changing over coil packs #2581914
11/23/18 02:28 PM
11/23/18 02:28 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I have a really stupid question.
do you really need to secure down the coil packs to the valve cover? I am switching from the 04-05 style to the 06 and up. If I have to I am going to make different hold downs using the 04 hole pattern. is this really needed? they seat or click on the plugs just like any other plug wire.
I didn't have hold downs on my traditional small block plug wires.
I am sure I am missing something so please smack me around and get me on the path of Gen 3 again.
thanks again for the help
I ordered/bought a bunch of stuff Wednesday and am getting closer to firing this thing up
Thank you
Kiddart
Re: changing over coil packs [Re: Kiddart] #2582222
11/24/18 02:00 AM
11/24/18 02:00 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Anybody??
Thank you
Kiddart
Re: changing over coil packs [Re: Kiddart] #2582228
11/24/18 02:19 AM
11/24/18 02:19 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I would think the weight of the coil would fatigue the unit/connection from vibration over time. That is vs a plug wire only.
RT
Re: changing over coil packs [Re: Kiddart] #2582281
11/24/18 10:31 AM
11/24/18 10:31 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
While I don't think they would go anywhere I do think the vibration over time could cause problems.
68 Barracuda Formula S 340
Re: changing over coil packs [Re: Kiddart] #2582288
11/24/18 10:52 AM
11/24/18 10:52 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
These guys have few options for mounting the coil packs
http://thecrankshopvt.com/product_info.php?cPath=22&products_id=791
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: changing over coil packs [Re: Kiddart] #2582662
11/25/18 01:43 AM
11/25/18 01:43 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
The coil packs do not click on like a spark plug. They need to be retained.
Re: changing over coil packs [Re: Kiddart] #2582759
11/25/18 12:24 PM
11/25/18 12:24 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I am going to make so retainers. I can see spending a bunch of money on fancy valve covers. I will figure something out.
thanks for all the guidance
Thank you
Kiddart
Re: changing over coil packs [Re: Kiddart] #2582763
11/25/18 12:36 PM
11/25/18 12:36 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
I have some extra remote coil pack brackets I have left over from a sullivan valve cover install.. I mounted mine under the intake , so I didnt use them
Re: changing over coil packs [Re: Kiddart] #2583089
11/26/18 01:13 AM
11/26/18 01:13 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Johnscudashop,
do you want to sell? and can you send me a photo
Thank you
Kiddart
Re: changing over coil packs [Re: Kiddart] #2583805
11/27/18 07:12 PM
11/27/18 07:12 PM
Mrytle Beach SC
Mrytle Beach SC
This site wont let me post pictures easy of the brackets..SMH
Re: changing over coil packs [Re: Kiddart] #2584277
11/28/18 05:36 PM
11/28/18 05:36 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
send me a pm with a atachement that should work
Thank you
Kiddart
Re: changing over coil packs [Re: Kiddart] #2584298
11/28/18 06:21 PM
11/28/18 06:21 PM
Australia
L4staero Offline
L4staero  Offline
Australia
Is it easier to just buy a set of the later valve covers?
Re: changing over coil packs [Re: Kiddart] #2584627
11/29/18 12:32 PM
11/29/18 12:32 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
they are expensive, at least the ones I have found. I am trying to keep this to a bare minimum swap. I guess I need to prove to myself that a junk yard hemi can run and run well. Seeing isn't always believing. So far I am in for about 3K on the swap. Headers and Computer have been the biggest cost.
Thank you
Kiddart
Re: changing over coil packs [Re: Kiddart] #2584793
11/29/18 06:00 PM
11/29/18 06:00 PM
Australia
L4staero Offline
L4staero  Offline
Australia
Factory plastic covers are generally $60-$80 a pair or $80-100 for the later eagle/apache ones
Re: changing over coil packs [Re: Kiddart] #2584867
11/29/18 09:29 PM
11/29/18 09:29 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
and where would I find that price. I find them for $80 a piece here in metro Detroit. I would gladly pay $60 to $80 for a pair
Thank you
Kiddart
Re: changing over coil packs [Re: Kiddart] #2586230
12/02/18 06:20 PM
12/02/18 06:20 PM
NE Ohio
Y
YeahItsAHemi Offline
Y
NE Ohio
The eagle 09+ Hemi valve covers also work on pre-eagle heads. Not the other way around though. I’m using 09+ covers for my coil pack swap. Getting them cheap is kinda a game of luck
Re: changing over coil packs [Re: Kiddart] #2586798
12/03/18 10:25 PM
12/03/18 10:25 PM
Australia
L4staero Offline
L4staero  Offline
Australia
I generally just scrounge through ebay once a week looking for good deals.
Kniw what u are looking at and u can get some bargains on stuff. Saw a set of perfect Apache heads go for $200 on ebay
Re: changing over coil packs [Re: Kiddart] #2586832
12/03/18 11:53 PM
12/03/18 11:53 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I bought a pair last night rh and lh for 100. not exactly the deal of a life time but you have to look. I am now looking for apache heads as well. I need to sell by small block short block to buy them but it will sell eventually. I hope.
Thank you
Kiddart
