512 C.I. 440 pump gas motor, what will it make in Chico CA #2579035
11/16/18 04:04 AM
11/16/18 04:04 AM
Cab_Burge Offline OP
I'm leaving in the morning to take a 512 C.I. pump gas motor to a DTS dyno in Chico, CA. We will dyno test and tune it on Saturday and then let the new owner take it home and play with it devil
Hopefully it will either scare the heck out of him or addict to more power work devil whistling grin
It is a 1968 HP2 block bored and honed to 4.380 with a torque plate, 4.250 stroke with a set of Eagle 6.86 long Hemi rods with L19 bolts. the pistons are a custom set of Diamonds with a reverse dome with -24 CC dome volume for 9.9 to 1 compression ratio. A set of non ported Eddy RPM heads and a Eddy RPM intake with a Holley 850 D.P.. Comp Cams 292H hydraulic cam and lifters with a set of Crane 1.5 roller tip extruded aluminum rocker arms which give it right at .514 net lift on the intake and exhaust. The duration at .050 is 244 on both with the same lobe lift on both lobes, it is ground on a 110 LSA and installed at 109 intake lobe center.
Nothing exotic or special, just a good old pump gas motor work whistling
I'm hoping to be back on Saturday night and I'll post some results then or Sunday morning.
No rewards for the closest guess but give me your opinions anyways thumbs
Re: 512 C.I. 440 pump gas motor, what will it make in Chico CA [Re: Cab_Burge] #2579042
11/16/18 04:56 AM
11/16/18 04:56 AM
Washington
madscientist Offline
Washington
Chino from Bend is a pretty healthy drive.
Re: 512 C.I. 440 pump gas motor, what will it make in Chico CA [Re: Cab_Burge] #2579064
11/16/18 09:46 AM
11/16/18 09:46 AM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Heads and lift are kind of small for this, Ill say 535 hp and 540 tq.
Re: 512 C.I. 440 pump gas motor, what will it make in Chico CA [Re: Cab_Burge] #2579106
11/16/18 12:39 PM
11/16/18 12:39 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
525 hp @ 5100 610ft/lbs @ 4000 just going by what my 9:1 493 did with an M1 single plane, MP509 108 lsa and 1.7 rockers. Nothing done to the heads but a proper valve job.
Mine fell off a cliff after peak power.
Kevin
Re: 512 C.I. 440 pump gas motor, what will it make in Chico CA [Re: Twostick] #2579124
11/16/18 01:19 PM
11/16/18 01:19 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I witnessed a 499" RB with a .509 and Rhoads awesome lifters make peak about 540hp peak at 5200 on a DTS dyno. It had a six pack intake and promax carbs.
Have a safe trip Cab!
Re: 512 C.I. 440 pump gas motor, what will it make in Chico CA [Re: Cab_Burge] #2579153
11/16/18 02:14 PM
11/16/18 02:14 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Sounds like a torque monster.
Chico is about mid-CA, Chino is well South of that. Neither is much above sea level.
Bend/Chico 7-8 hours, add another 5-6 for Chino as I remember it...unless you run into the "tule-fog" at night; avoid that if you can.
Re: 512 C.I. 440 pump gas motor, what will it make in Chico CA [Re: topside] #2579155
11/16/18 02:19 PM
11/16/18 02:19 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Chico is not mid-California tsk . Chico is 1 1/2 hours north of Sacramento. Mid California is Fresno. Cab.... You're heading directly to 'Ground Zero' for the Camp Fire, things are a genuine mess right now fotr air quality and general ambiance. You sure You need to do this? Is that the closest Dyno to You in Bend, OR?
Re: 512 C.I. 440 pump gas motor, what will it make in Chico CA [Re: Cab_Burge] #2579163
11/16/18 02:26 PM
11/16/18 02:26 PM
AndyF Offline
AndyF  Offline
Yeah I wouldn't head to Chico with the Camp fire still burning. From what I read on the news all of the local hotels are full for miles around since so many homes have burned down. Plus, the air quality has to be zero with all the smoke blowing right into town.
Re: 512 C.I. 440 pump gas motor, what will it make in Chico CA [Re: AndyF] #2579222
11/16/18 04:47 PM
11/16/18 04:47 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Cab, for what it is worth Grant Springer racing engines in Eugene, Or. has a engine dyno now. Grant has passed away but a guy named Ray Hoover runs it now.
Re: 512 C.I. 440 pump gas motor, what will it make in Chico CA [Re: AndyF] #2579438
11/17/18 03:26 AM
11/17/18 03:26 AM
Massillon, Ohio
cudatom Online content
cudatom  Online Content
Massillon, Ohio
Agreed. I'm working in Chico trying to help those affected by the fires. It's a mess. I travel almost an hr ea day to get there. Trying to find housing for people has been a challenge. Many are having to be house in Sacramento, Redding and further away.
Ok
Re: 512 C.I. 440 pump gas motor, what will it make. Results [Re: Cab_Burge] #2579890
11/18/18 05:11 PM
11/18/18 05:11 PM
I arrived in Chico Friday afternoon around 1.30 PM, the air quality in Chico was worse than I ever saw in L.A. going back the early 1960s up to when we moved out of CA in 2005, even when SO CA was having fires.
