Voltage regulator date code #2578671
11/15/18 11:36 AM
11/15/18 11:36 AM
Fl
Moulin Cuda Offline OP
Fl
What would the correct date code for voltage regulator for a 1970 Cuda with a build date of 5/70. I found one with a date of 4/70, but the description indicates its for a 1971
Re: Voltage regulator date code [Re: Moulin Cuda] #2578694
11/15/18 12:47 PM
11/15/18 12:47 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Please post a picture of it.
Re: Voltage regulator date code [Re: Moulin Cuda] #2578906
11/15/18 08:37 PM
11/15/18 08:37 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The general rule of thumb, and take this very loosely, is two months before your SPD.
Now since there was no First In First Out at the time a 4/70 date could be OK
Re: Voltage regulator date code [Re: Morty426] #2579003
11/16/18 01:16 AM
11/16/18 01:16 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
if it is "470" that's 47th week of 1970 (Nov. '70) which would be during the '71 model year
Re: Voltage regulator date code [Re: 6bblgt] #2579075
11/16/18 11:18 AM
11/16/18 11:18 AM
Fl
Fl
Thanks! I realized last night 470 is not 4/70, but as you said its 47th week of 1970. I will look for one dated prior to 210?
Re: Voltage regulator date code [Re: Moulin Cuda] #2579115
11/16/18 01:05 PM
11/16/18 01:05 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I have three NOS regulators with the proper bump on them and they all three over charge. If you have a lead acid battery, no problem, but not with a repo gel battery. Just saying, be careful with 40+ year old regulators. I got a new regulator and made my own bump and had ECS stamp it with a date code.
Re: Voltage regulator date code [Re: 71birdJ68] #2579525
11/17/18 01:06 PM
11/17/18 01:06 PM
Fl
Fl
I have a functioning regulator, but it's aftermarket. I'm wanting to get a correct looking regulator. I also want to get a new AGM battery
Re: Voltage regulator date code [Re: Moulin Cuda] #2579697
11/17/18 11:51 PM
11/17/18 11:51 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Then you have to make one like I did. You need a good picture of an assembly line reg to make yours look right.
