Re: 4 speed - grinding when going into Reverse
[Re: LAR_414]
#257799
03/18/09 09:10 AM
03/18/09 09:10 AM
Posts: 4,285 Ohio
64dodge572
Ohio
Larry-if it is grinding going into reverse, the input is turning or trying to turn. Since you've adjusted the clutch different ways, I would think the input may be tight in the pilot bushing, or the input is bottoming out in the crankshaft. Is it a Lakewood bell housing? Did you check the bell housing bore runout? A mis-aligned bell housing will also cause the pilot to grab in the bushing.
Wayne
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: 64dodge572]
#257800
03/18/09 09:31 AM
03/18/09 09:31 AM
Posts: 4,573 ...gently down the stream
LAR_414
Thanks Wayne, The Bell is a Quicktime, that I corrected the runout to under .005", so it's good. The input shaft doesn't bottom out in the crank, I'm sure of it. I have a mopar pilot bearing in there (torque converter register), and it fits just fine on the input shaft.
I understand what you are saying, but I just can't seem to figure out why the input shaft is still turning. The clutch is a McLeod Dual Disc RST organic face.
In all forward gears, life is fine. Actually, better than fine. I absolutely love the clutch.
Reverse is the only area that I need to figure out.
[Re: LAR_414]
#257804
03/18/09 10:34 AM
03/18/09 10:34 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
Like I wrote, I tried that numerous times. Put it into a forward gear and then to R. I've tried letting the clutch out a little in a forward gear, let it out in N, and then try R. I've double clutched N and then into R.
Every time, I get a slight crunch. Not too bad, but I'd like to get rid of it.
Maybe it's just this dual disc clutch dragging a little on the floater plate? But if that was the case, wouldn't it grind a little going into first gear at a dead stop?
I'm not 100% sure it would. IIRC, the A833 has synchronizers for all forward gears, but not reverse.
[Re: 1fastrunner]
#257806
03/18/09 10:59 AM
03/18/09 10:59 AM
LAR_414
Hmmmmm...funny you mention idle. I've had an issue where my idle is too high, and I'm out of adjustment on the 2 carbs. So I know I must have a vacuum leak somewhere. That's an issue that is next on the table. Not a huge leak, but enough that I can't get my idle down below 1200rpm hot right now. Maybe that's keeping things spinning too much ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) I've disconnected the only vac port and it didn't change anything. The carbs are not leaking, so it's probably in the top for my cross ram or even the ports sealing to the intake. What do you all think?
[Re: LAR_414]
#257807
03/18/09 11:33 AM
03/18/09 11:33 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
My 440 idles at about 1400.Its super radical and my old 65 4 speed dosent grind going to reverse.Rocky
Chrysler Firepower
[Re: LAR_414]
#257810
03/18/09 11:42 AM
03/18/09 11:42 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
My 70 runner did this too... I tried adjusting it some, but never did go awau.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: LAR_414]
#257812
03/18/09 12:58 PM
03/18/09 12:58 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Larry-since you have the adapter in the torque coverter register, you need to make sure the input diameter is .747 diameter all the way down to the taper before the spline area. Often they were not ground all the way to the taper, and are .010" to .012" larger diameter for the last 1/4" inch or so.
Wayne