The motor didn't make as much power as I expected but do they ever whistling
We loaded the motor on the dyno and I bought ten gallons of local fuel for testing. We waited for the owner to arrive on Saturday morning before starting the motor and testing.
It did make a lot more torque than HP but that seems to be normal on Wedge motors with less than 10.5 to 1 compression ratio, it made 619.6 Ft Lbs. at 3000 RPM and 443 Ft. Lbs. at 6000 RPM. Peak torque was 643 Ft. Lbs. from 3800 RPM to 4100 RPM so it should put the driver back in the seat pretty well any time he goes to WOT boogie devil
HP was 354 at 3000 RPM and peaked at 552 at 5100 RPM with 506 at 6000 RPM. We did pull it up to 6500 RPM but it was done down lower so we stopped at 6000 RPM after that.
We tested timing and a did a little bit of jetting and tried two different spark plug brands and heat ranges and a two inch reversion spacer as well as a bigger exhaust system. It responded well to all the changes, we found out what it liked and didn't like wrench
I told the owner the finish tune up needs to be done in the car with him driving it the way he likes drives on the pump gas he uses with the exhaust system hooked up with the hood closed in his town. up
It has a oil leak around the back of the motor so I brought it back home to fix it and determine exactly where the stupid leak is, this is the third motor that I've had this problem with runaway
I'll post what I find on the leak once I find out exactly where it is leaking from scope It looks like it is leaking around the rear main seal holder but there is no oil on the back of the crankshaft flange being slung off shock
Dang Murphy anyways whiney grin
If we don't get tested now and then we will never get any better, will we work
I think the combination of the low compression ratio with aluminum heads and the little camshaft along with the small 3.0 inch collector on the headers I used made the motor do what it did shruggy
All my new motors from now on will have bigger set of headers and bigger camshafts to make more power on the dyno and in the cars up
I won't blame the bad air for any of the bad results as it was clearing up on Saturday some shruggy
The real proof will be when the owner calls me after putting it in his car and drives it work luck grin
Re: 512 C.I. 440 pump gas motor, what will it make. Results [Re: Cab_Burge] #2579894
11/18/18 05:38 PM
11/18/18 05:38 PM
Santa Rosa, Calif
angleiron2 Offline
angleiron2  Offline
Santa Rosa, Calif
Just FYI we ran our 512 Dart at Sonoma Raceway Weds Night with extremely smoky condition and the car ran the same MPH and et it did the week before.
Re: 512 C.I. 440 pump gas motor, what will it make. Results [Re: angleiron2] #2579902
11/18/18 06:02 PM
11/18/18 06:02 PM
I appreciate you sharing that with me up
The DTS dyno show a correction factor based on the current weather conditions, it was below sea level in the morning when we started testing and it had a small correction factor later when the humidity went up to 40% shruggy. The barometer was reading 29.02 in the morning and dropped down to 29.82 around noon, I don't remember how much the humidity was in the morning though realcrazy
One of the guys that work at that shop was trying to bring his own car in to work on it in the morning and had a hard time due the police blocking off the offramp that needed to get there due to our President Trump visiting the area, that man never seems to stop doing things to serve our country up
Good or bad, depending on your opinion whistling stirthepot devil
We desperately need more public servants, not more POLITICIANS down twocents
Re: 512 C.I. 440 pump gas motor, what will it make. Results [Re: Cab_Burge] #2579927
11/18/18 06:54 PM
11/18/18 06:54 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
up up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 512 C.I. 440 pump gas motor, what will it make. Results [Re: hemi-itis] #2579953
11/18/18 08:18 PM
11/18/18 08:18 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
Amen!!! iagree
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: 512 C.I. 440 pump gas motor, what will it make. Results [Re: Cab_Burge] #2579959
11/18/18 08:42 PM
11/18/18 08:42 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I'm gonna go out on a limb with a wild guess.
Sounds like it's a good looking engine, and probably loud.
So..... I'm gonna guess 552ish horsepower and around 643 foot pounds of torque....
CrAzYMoPaRGuY
Re: 512 C.I. 440 pump gas motor, what will it make. Results [Re: CrAzYMoPaRGuY] #2579978
11/18/18 09:35 PM
11/18/18 09:35 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
and I'm gonna guess that THIS is the typea moder that yurr gonna need in that homely motor home of yours to keep up withe the Disco KING !
Re: 512 C.I. 440 pump gas motor, what will it make. Results [Re: dOrk !] #2579986
11/18/18 09:52 PM
11/18/18 09:52 PM
Canada
Canada
Are you stalking me....??
eek
What are you wearing........? callme
CrAzYMoPaRGuY
Re: 512 C.I. 440 pump gas motor, what will it make. Results [Re: CrAzYMoPaRGuY] #2580008
11/18/18 10:49 PM
11/18/18 10:49 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
I am stalking you ..... devil
I am wearing - bra and panties ...... callme
fIxEd !
Re: 512 C.I. 440 pump gas motor, what will it make. Results [Re: dOrk !] #2580018
11/18/18 11:01 PM
11/18/18 11:01 PM
Canada
Canada
fIxEd !
HOT!!!!!
I'll pick you up around 8:00.......
CrAzYMoPaRGuY
