Engine choice for daily driver dually pickup
#2581822
11/23/18 06:17 AM
11/23/18 06:17 AM
Posts: 115 Sydney, Australia
tuff440
Sydney, Australia
Guys I would like some input on an engine combo for my dually pickup which would be a daily driver and work vehicle. I would like to build something using the parts I have as money is tight at the moment. I have a few 318's, a 4 inch scat cast crank with 318 mains, standard bore 360 block and crank, a 440 thats nearly complete and a 318 poly. The 440 is a 30 over 74 casting. It has cast crank, LY rods, TRW 2355 pistons. It has arp main studs and rod bolts, performer rpm 84cc heads which have been lightly ported, guide clearance has been corrected as has the sloppy valve seat machining, manifold is a torker which has been port matched. I have a comp xe275hl cam which I think is to much cam for the application and mopar electric distributor and orange box. I think with the right cam and efi this combo would work pretty well. Or would a mild 318 with lightly ported heads, about 9.5:1 comp, cam with around 215-220 duration at .050, single plane iron intake with efi be a better choice. Alternatively I could put the 4in crank in and make use of the extra torque. Would ported 318 heads still be ok with the stroker crank considering I'm after torque. I could also machine the mains on the 360 crank and would have 350ci. I have both open chamber and closed chamber 318 heads. Another option is a 318 poly or I could drop in the scat crank and have 390ci It doesn't need to turn harder than 5500rpm. It has a dana 70 with 3.54 r&p with powr loc and trans will be be either a 727 I have which has been rebuilt already or maybe a 518 4 speed. Should weigh around 5500lbs once decked out for work. Would like to be able to tow a car trailer on occasion also. What do you guys think, all opinions welcome. https://i.pinimg.com/originals/3b/42/d1/3b42d190a98cb3d71a9ed26210c82dfa.jpg
Re: Engine choice for daily driver dually pickup
[Re: tuff440]
#2581839
11/23/18 10:43 AM
11/23/18 10:43 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
if fuel isn't an issue go with the 440 Next choice for me would be the 390 inch Poly.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: tuff440]
#2581840
11/23/18 10:45 AM
11/23/18 10:45 AM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
As long as you want a truck and not a HotRod, I would build a 360 or stroked 318 based on the parts you already have. 440 is easy torq but you feed it ALL the time. Watch the tire O.D. to not kill the gear ratio too. I have had and pulled with a nearly stock 360 and they do suprisingly well. An added positive with a smallblock is when travelling or broke down,it is MUCH easier to find smallblock parts at parts stores etc... [way more common} VS BigBlock,at least here in the states. IMO.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: tuff440]
#2581854
11/23/18 11:18 AM
11/23/18 11:18 AM
Posts: 4,457 Washington
madscientist
Washington
I'd use the 440 as a starting point. I'd build it with a stroke and rod length that gets you a nice piston as far as ring belt and compression height. The added CID will help with fuel mileage. Use an OD trans. Pick a nice cylinder head that fits your displacement/RPM and cam accordingly.
[Re: tuff440]
#2581855
11/23/18 11:18 AM
11/23/18 11:18 AM
Posts: 871 WA 98043
thecarfarmer
WA 98043
Isuzu 4BD1T...
Seriously, if $$$ are tight, there are decent 5.2Ls awaiting adoption at your local recycler's yard.
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
[Re: tuff440]
#2582092
11/23/18 08:21 PM
11/23/18 08:21 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
you didn't give enough info ..... but this is what I know, 440=under 10mpg ANY way you build it. But the most power for gasoline. 318 stroker? why bother . 360 best small block. I run an 1989 cummins 5.9 diesel good milage good power awesome reliability low maintance. I also understand you want to use what you have on hand. that's my 2 cents.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: tuff440]
#2582299
11/24/18 12:07 PM
11/24/18 12:07 PM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Man if your gonna do a new engine and your obviously a gear head I say the 440. How fun and cool would that be? EVERYONE has a 318 or 360- kind of a yawn. I say build a torque monster 440 with a nice dual exhaust and good dual plane manifold with a great street carburetor like the poly Street Demon (Modern upgraded Thermoquad). Building a torque monster means utilizing OEM parts like rocker arms and heads- this keeps cost down and preserves reliability. Having 480 plus lb feet of torque at your gas pedal would make driving your work truck fun. Run the tried and true ( and affordable!) Trans Go shift kit in a robust 727 transmission. Yea gas mileage will be not good but your not gonna get great mileage with any engine you presented. Might as well have fun with that big wide legendary 440 Mopar!!!!!
Keep old mopars alive.
[Re: tuff440]
#2582433
11/24/18 04:22 PM
11/24/18 04:22 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I wold do the 318/392 unless its an eagle crank, if that was the case I would build a 360 for TQ.
I built a 360 magnum for a 97 dodge 2500 and with a mild cam upgrade from Rapid340, EQ heads and steel shim head gaskets it pulled great and mileage was the best I had ever seen in a 3/4 ton truck, I borrowed it a few times and checked as I didn't think he was checking it right. Tight quench and as much compression as your fuel can handle are your friends.
If I was in your shoes thogh I would be very tempted to go 392 poly if I could find a 4bbl intake.
[Re: tuff440]
#2583187
11/26/18 01:17 PM
11/26/18 01:17 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
You got the 440 just about ready to go and money is tight...seems like a no brainer.
BB dually!
2 kids and a dog
[Re: TonyS451]
#2583256
11/26/18 03:29 PM
11/26/18 03:29 PM
2boltmain
Holland MI Ottawa
BB dually! Yes yes and yes! Dual plane intake, real street carburetor, appropriate dual exhaust and a moderate accelerator foot. Probably match a 2000 era 5.9 Magnum Rams 12 mpg city. Plus-its a big HEAVY work truck. The 2.08 intake and 1.74 exhaust valves and ports of a factory head work great in this type of idle to like 4800 RPM application.
[Re: tuff440]
#2583267
11/26/18 03:53 PM
11/26/18 03:53 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
You won’t find an OD trans for a 440 or a poly. Things can be adapted, but no direct economical choice. That leaves you with the small block option.
