sway bars, worth it?
#2578374
11/14/18 02:11 PM
11/14/18 02:11 PM
RapidRobert
Early A body. daily driver. easy driven around town. would it show much difference in turns/be worth the investment? thank you for your time.
Re: sway bars, worth it?
[Re: RapidRobert]
#2578387
11/14/18 02:44 PM
11/14/18 02:44 PM
Posts: 7,544 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
RR, It will improve your handling, but your satisfaction will depend how sensitive you are to it. Yes, I think you will feel a difference. It would turn crisper, flatter, and create a little more understeer with a front sway. Add a rear sway and it'll go back to neutral and be much flatter in harder turns. Include stiffer shocks and your handling will be even one more step crisper. Larger, wider rims with better tires takes you another step... The more steps you take, the less comfortable it will be on the street.. Sways are a good first step.
How necessary it is, is up to you. Sways, shocks, rims, tires, are not expensive steps, easy to install, and each one improves your handling. At some point consider front discs to stop you better. But that's more money.
EXAMPLE: I like to track race, so I put a 9lb FirmFeel tubular sway on the front of our '65, plus a rear sway.. plus stiffer shocks.. plus stickier, wider tires but stayed with 14" rims (Ford 6.5") to absorb harshness.. I have a very reasonably soft ride with much tighter, flatter handling than before..
- Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: RapidRobert]
#2578396
11/14/18 03:06 PM
11/14/18 03:06 PM
Posts: 823 On the open road
Hrtbkr
On the open road
I added a rear and a thicker front to my Challenger and it made a big difference during hard turns.
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
[Re: RapidRobert]
#2578420
11/14/18 04:11 PM
11/14/18 04:11 PM
Posts: 4,446 Michigan
MarkZ
Worthy
Worthy
One of the first things I did to my Fifth Avenue was a set of matched cop car bars. Car originally only had a front 1 1/16" bar. The cop bars measure 1 1/8" and 0.75". It made a huge difference in regular street driving and changing lanes on the interstate. Honestly, it made it safer to drive.
If I was daily driving and old car I'd match a set of big sway bars and go soft on the torsion bars.
[Re: BeavisHQV]
#2578437
11/14/18 04:58 PM
11/14/18 04:58 PM
RapidRobert
And thanks again for your help in several question! Hey you are welcome. Sitting in front of the computer motionless is my favorite activity! On the S/B, there is one for sale for $80 WO the links etc. Just wondering if I should jump on it or not as the complete kit is ~2 bills & I'm sure the extras needed are available seperately.
[Re: buildanother]
#2578501
11/14/18 07:46 PM
11/14/18 07:46 PM
67SATisfaction
Albany, NY
I bought a nice, solid 67 383 fact a/c 2 door satellite years ago, and that thing leaned quite a bit on any decent corner. ..ah yup, our '67 Satellite convert is a totally stock 383/2bbl and it rolls like a drunken sailor.
[Re: Magnum]
#2578546
11/14/18 10:21 PM
11/14/18 10:21 PM
MarkZ
Worthy
Worthy
My 318 B body never cam with a bar and it handles just fine. Compared to what?
[Re: RapidRobert]
#2578565
11/14/18 11:03 PM
11/14/18 11:03 PM
Posts: 31,055 Oregon
AndyF
Early A body. daily driver. easy driven around town. would it show much difference in turns/be worth the investment? thank you for your time. Huge difference between no bar and a peformance bar. There is also a big difference between factory torsion bars and larger bars as well as factory tires and modern tires. All depends on where you want to stop. I rode in a fairly stock GTX the other day and was surprised at how mushy it was. Been a long time since I was in a stock suspension Mopar so I'd forgotten how soft they are.
[Re: MarkZ]
#2578566
11/14/18 11:05 PM
11/14/18 11:05 PM
AndyF
My 318 B body never cam with a bar and it handles just fine. Compared to what? Need a picture of a pig on ice to fully capture the handling of a B body car with tiny torsion bars, no anti-sway bar and OEM tires!
[Re: AndyF]
#2578586
11/15/18 12:10 AM
11/15/18 12:10 AM
RapidRobert
The one I got in mind is an Addco #751 & it is 1&1/8". 63 dart convertible I am resurrecting next year. EDIT I remember seeing an early A OE front sway bar & it is very small. (that jogged a memory from the /6 club of America literature decades ago, maybe 7/8"). I will have top notch tires on it.
