Re: Removing upper control arm stud from Front Spindle
[Re: Sammy]
#2583477
11/27/18 12:08 AM
11/27/18 12:08 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
The problem with using a fork and a hammer is the arm is held in place by 2 rubber bushings.
For this method to work well, the arm needs to be held solid.
Can you unbolt it from the lower ball joint and remove the upper control arm by the bushings?
[Re: Sammy]
#2583546
11/27/18 02:51 AM
11/27/18 02:51 AM
Posts: 31,078 Oregon
AndyF
How hard is it to get the upper control arm stud out of the top spindle hole on the front wheel? Does it pop right out or do I need a specialty tool for removal? I never did this before and don't want to mess anything up. Depends on what you're doing. If I'm in a wrecking yard pulling knuckles for a disc brake swap then I use a pickle fork and a 5 lb sledge. If I'm in my home shop working on my own car I use the FSM tool to pop things apart.
[Re: Sammy]
#2583764
11/27/18 05:30 PM
11/27/18 05:30 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I've tried hammering, etc... then purchased the factory tool (from Mancini).. and it was easy... wish I had it before I tried the hammer.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
