Re: Edelbrock heads and re-torque after initial run.
[Re: Seank]
#257961
03/18/09 11:53 AM
03/18/09 11:53 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Dont run it with no exh manifold or header. Do run it, then take off the headers of manifolds, and retorque them. Hot preferably. Many guys dont do it. I always do. Retorquing means releasing the torque (loosen the bolt) then bring it back up. You dont have to unbolt the head, just do each bolt in the std order.
This would be one of the reasons I built a running stand..lol. It really stinks, but it should be done.
[Re: Seank]
#257964
03/18/09 05:28 PM
03/18/09 05:28 PM
moper
Columbia, CT
If it's not in yet, try finding a local guy with a run in stand. I help friends out with it. it's a LOT easier. Another thought would be dyno time... break it in right, get it squared away, so it's done when it goes in. When you're looking at the time and effort, sometimes the dyno aint such a bad idea.
[Re: moper]
#257965
03/18/09 05:49 PM
03/18/09 05:49 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I usually just torque them to 75 and recheck a day or two later one bolt at a time loosening and bring up to 75 all in one pull! My dad had a long funny story (well funny to me) about re torqing his indy heads on his 69 super bee show car. They told him just go 75 and forget but he decided to warm it up. first he fired without the manifolds! he said Jesus the flames shoot out 3 feet!!!! LOL!! right to hs laquer painted fenders! Then he slid the manifolds on and started again. that set the cardboard he had under the car so oil would not get on the floor on fire. That nearly gave him a heart attack getting the flames out. dam he was in his mid sixties at the time with a bad ticker surprised it did not but he lived another 10 to 12 years after that!!
[Re: dynamite]
#257967
03/18/09 08:41 PM
03/18/09 08:41 PM
Posts: 4,450 Michigan
MarkZ
Worthy
Worthy
I torqued the bolts again a few days later while the motor was on the stand and that was it. 8,000 miles so far on the new motor. I did torque the header bolts though, multiple times.
[Re: dynamite]
#257968
03/19/09 06:57 AM
03/19/09 06:57 AM
Posts: 3,822 Arlington, Texas
bobby66
Arlington, Texas
On our 512 stroker with Eddys I did it by the book ..got it to temp ,cooled down and retorqued ..and after about 100 miles it pushed the gaskets out..( 1009 felpros )..I have only seen thar on Blower motors...water in # 2 cly brought it to my attention..whats up with that ...11:1 comp
Dealing with the same thing right now. Water in # 2. Checked other side and the fire ring is separating from the gasket. Glad I checked. I've heard you need to re-torque pretty often with the aftermarket heads. Now I believe it.
[Re: bobby66]
#257969
03/19/09 09:54 AM
03/19/09 09:54 AM
RapidRobert
I cant help thinking that it is a gasket(quality) issue as opposed to "aluminum" heads needing constant retorquing EDIT & if I did R&R the head gaskets I'd for sure check the block/heads & see if their still flat & if so I'd think it's the gasket
[Re: RapidRobert]
#257970
03/19/09 10:01 AM
03/19/09 10:01 AM
Posts: 1,178 Indy
FlyFish
Indy
I didn't know you needed to retorque the heads...my 360 with Eddy's and Felpro 1008 gasket ran for 8 years on the bottle all the time with no issues...maybe I was lucky.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
