[image][/image]
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: sgcuda] #2582958
11/25/18 07:56 PM
11/25/18 07:56 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Man I can’t wait to read some of the responses from this post. Lol. Since I just had a post about alcohol recently I will butt out and enjoy.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: pittsburghracer] #2582977
11/25/18 08:34 PM
11/25/18 08:34 PM
sgcuda Offline OP
sgcuda  Offline OP
I don't remember that post. But then again, I don't remember what I had for dinner last night. Lol! I hope I don't get slammed, beaten and tossed aside, and told to read a book. spank
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: sgcuda] #2583088
11/26/18 01:04 AM
11/26/18 01:04 AM
gregsdart Online content
gregsdart  Online Content
I run methanol, use Klotz fuel lube, and apparantly am blessed by the fuel gods because i top off the tank, plug the vents, and leave it even over winter that way. I have had to rebuild my fuel system once,a year ago. First time for some of the parts since 1998. The big deal with methanol as i understand it is it will suck moisture out of the air, which allows oxygen to attack what ever it can. So if the fuel is not allowed access to air, and has Klotz in it, I personally have had good fortune. I like methanol for the extra power and tuning window, better than ethanol, MUCH better than gas. I did buy a primer plus system this year. I bought the plus system with a one gallon tank since i fully intend to use th system at all times but the run. If you run water through your heads i believe you can get by with a fairly small cooling system. Just off the top of my head i am thinking you might want to ask about heat buildup between the center two exhaust valves? I understand some motors get water plumbed into the heads below the center ports in circle track apps. It might not be a big deal in a drag motor shruggy
Since i have been kept away from the track A LOT in the last few years, i have some jugs of methanol dated three years old that check ok, no significant water in them. Keep em capped and in a cool place.
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: sgcuda] #2583127
11/26/18 04:49 AM
11/26/18 04:49 AM
I switch to E85 four years ago and still use it up
My bracket current car has two very small oil coolers for the radiator due to it being a blown methanol burning car that was towed all over at the race track except for the burn out and run before I bought it work
It runs very consistently from early morning to late afternoons and cools down quickly, I have to drive it around a lot more than I would on gasoline to get the coolant and oil temps up in the morning work
I do use the local pump E85 so your fuel deal will probably by be more consistent than my fuel supply work
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: sgcuda] #2583162
11/26/18 12:01 PM
11/26/18 12:01 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
if i was wanting to "keep temps down", I would run methanol because it has a 30% higher latent heat of vaporization.
for those of you that skipped or don't remember your HS science class, latent heat of vaporization is the amount of heat required to convert a unit mass of a liquid into vapor without a change in temperature.
Methanol has to remove more heat to change to a vapor.
Joe
Without Data, you’re just another guy with an opinion.
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: sgcuda] #2583183
11/26/18 01:09 PM
11/26/18 01:09 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
I've read the other alky posts and don't recall if anyone has stipulated the ideal compression ratio for its use. Iron vs aluminum head? On some recent builds, pump gas motors were pretty close in power to the high compression brothers(11:1 and +). With the 25% + use with alcohol and the procedures required, pump gas was cost effective and simple to use since we all started out using it. My BB injected altered from 40 + years ago ran a heater core as a radiator. At 13:1 with an aluminum head, the motor always wanted more heat. With zoomies, the fumes were not so appealing with a slow staging opponent. I did have some cylinder wall wash issues. Had to send the injectors to Ronco in Blue Bell PA every year to have the lines replaced. They seem to develop cracks. I assume that fuel line quality has increased since then. Without changing the direction of original question, I met 2 guys that were big bracket racers that ran in the 9.50-10.50 range. Pretty consistent. Both used a methanol injection system with their race gas.
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: sgcuda] #2583362
11/26/18 07:48 PM
11/26/18 07:48 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I played with E-85, and the engine did run cooler. I did not change out my old cellulose fuel filter, and the E-85 caused it to fall apart and get into the carb. I used that as an excuse to install the FiTech EFI, with new high pressure pump and stainless steel screen fuel filter. Currently running gasoline, but I might try out the EFI with the E-85 again. Just need to install the larger Walbro 450 lph pump that is good with E-85.
