Enough fuel pump?
#2578280
11/14/18 09:52 AM
11/14/18 09:52 AM
Posts: 10,035 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Here is what i have. 65 Dart 3380 lbs, 408 dynoed at 504 hp, mainly street, a few trips to the track planned. I now have a Carter electric 65gph 6psi no regulator needed pump. From cell to Fram large filter -10, 3/8 fittings and hard line with no sharp turns to a regulator at rear of motor, regulator set to allow max flow/no resistance. I could put a gutted regulator body in its' place if it will help. The car runs great at WOT till after the 2/3 shift, then it felt off a bit but i have no pressure gauge to go by. I want to switch to a 65 Mustang gas tank in this car so if a better pump becomes a need, suggestions on a very low noise system would be appreciated. What do you all think? Pump OK? Pump marginal? Just too small?
Re: Enough fuel pump?
[Re: gregsdart]
#2578345
11/14/18 01:23 PM
11/14/18 01:23 PM
Posts: 1,176 East Coast
A/MP
East Coast
If your not stumbling or lagging from launch to 1-2 shift, then your pump is keeping up with with the launch inertia which is the first major issue with launching and fuel volume. If only investigating fuel issues, then your bowls might be running out of fuel. 65 gph is too little for a 408. That output is good for a stock motor. Maybe a Holey Blue at least. I like the Black Gerator. Handles all fuels and the pump is quiet enough, yet its easy to listen for when trouble shooting. Don't forget a return line, can be from the rear fuel filter,before the pump,or at the carb. Paper element filters, in general, swell and reduce the fuel flowing through. Add some extra moisture from pump gas and that can be an additional restriction. A streetable stroker SB can easily perform with a 950 carb. Its an indication of how much fuel it wants. When it comes to fuel, bigger is better, 1/2" fuel line, easy flowing direction( as you've done) and a larger adjustable pump remove any fuel delivery issues.
[Re: gregsdart]
#2578407
11/14/18 03:28 PM
11/14/18 03:28 PM
Thumperdart
State of confusion
Here is what i have. 65 Dart 3380 lbs, 408 dynoed at 504 hp, mainly street, a few trips to the track planned. I now have a Carter electric 65gph 6psi no regulator needed pump. From cell to Fram large filter -10, 3/8 fittings and hard line with no sharp turns to a regulator at rear of motor, regulator set to allow max flow/no resistance. I could put a gutted regulator body in its' place if it will help. The car runs great at WOT till after the 2/3 shift, then it felt off a bit but i have no pressure gauge to go by. I want to switch to a 65 Mustang gas tank in this car so if a better pump becomes a need, suggestions on a very low noise system would be appreciated. What do you all think? Pump OK? Pump marginal? Just too small? BS on no regulators EVER imo because those toy pumps can and do spike higher than needed at times and can drop dangerously low at higher r's.........seen it personally and fuel pressure control goes deeper than most know..........
[Re: gregsdart]
#2578478
11/14/18 06:35 PM
11/14/18 06:35 PM
gregsdart
Thanks guys. Being a mainly street rod with a nice quiet exhaust and a great radio, i will go with the EFI pump. About $500 for a tank,pump/fuel sender kit for a 65 mustang, which will fit nicely because i have removed the spare tire well. Being cheap never pays. When i bought the Carter i was thinking it would be quiet enough and cheap to boot. Not so much π
[Re: gregsdart]
#2578512
11/14/18 08:24 PM
11/14/18 08:24 PM
gregsdart
Fury, it has a Quickfuel 850 on it. The noise issue is pushing me to go in tank. I promised the Mrs this would not be a race car,,,,,,,π car weighs 3380 with me in it, so it is pretty snappyπ I do want to run Sportsman class a few times for fun, 12.00 and slower footbrake is the bracket, so i don't have to mess with a rollbar or jacket.
[Re: gregsdart]
#2578535
11/14/18 09:54 PM
11/14/18 09:54 PM
Posts: 4,213 New York
polyspheric
New York
Common in-tank EFI pump uses industry standard 43.5 psi, which increases flow in your stock fuel line dramatically.
Boffin Emeritus
[Re: gregsdart]
#2578542
11/14/18 10:12 PM
11/14/18 10:12 PM
Posts: 4,457 Washington
madscientist
Washington
Fury, it has a Quickfuel 850 on it. The noise issue is pushing me to go in tank. I promised the Mrs this would not be a race car,,,,,,,π car weighs 3380 with me in it, so it is pretty snappyπ I do want to run Sportsman class a few times for fun, 12.00 and slower footbrake is the bracket, so i don't have to mess with a rollbar or jacket. How are you going to slow it down to 12.00?
[Re: madscientist]
#2578597
11/15/18 01:06 AM
11/15/18 01:06 AM
gregsdart
At a minimum i will let it shift on its' own. Full forward standard type valvebody. I am not sure what i want to do to take more ET out of it and still have a killer mph. Gears are 3.55, and will run 28 inch slicks.
[Re: gregsdart]
#2578607
11/15/18 01:30 AM
11/15/18 01:30 AM
madscientist
Washington
At a minimum i will let it shift on its' own. Full forward standard type valvebody. I am not sure what i want to do to take more ET out of it and still have a killer mph. Gears are 3.55, and will run 28 inch slicks. My math says you should be in the 10.70ish range at 124 or so. To slow it down that far, you'll need to pull 2 plug wires and hire a 450 pound driver.
[Re: gregsdart]
#2578709
11/15/18 01:27 PM
11/15/18 01:27 PM
gregsdart
Thanks Cab. I am going to go with the intank deal, and it will get rid of the iritating pump noise. Too bad the whole deal is that pricy. Anybody need a good fuel pump for thier garden tractor?π
