727 work/storage stands? #2580019
11/18/18 11:01 PM
11/18/18 11:01 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
As in something you can lay the trans upside down on that keeps it level if you need to work on it. I've seen one, but can't find any listings for a commercially available product. Am I looking in the wrong places, or should I expect to make my own?
Re: 727 work/storage stands? [Re: BradH] #2580022
11/18/18 11:11 PM
11/18/18 11:11 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
DONT remember the rim size (14" steel wheel I think) flipped over - the trans bell sits in that then a cheapie jack stand to hold up the tail housing ' probably did 500 727s and 904s that way
Re: 727 work/storage stands? [Re: BradH] #2580195
11/19/18 02:29 PM
11/19/18 02:29 PM
AndyF Online content
AndyF  Online Content
Brad, do you want a transmission bracket for your engine stand? That way you can rotate the trans around for assembly and tear down. It is nice to have the trans on its back for some operations but it is also nice to have it vertical when dropping the parts in. I have this old trans stand sitting in the corner. I'll give it to you if you pay the freight.
Re: 727 work/storage stands? [Re: AndyF] #2580253
11/19/18 04:31 PM
11/19/18 04:31 PM
BradH Offline OP
BradH  Offline OP
Andy - That's a generous offer. I suspect that the front tab(s) that fixture mounts to is also the tab(s) that had to be removed from the case to fit the CSR form-fit trans shield I use. I'll check and see if my memory is right or not, though.
Re: 727 work/storage stands? [Re: dOrk !] #2580254
11/19/18 04:33 PM
11/19/18 04:33 PM
BradH Offline OP
BradH  Offline OP
Can't say that's not functional, but I was thinking something more intended for the purpose and space-efficient.
Re: 727 work/storage stands? [Re: BradH] #2580283
11/19/18 06:08 PM
11/19/18 06:08 PM
I also have the style that bolts to the front of the case which will work when the ears are removed. I'll snap a picture to show you how it works. It is a new product I was working on so you can test it for me.
Re: 727 work/storage stands? [Re: AndyF] #2580540
11/20/18 09:56 AM
11/20/18 09:56 AM
BradH Offline OP
BradH  Offline OP
work
Re: 727 work/storage stands? [Re: BradH] #2581426
11/22/18 05:09 AM
11/22/18 05:09 AM
Brad maybe this is too simple/not what you are after but what about just bolting (2) legs on the front/& as said a stand under the tail?
Re: 727 work/storage stands? [Re: RapidRobert] #2581453
11/22/18 11:12 AM
11/22/18 11:12 AM
BradH Offline OP
BradH  Offline OP
Nothing wrong with that idea. I was thinking about making a wooden cradle, too.
Re: 727 work/storage stands? [Re: BradH] #2581722
11/22/18 10:52 PM
11/22/18 10:52 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I made one out junk I had laying in the garage 30 years ago. 2 pieces of 3/8 rod, 1 piece of 1/4" rod, 2-5/8 bolts, and a welder. You weld bolts 90 degees to the end of the rod, bolt to bell of trans, bend a 90 about 6" down, another 90 about 14" back, then cross your 2 rod and weld to catch the rear. Weld a piece of 1/4 or 3/8 rod across the lower rear of the rods so it does not spead and its done. Do not weld rod across front, that way rods bend and it works for big and small blocks. Ghetto I know, but never saw a need to upgrade.
Re: 727 work/storage stands? [Re: 4406bbl] #2581784
11/23/18 01:58 AM
11/23/18 01:58 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I bought this transmission holder from Summit and bolted it to one of my old engine stands that I didn't trust for holding engines. It works great.
Untitled by John Cadamore, on Flickr
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 727 work/storage stands? [Re: pittsburghracer] #2582133
11/23/18 10:49 PM
11/23/18 10:49 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Plywood, 2x4 and angle iron drilled for both bolt patterns (SB & BB). Been using this for years.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
