69 Charger 440 RT AC compressor clutch engaging in heat mode #2582143
11/23/18 11:21 PM
11/23/18 11:21 PM
NC
Sixt8Chrgr Offline OP
NC
My AC compressor is engaging when I push my heat button "in". Per the FSM the compressor clutch should be off. I supposed there is 12 volts going to the compressor when it shouldn't. Any idea where I can look for this problem?
Thanks!
Re: 69 Charger 440 RT AC compressor clutch engaging in heat mode [Re: Sixt8Chrgr] #2582145
11/23/18 11:30 PM
11/23/18 11:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Is it in the defrost mode?
Re: 69 Charger 440 RT AC compressor clutch engaging in heat mode [Re: Sixt8Chrgr] #2582169
11/24/18 12:08 AM
11/24/18 12:08 AM
NC
NC
No it is in the heat mode. When I hit the defrost button I don't get much air at all at the glass but get the same on the floor as heat mode.
I restored the car including rebuilding the heater box. I thought I had the vacuum lines all back in the right places? I did read that the linkage on the defroster duct could need to be adjusted to get the correct air flow. Prior to restoration I never ran the heat because of a bad heater core. But did run the AC and it worked well.
Re: 69 Charger 440 RT AC compressor clutch engaging in heat mode [Re: Sixt8Chrgr] #2582273
11/24/18 10:02 AM
11/24/18 10:02 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I rebuilt one for a 69 Charger and bench tested all of my servos. I had one that was failed on almost every spare box I had. You need to test them before you install those. They are 50 years old and have a rubber diaphragm. You may not have the correct plastic switch on it as well. A 69 B body has a different one with a pigtail plug on it. All the ones you can still buy are direct plug in. Not sure they interchange.
Re: 69 Charger 440 RT AC compressor clutch engaging in heat mode [Re: Sixt8Chrgr] #2582276
11/24/18 10:09 AM
11/24/18 10:09 AM
NC
NC
What plastic switch are you referring to? There is a pigtail that comes out of the compressor with a plastic plug. I did replace that wire and plug, and the wire from the firewall to the compressor is new. I did not test the compressor prior to installing it.
Re: 69 Charger 440 RT AC compressor clutch engaging in heat mode [Re: Sixt8Chrgr] #2582460
11/24/18 05:24 PM
11/24/18 05:24 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
Even though most of the 5 button A/C switches look the same they do not function the same. Your car calls for part #3431020. If you installed part #3502126, pushing the heat button activates the compressor. That switch is for a C body. The pics below show that they both look the same. Many Ebay sellers list them as fitting all applications, which is wrong.
Re: 69 Charger 440 RT AC compressor clutch engaging in heat mode [Re: twodoorpost] #2582774
11/25/18 01:07 PM
11/25/18 01:07 PM
NC
NC
Thanks for the info, but I never took out the original. Still works fine, unless this is the culprit.
Re: 69 Charger 440 RT AC compressor clutch engaging in heat mode [Re: Sixt8Chrgr] #2582838
11/25/18 03:17 PM
11/25/18 03:17 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Look at your original unit. These went out on a regular basis and were changed often. As I said, your oem dated one should have a pigtail soldered on to those three prongs in the middle of the switch. Look for the part no and date code and post it here.
Re: 69 Charger 440 RT AC compressor clutch engaging in heat mode [Re: Sixt8Chrgr] #2583090
11/26/18 01:17 AM
11/26/18 01:17 AM
NC
NC
Ok, for now I have disconnected the power feed to the compressor. Heat works well. Will post up the numbers
