Changing from 1.5 to 1.6 rockers--Clearance Question? #257894
03/18/09 10:38 AM
03/18/09 10:38 AM
Pittsburgh, PA
bobdog106 Offline OP
Pittsburgh, PA
I am getting ready to re-install my Eddy RPM's, which were just done by Jeff @ Modern Cylinder( They Look Great!! Thanks) I am changing to the Crane 1.6 rockers and was wondering if the pushrod opening needs clearanced before I bolt on the heads. I am waiting for the rockers now( from Moparts Member), so I can't test fit. I am sure somebody has done this before, Thanks for your help!
Edit( Cam is Comp Cam solid just around .586 and .591 with 1.5 rockers)
Re: Changing from 1.5 to 1.6 rockers--Clearance Question? [Re: bobdog106] #257895
03/18/09 10:46 AM
03/18/09 10:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Its going to depend on how much clearance you had before,
the 1.6 moves the pushrod in closer to the head, I
would check it anyways... full lift gets closer,
specially with a big lift
Re: Changing from 1.5 to 1.6 rockers--Clearance Question? [Re: bobdog106] #257896
03/18/09 10:47 AM
03/18/09 10:47 AM
boscosis Offline
super street
boscosis  Offline
super street
We're running Edelbrock RPM's with 1.6 Crane Rockers and we didn't have any clearance issues with the 3/8" pushrods. We're using an MP .484 cam also.
Re: Changing from 1.5 to 1.6 rockers--Clearance Question? [Re: boscosis] #257897
03/18/09 11:54 AM
03/18/09 11:54 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
Any time an engine component is change clearances should be checked IMO. Your engine and aftermarket part combination's are unique to your build, variables are bound change fit and clearances. Paying close attention to every detail when building an engine is always very important. My
Re: Changing from 1.5 to 1.6 rockers--Clearance Question? [Re: Rodney] #257898
03/18/09 02:37 PM
03/18/09 02:37 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Jeff didn't open the pushrod hole up when he ran them through the CNC program? He ported ours a few years ago and the pushrod hole was opened more also.
Re: Changing from 1.5 to 1.6 rockers--Clearance Question? [Re: bobdog106] #257899
03/18/09 04:48 PM
03/18/09 04:48 PM
Wichita Kansas
CH3NO2 Offline
CH3NO2  Offline
Wichita Kansas
mock it up before final assembly.
Engine by DeTar http://www.kansasbadman.com
Re: Changing from 1.5 to 1.6 rockers--Clearance Question? [Re: CH3NO2] #257900
03/18/09 05:17 PM
03/18/09 05:17 PM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
My heads are from MCH and didn't require clearancing. I have 1.65 int and 1.6 exh HS rockers. I have .025 or better clearance down the pushrod hole across the board w/ 3/8 pushrods. However, I've seen another MCH set that needed clearance with 1.5 rockers. I believe mine were clearanced. U might want to check with MCH as you mock up.
