904 2-3 runaway shift, what to check/adjust
#2579703
11/18/18 12:00 AM
11/18/18 12:00 AM
RapidRobert
On the 360 stock car, my racing partner who was driving reported it. It is a stock unit & I'm sure due to be gone thru but if a band adjustment would be a likely culprit I will do that. Thank you for your time.
Re: 904 2-3 runaway shift, what to check/adjust
[Re: calrobb2000]
#2579732
11/18/18 01:37 AM
11/18/18 01:37 AM
RapidRobert
I believe you! I kinda knew in the back of my mind that it is time. Thanks guys.
[Re: dvw]
#2579825
11/18/18 01:12 PM
11/18/18 01:12 PM
RapidRobert
throttle pressure. The eng has to come out so I will go ahead & pull both.
