Power steering pressure port thread size #2579067
11/16/18 09:53 AM
11/16/18 09:53 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I’m trying to convert the pressure port on my 70 cuda to receive a different hose with a #6 AN fitting. We can’t figure out what the fitting thread and size is called. It’s a straight thread with no taper so it’s not NPT. It uses a copper washer for sealing. Where would you get a fitting like that? We’ve tried ever place in town. Hate to just order something without knowing what to call it.
Re: Power steering pressure port thread size [Re: fastmark] #2579068
11/16/18 09:59 AM
11/16/18 09:59 AM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline
Blown_Hemi  Offline
Inverted flare to AN. I have used smaller ones on brake lines. You just have to find thread size. 1/2" maybe?
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: Power steering pressure port thread size [Re: fastmark] #2579085
11/16/18 12:00 PM
11/16/18 12:00 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Rockauto has the info in the power steering section. looks like 5/16 SAE
Don't be the exception.
Re: Power steering pressure port thread size [Re: fastmark] #2579091
11/16/18 12:12 PM
11/16/18 12:12 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
its just a straight thread port fitting. some of the power steering pumps use an inverted flare. it would help to know what year car and pump we are talking about
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Power steering pressure port thread size [Re: Jerry] #2579098
11/16/18 12:29 PM
11/16/18 12:29 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
This is a custom application with a single serpentine belt and pump. Tru-trac, I think. They have regulate AN fittings on the pump. That’s not the problem. It’s the fitting out of the power box. It’s a fine thread that’s straight. We need to eliminate the original flared adapter that goes to the oem hose.
Re: Power steering pressure port thread size [Re: fastmark] #2579131
11/16/18 01:32 PM
11/16/18 01:32 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
I've made those for the gear boxes in the past. take a pic of the fitting and post it here. you need to modify an AN fitting with a -6 male jic
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Power steering pressure port thread size [Re: fastmark] #2579176
11/16/18 02:47 PM
11/16/18 02:47 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Is a -6 male jic the same thing that goes through a hole like a bulkhead connector or oil pan pick up?
Re: Power steering pressure port thread size [Re: fastmark] #2579243
11/16/18 05:27 PM
11/16/18 05:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The straight threads in the valve are 1/2"-20, same as #5 AN.
Re: Power steering pressure port thread size [Re: fastmark] #2579303
11/16/18 08:43 PM
11/16/18 08:43 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Thanks. I just screw my thread chaser in the hole and discovered it was 1/2”x 20. We have to go to 6 an so I bet we can.
Re: Power steering pressure port thread size [Re: fastmark] #2579310
11/16/18 09:02 PM
11/16/18 09:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Power steering pressure port thread size [Re: fastmark] #2579470
11/17/18 10:40 AM
11/17/18 10:40 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
You da man, John. I don’t know how it is that I can look for stuff and not find on jegs or summit either one. Thanks.
Re: Power steering pressure port thread size [Re: fastmark] #2579794
11/18/18 11:23 AM
11/18/18 11:23 AM
VA
dragon slayer Offline
VA
Doesn't that Jeg add say it is 1/2" NPT? I thought the valve body was 1/2"-20?
Re: Power steering pressure port thread size [Re: fastmark] #2579802
11/18/18 11:53 AM
11/18/18 11:53 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Earl's Power Steering/Fuel Pump Adapter Fitting -06AN to 1/2"-20
Re: Power steering pressure port thread size [Re: fastmark] #2579838
11/18/18 01:44 PM
11/18/18 01:44 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
In the description, it does say NPT but I think that is incorrect. It looks straight to me with an inverted flare on that end as well. I’m not sure what the 20 NTI other than national threads per inch. NPT would have threads all the way to the end. May have to call Earls.
