Re: Motor Mounts [Re: 70charger512] #2581743
11/22/18 11:57 PM
11/22/18 11:57 PM
NC
70charger512 Offline OP
#1 Thread Starter
#1 Thread Starter
NC
So what I'm hearing is solid on both sides shouldn't be too much of a problem. I will probably do that, worst case I could easily swap the pass side back out if necessary.
Re: Motor Mounts [Re: 70charger512] #2581745
11/23/18 12:00 AM
11/23/18 12:00 AM
New York
polyspheric Offline
polyspheric  Offline
New York
The 2 mounts serve different purposes, and are subject to opposite forces.
Boffin Emeritus
Re: Motor Mounts [Re: Cab_Burge] #2581746
11/23/18 12:00 AM
11/23/18 12:00 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
well the op ask for a STREET car that only see track ocasinaly !
and yes cheep hardware store chain and i bolts can strech !
now get a piece of G7 chain and equil eye bolt and have a small amount of movement that does not transmit vibrations to car from solid strap for a STREET car and have best of both worlds !
Re: Motor Mounts [Re: 70charger512] #2583167
11/26/18 12:24 PM
11/26/18 12:24 PM
an8sec70cuda Offline
I'd use solid mounts. The vibration doesn't bother me.
If you're worried about it, use stock mounts and get the torque strap from Schumacher Creative Services. I have one on my dad's six pack road runner and it works great.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Motor Mounts [Re: 70charger512] #2583365
11/26/18 07:53 PM
11/26/18 07:53 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I bought a set of the interlocking Poly mounts. They are expensive, so I just used one each on the drivers side mount of my two cars, and run good quality stock replacements on the passenger side.