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: sgcuda] #2583377
11/26/18 08:22 PM
11/26/18 08:22 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The VP C85 is a very good compromise between gas, and meth. You get real cooling, but not so much that you can't get heat. Corrosion is negligible compared to meth. Half the cost of race gas, and makes more power than gas because of the O2 in the fuel. The C85 also has MTBE, as a further oxidizer.
Ive ran meth in carbs, and injected, and it is for sure the way to go if you're making big power where that's all that will work. Gas is too hot in the summer, and meth is a pain in winter. E or C85 works great in both.
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: sgcuda] #2583407
11/26/18 09:30 PM
11/26/18 09:30 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Since no one read this, I'll just take it down, m'kay?
Boffin Emeritus
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: sgcuda] #2583432
11/26/18 10:50 PM
11/26/18 10:50 PM
sgcuda Offline OP
sgcuda  Offline OP
My goal is to run upwards of 14:1 cr with as close to a flat top piston as possible. It shouldn't be too hard with a 4.560 bore and a 4.625 stroke. Once the heads are done, I'll see how much they can be milled to get the proper chamber cc's to run a flat top. I remember the MTBE additives from years ago. They (Ecology Police) finally figured out that while trying to save the birds and the frogs, they were causing cancer to us mere mortal humans. I'm thinking of starting out with VP M1, and maybe switch over to M3 once I get a handle on how methanol works.
[image][/image]
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: sgcuda] #2583449
11/26/18 11:15 PM
11/26/18 11:15 PM
PA.
"Little"John
"Little"John
PA.
Man you guys run the good stuff. Lol. I like the 145.00-165.00 for 54 gallon stuff.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: sgcuda] #2583452
11/26/18 11:21 PM
11/26/18 11:21 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
I have been racing about 7 years I'm on my second BB A body and have never used anything but M1 methanol. Its how my first car came set up and , I have not found any real downsides, although it can be a hassle at times. Something no one has mentioned is you cant just jump in the car and run it for a minutes on a cold engine. You must bring it up to 180 to burn off any condensation from inside the engine. If not you will most likely milk the oil with the moisture. Alky binds with water, and that is the enemy when using alky as a fuel. That said there are ways around it such as a primer plus system as mentioned or something similar to run and warm up on gas, and belt driven vacuum pumps to pull the moisture out. I do none of that. I'm just careful. Also have used 3 year old methanol and didnt notice any difference form fresh. Lots of guys down south run it to both keep the engine cool and for the consistency it provides in high humidity as it doesn't rely on atmospheric oxygen like gas. I think if you want to be a competitive bracket racer, and especially if you are in the south, it's a wise move. That said I am running in the north and see plenty of guys on gas printing time slips. Depending on what your set up is you will probably spend a couple of grand converting over properly and thats with a carb not mech . injection. If you do this dont skimp and do your homework or your going to spend alot of money and have alot of problems.
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: sgcuda] #2583507
11/27/18 01:07 AM
11/27/18 01:07 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Our next big block engine will be set for E85
1963 Plymouth Max Wedge
1971 Barracuda
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: sgcuda] #2583508
11/27/18 01:10 AM
11/27/18 01:10 AM
sgcuda Offline OP
sgcuda  Offline OP
I have heard either a Primer Plus system, or some guys use oil heaters to get some heat in the motor prior to fire up. With a solid block, warm up shouldn't be too hard, even on alky. Lol! Working with a close friend and expert on fuel systems to help with the carburetion calibrations.
I really appreciate everyones input on this. This is unknown territory for me, and I'm really looking forward to the challenge.
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: sgcuda] #2583647
11/27/18 12:50 PM
11/27/18 12:50 PM
New York
polyspheric Offline
polyspheric  Offline
New York
How does that work?
Boffin Emeritus
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: polyspheric] #2584447
11/28/18 11:24 PM
11/28/18 11:24 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
How does that work?
Sorry if I wasn't exact with my statement. Methanol is an oxygenate, meaning it has oxygen in it. Changes in the atmosphere, don't effect like gasoline.
Re: Converting fuel types. E85, E98, Methanol. Pros and Cons. [Re: sgcuda] #2585294
11/30/18 06:43 PM
11/30/18 06:43 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Well, why not really put some compression in it if you're going meth? 16:1 is just dandy.
